BanburyBlue
- Joined
- 18 May 2015
- Messages
- 878
Hi all
Calling electrical peeps out there.
We have a light fitting in our dining room (that Mrs BanburyBlue absolutely loves). Suddenly last evening it stopped working. I had a play this morning, and basically, the issue is with the light fitting.
I’m guessing the issue is with the transformer in the light fitting. Looking online, it looks like I can get something very similar. The only difference is that it says for halogen lamps 10 - 60 watts, whereas the fitting at home says 20-80watts. Is this a problem?
The light fitting has seven 10 watt bulbs, so when it says 10 - 60 watts, does this mean it is designed for any bulbs that are between 10 & 60 watts, or is it a sum of the individual bulbs - so 70 watts?
And what would be the impact of replacing the lower wattage transformer?
Thanks
Thanks
