- Joined
- 14 Jul 2011
- Messages
- 20,281
Expand the WCML where possible.
We did.
The WCML is full.
Tiny sticking plasters can't escape that.
Can you explain why Liverpool should suffer from having clapped out stock running on old lines just because London wants 15 minutes shaved off its commuter times at £20m+?
Treasury figures are within my range, see above.
I would spend small and focused. So £10m on five new stations, and then a controlled budget thereafter on focused areas across the network. I won't spend £80bn on a cross-fingered experiment.
I would spend money on new rolling stock. I would connect existing towns to the network. I won't spend money on a London-centric expressway.
We did.
The WCML is full.
What?
This statement doesn't even make sense.
Liverpool is not going to have clapped out stock running on old lines. (Indeed they will have new stock long before HS2 opens as the acquisition is already moving forwards).
And I don't know any journey that HS2 will reduce any journey times by 15 minutes.
40 minutes to Birmingham and an hour to Manchester.
Oh please, having HS2 or not is not going to make us the laughing stock, having a £40bn version of Ciudad Real, will make us a laughing stock. We are a small country, with a high population, and population densities and distributions that are not ideal for high speed rail.
The optimised alternative costs £2.062bn, so even if it overspends by a factor of 20 it's still below the current estimated cost of HS2, with a BCR of 5.17.
I think you are missing the point of what a BCR is. Having a larger or smaller BCR does not mean the benefits are the same, its the ratio of benefits to costs.
One question whos 25 year passenger figures are right, DfT, Network Rail or HS2? and which one are you most inclined to believe? ok we won't know for 25 years and you may as well throw darts at paper on a dart board, but to turn your statement round, if you can't show the capacity step change is needed over and above what can be cost effectively got out of the current network, there is no argument for HS2.
Maybe someone should build a mock up of a HS2 train and then put it alongside a recreated 390 interior (and to be fair, a non-tilting train) and let the public see what they could have, against what we currently have and always will have.
We can explore where and how to explore widening/exploring the WCML where possible.
A total of £73bn (Treasury figures) to put a line avoiding some of the largest towns and cities in the country, or the same to invest in new stations and extended lines where required?
Explain to us what the "optimised alternatives" are. If you are really serious about your objection you will know exactly how the alternatives can be built and what benefits they would provide and how they would be better value and provide bust as much capacity enhancement as HS2....
I totally agree with more lines to go east and west. Isn't there one already in the works from MK to Cambridge - effectively creating a link that spans most, if not all, of the mainlines.
I'd like some form of link from St Albans through to Hertford (connecting the MML to the ECML to the WAML) and can think of many others.
I would hope and expect that in the next 50 years, a lot of these things will be considered separate projects and won't be held back by HS2.
If I was an investor, I'd be looking at HS2 as a pretty safe, solid, project to fund. I wouldn't, sadly, see a lot of other things that will help people but not guarantee a good return, as being worthwhile.
Thus, the money that will be given for HS2 probably wouldn't be there for the other stuff anyway. It's not all public money for HS2 is it?
So £20m+ for 40 minutes? Or £20m+ to improve, say, lines into and out-of Birmingham ?
Liverpool is being left out of HS2, so whilst Manchester is given an hour bonus, Liverpool gets nothing, but tax payers still have to shell out thousands of pounds for it. So why should Liverpool suffer?
Why not - as I have suggested - put investment into east/west lines? Liverpool to Lincolnshire?
I have already suggested my alternatives.
I would look at focused, regional/hyper-regional expansion projects, rather than a national coin-toss. I would work on intelligent timetabling, for example, and as has been mentioned before by others, work on signalling to enable shorter distances between trains.
I would spend £10m on five new stations, and then use the same amount of money in another 5 or so years to do the same, helping to bring more people to connect with the train network (as HS2 disallows people to connect to the line they're paying for)
Liverpool IS being abandoned by HS2, because the focus is getting people from Manchester to London. It's not just or fair to do so, which is why I suspect Angela Eagle is using "north/south railway" rather than "HS2"
Right then is presume you are talking about ERTMS signalling? Do you know how much that costs? Do you know the infrastructure that is required for it? Do you know how much benefit it will actually provide? Clearly not.......
You could not build 5 new stations for £10m. Considering the average bridge costs around £2m. Like I said you really don't understand what you are talking about.
It was the original plan that it wouldn't be public money, I believe the plan is now to borrow the money
I understand that HS2 is a massive gamble, a poker game with the nation's finances. I understand that there is no justification, no need, no want, no reason, little support outside Westminster, for such an expensive coin-toss.
I understand that only rail enthusiasts seem to want it. I understand nobody can justify a multi-million expressway running from London to Birming....The West Midlands :roll::roll: - based on how commuters work NOW not in 30 years time. I understand that HS2 does not take into consideration the reduction in 9-5 office hours or the increase in at home working. I understand that you can't use HS2 unless you live in four or five arbitrarily chosen cities.
I understand that you can focus money into specific regional centres along both WC and EC lines, for far less disruption, with far less opposition.
If we had people like you around 50 years ago man would never of stepped foot on the moon......
Can I ask you where you propose putting the extra freight from Felixstowe? Or does all that go onto the roads? You really need to look at the bigger picture buddy its not just about transporting business men and women to and from London quicker.
If it wasn't transporting business men and women to and from London, why is that the only thing that Ministers and SoS have been using as justification? Why is not the same amount of money spent on, say, Glasgow/Edinburgh to Birmingham instead?
I know - and you know - why this white elephant is being directed to stomp over the gap between London and Brum.
I just hope that sense and reason comes to someone in the short-term. This country does not want, need, or can afford, HS2, and I hope it comes to an end before it's too late. It's that simple. HS2 is just not needed.
You're still saying £80bn, even after getting the adjusted-for-2033 figure and being shown how the £80bn figure is nonsense.
You're still saying 'white elephant'.
You're still talking about London-Birmingham as if HS2 is only to there.
You're now arguing about people in Liverpool losing out, when they aren't - they're gaining quite a lot (more than people to Birmingham it seems).
You're not coming up with properly thought out alternatives, and the small things you have said (like 5 stations for £10m, then 5 new stations every year) don't make sense.
And you still think I was out of order to say you were trolling?
I see HS2 as one of the best projects this country has ever taken on. It's shows we are being proactive in stopping a problem before it happens and not just reacting to it when its too late.
Plus how do you proposed "upgrading" the WCML and ECML without causing massive disruption?
So I can only not "troll" if I agree with you?
We're never going to agree. I'm not going to blow out or strop or flounce, but clearly nothing good will come from an anti-HS2 arguing with a cheerleader. You're looking at my answers and choosing to keep storming through with your own blinkered opinions - wonder what that's called?
