I read that Crossrail could have up to 24 trains per hour capacity (I'm assuming this is in each direction, i.e. one train each way every 2.5mins) . Is there any other lines in the UK with a higher frequency of service?
There are approximately 40 departures each hour off-peak from Waterloo with eight lines in use. Seems a safe bet!
I guess here we'd have to first determine what a "line" is. Is it a set of tracks, no matter how many that is, in principal, earmarked for a certain operator or simply lines/tracks available from a station (thus the eight tracks from WAT). Or, like I'd rather see it, a "line" is a set of double track for bidirectional traffic like at:
London Underground's District / Circle Line from Gloucester Road - Tower Hill has trains every 2.5 min even off peak
or two "lines" for two twin tracks at:
Rush hour going into London on the Great Eastern is very frequent. I'm based at Romford and we get a train past every 3 or 4 mins for about an hour on the Mains. Crossrail will use this route too but on the Electrics (Slows). So it will be a train every 3ish mins on both lines. Mad!
In that case, per track, the LU candidate wins hands down. The verdict cannot be appealed.
This must be also a question of safety measures; at the LU, it is possible for drivers to actually see the preceding train at times and they often have to be "feathered" to a station by a set of signals that will reduce their speed until the preceding train has left the station. Surely, with that sort of congestion at the ole' Metropolitan District's twin track, without surefire safety in place (and also when incorporating the possibility of disruption to an even flow of trains) frequencies cannot be much improved if considerable train speeds are to be maintained...?
