- Joined
- 14 Jul 2011
- Messages
- 20,293
Well if they ever got around to building that line to Stockport you could just put in a curve where it leaves the Airport Line's route....
You need at least 3tph to Coventry, 2tph Stoke (fast), 2tph Trent Valley (semi-fast), 1tph Chester, 1tph Lake District (since HS2 won't stop at Lancaster/Oxenholme/Penrith/Carlisle).
Not a lot of room for additional commuter trains which will extensively eat paths.
Do we really need all of these? That might be what these destinations currently get, but do they need that level of service? It sounds to me like you're suggesting even post-HS2 we still won't have enough WCML capacity.
Could you not run some of those services pared up and splitting on route as needed, as you wouldn't need to run 3 lots of 12 coach trains to Coventry? Which would allow many of the above 9 services to be reduced into 5 or 6.
Why don't we rework the timetable so that the WCML south of Birmingham effectively has the same service pattern as it does now, only the express trains to destinations further north are now running on HS2 instead? The trains calling only at Coventry, Milton Keynes etc would instead start at Birmingham rather than Liverpool, Manchester, Glasgow, etc.Phillip Elliot said:Bingo, HS2 does not release train path capacity because it doesn't call at principal intermediate stations. We do need all those services unless you want people in these places to switch back to the their cars because the rail service is no longer convenient?
Perhaps we should be a high speed line to Bournemouth and let Southampton have a classic service of 1tph all stops....
When you look at the loadings then a 4-6 car unit is not sufficient. Splitting and joining units is best avoided particularly as it is introduces significant risk and further slows down services.
Why do you have a liverpool Lime street train at all?
The only place that loses out if the Liverpool train is cut entirely is Stafford (as Runcorn and Crewe can pick up both HS2 services).
You can easily add the Stafford stop onto the Chester service.
And why are you putting a through service from Euston to Glasgow on the classic line?
Surely such a through service woudl be better placed running to Birmingham since anyone going to London will change at Preston or Crewe for a HS2 service?
Additionally, cutting one stop out of the Birmingham stopping pattern makes little sense from a journey time standpoint (since journey times are no longer paramount) and doesn't really improve pathing, so a clockface half hourly service makes more sense IMO.
Personally I would think a service pattern similar to the below would work well at giving places like Stoke and Coventry reasonable frequency of 'fast' trains while still serving places further south of them on the WCML.
1tph Birmingham New Street, Birmingham International, Coventry, Rugby, Milton Keynes Central, London Euston
1tph Birmingham New Street, Birmingham International, Coventry, Milton Keynes Central, Watford Junction, London Euston
1thp Manchester Piccadilly, Stockport, Macclesfield, Stoke-on-Trent, Lichfield Trent Valley, Tamworth, Milton Keynes Central, London Euston
1thp Manchester Piccadilly, Stockport, Macclesfield, Stoke-on-Trent, Nuneaton, Milton Keynes Central, Watford Junction, London Euston
1tph Liverpool Lime Street, Liverpool South Parkway, Runcorn, or Chester, Crewe, Stafford, Lichfield Trent Valley, Tamworth, Rugby, Milton Keynes Central, London Euston
1tph Glasgow Central, Motherwell, Carlisle, Penrith or Oxenholme Lake District, Lancaster, Preston, Wigan North Western, Warrington Bank Quay, Crewe, Stafford, Nueaton, Milton Keneys Central, London Euston
Such a service pattern would give reasonable journey times from Coventry and Stoke while giving stations from the Trent Valley south faster and more frequent services to London. Such a service pattern would also give much improved links between stations south of the Trent Valley to destinations further north, which is not the case with the current WCML timetable.
Yes, but maintaining a Classic Liverpool train would essentially only benefit the flow 'Stafford-LIverpool' which I can't imagine is large enough to justify the path into London by itself.
They can't change at Crewe if they really want to make such a journey and we save a path that is literally doing nothing that isn't done better by a combination of the HS2 Liverpool services and an extra stop on the Chester service.
They're still won't be space for local trains to places like Tuxford if they're still Intercity services to Hull, Wakefield etc. If HS2 was about capacity then it would serve all the current key destinations.
There will be less trains moving about Birmingham New street post HS2 which means you should be able to handle additional Birmingham terminators, especially as many of them will probably not have to be 11x23m coaches long after the Pendos are gone.
From HS2 explanation of the service patterns (p7 & 8)
Predicted service pattern:
3tph Birmingham New Street, Birmingham International, Coventry
1tph Birmingham New Street, Marston Green, Birmingham International, Coventry
2tph Birmingham New Street, Birmingham International, Hampton-in-Arden, Berkswell, Tile Hill, Canley, Coventry
1tph Birmingham New Street, Marston Green, Birmingham International, Hampton-in-Arden, Berkswell, Tile Hill, Canley, Coventry
(also 2tph just between New Street and International)
I've omitted the stations outside of the Birmingham New Street to Coventry route but you get the idea, it's not a corridor that's going to be starved of service!
As you indicate, this anti HS2 movement is not exactly ' a peasants' revolt' is it?![]()
Why do we *need* at least those frequencies and speeds to be retained?
Take away the Manchester/ Birmingham (etc) passengers and would anyone really claim that Stoke/ Coventry justify those levels of service?
A lot of places get a good service at the moment because they are on a direct route between London and somewhere large further north - would Grantham get a couple of trains an hour to the capital were it not for the fact that trains from Leeds/ Newcastle pass through it?
Look at it from the opposite direction, can we justify running 3tph to Brum and Manchester currently if they didn't stop at Cov/Stoke/MK/Macclesfield etc.? They would be very empty trains...
And aren't we supposed to be thinking of patronage in 2033 and beyond? Quite why so many seem to think that Brum/Manc usage will boom and everywhere else will stagnate I don't know...
Exactly, with HS2, Birmingham and Manchester WILL boom and everywhere else WILL stagnate. It's a means to end.
Given the fact that the 'peasants' are paying for it and will be unlikely to take avantage of it, it is surprising that they aren't 'revolting', no?
There are lots of projects UK wide that my tax contributes to and that I won't take advantage of but I don't complain about it and neither should they
....a line of some form or another.
****city living.
Ahem, I think it's more about equity.
No, no idea what you're on about. Can you expand?
Fairness. Equitable distribution of taxpayers money so benefits are maximised amongst all groups, not just the wealthy.
I still can't tell if you're for or against it.
