How could the effects of the Glasgow Central closure be mitigated?
bluesfromagun
12 Jul 2010
Moderator note: Split from
As somebody stated earlier in this thread, the biggest issue with running anything is the train crew situation. If staff cannot access the mess facilities, booking on points, and so on - then trains can't run, or at least trains crewed by Glasgow Central drivers (and conductors) that is. That's the vast majority of local services. There'll be Ayr, Corkerhill, Shields, Dumfries, Motherwell crews at work, but you couldn't even begin to run much of a service with that alone. Plus even planning that at short notice is a nightmare.
If the station or even just the crew facilities remain closed for any amount of time, they'll quickly need to come up with a solution, and it'll probably involve basing crew at Atrium Court temporarily, and relying on taxis to get them to Paisley or Motherwell or wherever services are stopping short. You'd also need Portacabins in most of the places you were changing crew over too, so that there were mess facilities and toilets - you can't just say to a driver or guard "your break is at East Kilbride now", you have to provide them with somewhere to sit, a toilet, cooking facilities.
mrmartin
17 Dec 2012
Can't ScotRail just rent a cafe/restaurant nearby (the entire venue) for a "mess" room?
380101
18 Feb 2015
Their HQ is a 2min walk along Waterloo St from Central Station. I expect they will use the training Academy for bothy facilities.
b0b
25 Jan 2010
Any chance they might consider re-opening a couple of the western platforms, and using the Argyle St and or Hope St entrances while keeping most of the station concourse closed? I guess the first signs of life is probably going to be re-opening the lower level platforms.
Krokodil
23 Jan 2023
Wales
You'd also need portacabins in most of the places you were changing crew over too, so that there were mess facilities and toilets - you can't just say to a driver or guard "your break is at East Kilbride now", you have to provide them with somewhere to sit, a toilet, cooking facilities.
When Llandudno Junction was closed by a fire a temporary messroom and booking-on point was set up in a pub in Colwyn Bay.
Whilst it's too late to do anything about it for this occasion, it is surprising that emergency planning for a major station like Glasgow Central being out of service does not include a sufficient number of staff being signed for the alternative stations and routes that would form part of the plan.
It's hard enough to get someone to pay for route knowledge for very routine diversions (like GWR Plymouth crews no longer signing Bridgwater or TfW crews not signing Bescot), never mind for something exceptional like this.
185143
3 Mar 2013
Of course nowadays, most TOC drug and alcohol policies would rule that out!
norbitonflyer
24 Mar 2020
SW London
I don't see why, as long as it is clearly understood by all concerned (rail staff and bar staff alike) that the train crew are not allowed alcohol.
Krokodil
23 Jan 2023
Wales
Officially ATWs policy was that staff shouldn't be in licenced premises in uniform. I presume that this rule was ignored on the basis that they had hired the venue for their exclusive use.
185143
3 Mar 2013
AIUI, being in licensed premises in uniform is generally a no go.
I agree, in exceptional circumstances such as these, if that's the nearest suitable location common sense should prevail. All Safety Critical staff know they're not allowed alcohol.
b0b
25 Jan 2010
presumably the hotel has conference rooms that might be useable as a temporary mess
35B
19 Dec 2011
Absolutely. I've stayed in hotels for work which have been used for aircrew accommodation, and their bookings were clearly differentiated to avoid alcohol consumption in the hotel.
Based on reports of a colleague who worked as a stewardess on long haul, those policies didn't always work 100%
RiverDon
11 Mar 2024
They're using the Training Academy on the ground floor at Atrium Court, the Scotrail HQ, for booking on and PNB facilities. It is a 2 minute walk along Waterloo Street.
AilsaBus
7 May 2023
According to Google maps, Argyle Street is shut where it passes under Central station. When that reopens, I expect the low level station will too. It's easy to block off the escalators leading to the main concourse. For the time being, Argyle Street station is a short walk from Central so its an easy alternative for passengers on that line.
It is not shut, the road under Central Station and the access to the low level has been open since the works on Argyle Street started. I see no reason why they can't allow trains to stop at the low level and direct passengers to use the Argyle Street and Hope Street low level entrances.
800001
24 Oct 2015
There must be a valid reason why they not stopping at Low Level. Otherwise they would!
Easy to make judgements without knowing full facts.
MadCommuter
4 Oct 2010
SFRS has a large hose from the Clyde going up Oswald St to Gordon St to supplement the water supply and not overdraw from Scottish Water's supply. I'm guessing this pipe prevents Argyle St from being opened to traffic. This alone though, doesn't prevent access to the low level platforms from the other end of the umbrella. Unless they have 2 hoses from the Clyde, one up Jamaica St and one up Oswald St?
The exile
31 Mar 2010
Somerset
Unless any “control functions” for the Low Level operate out of areas currently “out of bounds”.
35B
19 Dec 2011
Or they just want to manage the dispersal while they assess the condition. As has been noted, Argyle Street station is hardly far from Central.
AilsaBus
7 May 2023
I’m assuming they’re going to be moving the 390s that are stuck in the station as WCR 57314 is currently heading north to Glasgow on this working.
Why would they need to send a locomotive up to rescue the 390s?! Surely they could be driven out under their own power?
b0b
25 Jan 2010
or they think there's still a risk that the fire isn't completely out or re-ignite
enginedin
15 Dec 2020
Health and safety getting silly now. I doubt turning the power on is going to cause anything bad to happen.
Depending on what mains cables have been damaged by the fire or huge amounts of water it might not even be possible to turn the power on...
800001
24 Oct 2015
You seem to be an expert on all things railways/fire.
You think it safe to have trains stopping at Central Low Level and now think it's ok to have OHL power turned on.
I think many people will side with the profession people on the ground who know what they are dealing with and what preventative measures need to be implementers
Warrior2852
27 Oct 2018
It's not generally sensible to have 25 kV exposed wires turned on next to an active situation involving fire damage.
AilsaBus
7 May 2023
Where have I claimed to be an expert?
JModulo
17 Nov 2013
67A
No. You will likely find the power is still isolated. Even if the power was live, the fact that sets have been sat there, essentially abandoned, means the batteries will now likely be flat meaning you wouldn't could use them anyhow.
Taunton
1 Aug 2013
Temporary bridging units are available to allow traffic to continue to run over the top of fire hoses. They are extensively used in Continental cities, especially to allow tram services to continue over them at walking pace. They are just spiked into the asphalt. I think they are called 'Kletterweiche'.
Fire services taking water from other than the public supply doesn't seem too common in the UK, but it does happen. In California, particularly after earthquakes when the city supply may be fractured, they classically draw water from all the nearby houses' swimming pools.
father_jack
26 Jan 2010
These.....
