I presume, given the length of the sidings, that they were just doing fit checks on the cranes, etc.Doesn't seem efficient if only three containers at a time will operate.
Actually it was FOUR which makes all the difference!Doesn't seem efficient if only three containers at a time will operate.
Probably one of the central belt terminals for redistribution onto trains for the south. Could be more than one terminal depending on which FOC(s) work out of Blackford.Where will the service be going to once it is up to speed, Mossend?
St Albans railfreight has been resisted because the developer had given themselves so many excuses to use the road link that it was unlikey to operate like a rail freight interchange, instead pushing yet more HGVs onto inadequate major and local roads.Not only for Scotland but the whole UK.
How many years have the proposed railfreight depots at Four Ashes (Wolverhampton) and St Albans been held up by objection after objection? Every MP wants more freight on rail.......as long as the depot is in someone else's constituency.
Council pop!It's great to see freight coming off the road, though it's still slightly absurd that we're sending bottles of water all over the country when we have pipes and taps.![]()
Not quite so absurd if you ever taste Northumbria Water through the tap. Tastes like mouthwash - even worse when boiled for a cuppa.It's great to see freight coming off the road, though it's still slightly absurd that we're sending bottles of water all over the country when we have pipes and taps.![]()
A pedant writes:Actually it was FOUR which makes all the difference!![]()
In fairness, I did have a bottled water yesterday in work as the water out of the tap tastes like it may well have come from Northumbria!Not quite so absurd if you ever taste Northumbria Water through the tap. Tastes like mouthwash - even worse when boiled for a cuppa.
More power to Highland Spring's elbow, I say and hopefully a forerunner.
Maybe a new thread - lines close to a natural spring?![]()
Likely off thread. There is a huge difference in taste of tap water, because of the additives. Even before you start to think of hard / soft water. The stuff we drink smells of swimming pool chlorine chemicals if we don't let the water 'stand' for a while. We are near the source. Apparently the level diminishes before it gets to 'metropolis' where it doesn't taste as yukky.In fairness, I did have a bottled water yesterday in work as the water out of the tap tastes like it may well have come from Northumbria!
It will take 8,000 lorries off the road and cut CO2 emissions by more than 3,000 tonnes every year.
Scotland’s first dedicated rail freight facility in a decade has opened in Perthshire.
The hub, created by water company Highland Spring, is being hailed as an example other firms need to follow if Scotland is to become net zero by 2045.
Highland Spring bottles 500 million litres of water a year.
Until now, the firm has relied on a steady stream of lorries to transport the water.
Agree whole heartedly with that, - bottled water is an environmentally damaging indulgence.I think it would be much better if people drank tap water instead (use a filter, run the tap for a few seconds if it tastes strange).
True, but the thread is about the facilities in Blackford, - which is definitely in the Scottish Highlands.According to my map, Blackwater is not in the Highlands!
It definitely isn't.Agree whole heartedly with that, - bottled water is an environmentally damaging indulgence.
Compared to Blackwater (I assume that Hampshire was in mind), it is much more Scotland and not that far from whatever the locals there might define as their 'highlands'.It definitely isn't.
We're agreed that it isn't in the Highlands.Compared to Blackwater (I assume that Surrey was in mind), it is much more Scotland and not that far from whatever the locals there might define as their 'highlands'.
To a sassenach or outlander (as you will) it's as near as matters to the highlands where the water is presumably claimed to be drawn from, and certainly not the realtive flatlands of north-east Hampshire.*We're agreed that it isn't in the Highlands.
Indeed. Highland Spring is a brand name, not a claim of origin.To a sassenach or outlander (as you will) it's as near as matters to the highlands where the water is presumably claimed to be drawn from, and certainly not the realtive flatlands of north-east Hampshire.
I'm not sure what you mean by "put on the road". Essentially the traffic through the new terminal was largely roaded in containers to longer-established terminals in the Scottish Central Belt and then on trains to Daventry. There is a well established distribution network from Daventry with major names like Tesco and Sainsbury's having depots within the DIRFT complex.How many lorries are put on the road at the other end to distribute the water? Is rail transport so efficient that the business can be grown more? How much more water could be extracted?
Whats the latest with this? Are the trains using the depot?
Would it not have been an idea to have a northbound access so that existing HML frights could have looped in and out of the terminal, had containers added or removed, and trundled on without any shunting or decoupling?
Highland spring water can be found in every major retail outlet up here in the shire, how does it get here...The working aren't part of the usual Inverness or Aberdeen runs, which are out-and-back trip workings from the Central Belt.
Instead Highland Spring is envisaged to be its own out-and-back working, with the container flats then martialed into southbound trains.
I don't know about the status of workings, however it's been build on the basis that traffic volume will warrant its own trip working, and therefore there is no need for a nothbound connection
