Highland Line blocked this morning..
D89 HAC
19 Jan 2018
I’m booked on the 1450 Inverness to Stirling today which Scotrail inform me has been partially cancelled. I believe it’s a broken down train somewhere south of Kingussie. Any more news on my chances of making it through to Edinburgh? Any further gen welcomed.
Blindtraveler
28 Feb 2011
Mentioned over in the Caledonian sleeper thread. I think there's a 66 on a freight in some kind of serious mechanical trouble
Do lner sign via Elgin for the purposes of diverting the London service
ld0595
1 Aug 2014
LNER to Inverness was cancelled this morning. I'm sure the Chieftan was directed via Elgin in the past but not sure if they still do.
Looks like it must be a serious issue for the 66 since it happened around 5:30pm yesterday.
Haywain
3 Feb 2013
I haven’t heard of an LNER service running that way for many years, so I would say no as the crews will not have appropriate route knowledge. In any event the Chieftain didn’t run to Inverness yesterday.
The Puddock
10 Jan 2023
Frog
The last Azuma to run between Aberdeen and Inverness was on 5th February 2021, to recover 800112 which had been trapped at Aberdeen Clayhills for nearly a month following the collapse of a bridge parapet on the line to Dundee; it ran empty to Craigentinny. Prior to that, 800113 also ran empty from Aberdeen to Craigentinny via Inverness on 20th August 2020 due to the line closure after the Carmont crash.
Haywain
3 Feb 2013
Neither of those were running in service though, and I would guess those movements were achieved by having Scotrail* drivers act as pilots for the LNER driver.
*Or GBRF.
The Puddock
10 Jan 2023
Frog
*Or GBRF.
The 2021 run was a Newcastle driver with no route conductor as he signed the road. The 2020 one did, I think, require a route conductor.
I know you're using the word 'pilot' in the vernacular but a Pilot is a specific operating role in the Rule Book which doesn't apply here. The correct term is route conductor.
Haywain
3 Feb 2013
I knew pilot was wrong, but just couldn't bring the right term to mind!!
800001
24 Oct 2015
The last Azuma to run Inverness to Aberdeen across the top was this year, 2024,following flooding on the highland mainline.
The LNER driver was route conducted with a Scotrail driver.
The Puddock
10 Jan 2023
Frog
Oh, I totally missed that one! I try to keep a record of odd one-off workings like this in Scotland. Do you know the date, out of interest?
Cheshire Scot
24 Jul 2020
North East Cheshire
I believe Newcastle drivers ride pass between Inverness and Aberdeen (insufficient turnround time in Inverness so they work into one and back from the other with lodge in Inverness). Surprised the pass ride is not used as a route refresh to maintain knowledge.
The Puddock
10 Jan 2023
Frog
Not any more, it hasn't been the case for a while now (May 2023 if I remember correctly).
Morayshire
6 Feb 2019
Reported as being 66122 on 4D47 Inverness to Mossend containers. Failed around north end of Pitlochry / Blair Atholl area. Cause reported as brake issues (Real Time Trains) or seized axle. May be visible on Traksy? Info taken from the Scot-Rail Io.group.
The Puddock
10 Jan 2023
Frog
It's at Blair Atholl. The loco has a seized traction motor and requires a wheelskate. The plan is once the skate is fitted, to take it to Dunkeld and recess in the siding there.
northscots
30 Dec 2023
Inverness
Scotrail diverting passengers via Aberdeen. LNER normally use buses if they can get hold of them but you'd need to check with them what they have in place.
800001
24 Oct 2015
Driver who works up to Inverness lodges Inverness and then works back south form Inverness the following morning.
They no longer pass across between between Aberdeen and Inverness.
Cheshire Scot
24 Jul 2020
North East Cheshire
Thanks for the update, presumably they have an agreement for 'short rest' on the lodging turn. By the time they have been for fuel and wash plus prep time in the morning I assume the 'rest' will be circa 9 hours?
185143
3 Mar 2013
They do indeed. The agreement is 9 hours, I asked a driver this last week when he said he'd come up the night before
800001
24 Oct 2015
The unit stables in the station and no longer goes into depot for fuel, CET or water.
Haywain
3 Feb 2013
I don't know the details but I do know that a late arrival into Inverness can result in a late departure the following morning so that the driver has the correct rest time.
Mcr Warrior
8 Jan 2009
How did the sleeper get through this morning?
Presume the Northbound sleeper (to Inverness) did run via Blair Atholl this morning. But, how about last night's Southbound sleeper (from Inverness)? Did that run? If so, what route did it take between Inverness and Edinburgh?
The Puddock
10 Jan 2023
Frog
The Up (southbound) sleeper last night was diverted via Aberdeen and Dundee.
The failed locomotive was sitting on the Up line at Blair Atholl but occupying a track circuit that prevented the points being moved to allow Down direction (northbound) trains to run from the single line to the Down line. In order to run the Down sleeper via the booked route this morning, the points had to be manually pumped to the correct position and the protecting signal had to be passed at danger. This was ok for a single train but wouldn't be any use for the rest of the day because of the need for the Down line to be blocked while the wheelskate was fitted.
Trainguy34
29 Apr 2023
Kent
Looks to have ran, likely via Elgin and Aberdeen aswell as Inverkeithing and Dundee.
The Puddock
10 Jan 2023
Frog
66122 is being shunted into the sidings at Dunkeld just now, around 23 hours after it first failed. The first ScotRail service to run beyond Perth will be 1H21 15:07 Queen Street to Inverness.
Wow. I guess that's an advantage of them being bi-modes: they don't have to do 1,100+ miles without fuelling.
800001
24 Oct 2015
Normally works Harrogate to Kings Cross then to Inverness’s stables over night, then Inverness London, then I think it’s the Hull or Harrogate service works.
@43094 can advise better the diagram.
Thanks. The majority of that will be under the wires though. Would be struggling to do that with a HST, methinks. :)
800001
24 Oct 2015
Oh yes, definitely. But water, CET etc is still an issue as it operates for 2 full days
Haywain
3 Feb 2013
It was the Hull working in HST days, so I doubt that's changed.
For water, there are various stations where it can be tanked.
