thachieman350
- Joined
- 1 Sep 2011
- Messages
- 20
Does It make a certain noise as it passes ?
Thanks Jesse
Thanks Jesse
A rythmic tapping sound as the train passes by.
Can even get rough riding if it's a bad flat and you're on board the train...
Thanks Jesse
I've only had a flat so bad it could be felt once and I took the set out of service.
How do trains even get wheel flats?
Slippery rails, heavy braking are probbably the most common cause of Wheelflats - Just listen to most Freightliner Flats for those!
I've had one myself. All the old hands say that if you can hear it then it's not too bad, but if you can feel it then it's time to stop!
I've reported a few that were bad enough to be felt, one of which was particularly worrying as the thumping and the vibration kept suddenly stopping to be replaced by a squealing noise, ie the wheelset in question was actually locking up! This was at 100mph on the WCML in a Mk3; the guard refused to even come to listen to it!
Should I have kicked up a formal stink about that after arrival at Euston?
( Note - this was about 10 years ago now ).
No not really, you did your bit by telling the guard, when a flat stops thumping is is usually on a curve and this indicates the flat is on one side of the wheel, this is very common in fact, you get the thump on a LH curve and nowt on a RH one, as for the squeeling this is probably flange squeal and not a wheel locked up,
In the case in question, the curvature made no difference. It seemed to be totally random; happening on both left and right hand curves and equally not happening on the left and right hand bits. The thumping got progressively worse as the journey continued. From memory I was on the train all the way from Carlisle to Euston. The vanishing thumping and replacement by squealing started about an hour into the journey; prior to that it had just been non stop thumping.
