Help Please
SJN
20 Oct 2012
When I did my conductor assessments last year, I was told you can only have two goes at them.
jim8970
19 Nov 2013
United kingdom
Would the online test count as one as I done it for conductors position but did not meet the minimum points required?
Thanks for all comments!!!
455driver
10 May 2010
The online part does not count as a fail, it is a sort of pre-sellection process.
You get 2 goes at the assessments for drivers and 2 goes at the assessments for guards roles.
Monty
12 Jun 2012
As far as Guard's go it can vary from TOC to TOC. SWT for example will allow you sit the assessments more than twice while others will not. For driving however is two strikes and that's your lot.
455driver
10 May 2010
Some people (like me) think its better to get another job (pretty much any job) with a TOC to get on the ladder, then you will have access to the internal vacancy list plus you will be able to prove to the TOC that you are a good worker.
Other say its better to try and go for the job you want along with thousands of others straight away.
You pays your money and takes your choice.
