Historical Train Performance Statistics - Open Data
Class172
Quizmaster
20 Mar 2011
West Country
I'm currently investigating the feasibility of a small research project that would compare historical train performance statistics for a single or small group of stations against another non-rail dataset. The data I have in mind are the distributions of services that are on-time/delayed x-mins/cancelled for a given station over a long time period, a bit similar to the information displayed in the performance graphics on OnTimeTrains but without the limitation where the data only appears to go back 12 weeks. I would ideally like to look at longer timescales (the longer the better), which could be focused on a single/small group of stations rather than the entire network. To clarify however am not interested in aggregated TOC PPM statistics.
I feel like this is data that would likely be available in the various open data repositories/portals/marketplaces, however I don't exactly know where to start looking, or even if sufficient information is available to make the project worthwhile. I am hopeful however because looking at recenttraintimes.co.uk I appear to be able to query arrival/departure times from farther back in time (March this year). With this in mind, I would be appreciative of suggestions for which datasets may be used and how far back in time they go. It may be I proceed no further if data isn't suitable, but I would rather rule it out if that's the case. Thanks in advance.
Tom
19 Jan 2008
35,000ft
HSP might be the data feed that you want from an open data perspective.
At RTT we have data going back a long way which, depending on the research project and purposes, we may be able to make available for free.
Class172
Quizmaster
20 Mar 2011
West Country
Thanks for the HSP suggestion. I've sorted access to it this morning and will take a look around.
I may send you a message later to discuss the nature of the project and whether one of your datasets may be of use.
