HELP ME PLEASE!
yankee317
16 May 2008
Hey guys im having huge problems trying to put in the NYCT add-ons for BVE. I just downloaded BVE 4 and i have been trying to figure out how to get the routes and trains correctly put into the right places.I read that i had to convert the B3D files into CSV btu when i down load the converter it only shows "?????????&?????????????".I then tried dragging some files into the converter but nothing happens.Maybe im not putting the right files in the right place? or maybe im just not converting them correctly?At one point i eve downloaded BVE 2 and tried and it starts off by asking to select a train.I go to where i installed the train along with everything else (C:\Program Files\BVE\)and nothing happens?....someone please help me
guillyman
12 Sep 2007
South London
Hi yankee317! And welcome to the forums.
Maybe you could take a look here:
http://www.trainsimcentral.co.uk/phpBB3/viewtopic.php?f=2&t=1227
which usually answers all the questions which newbies are faced with!
Regarding your conversion tool, it shouldn't make any difference if the b3d files are left as they are, but the way the tool works is: drag a b3d file from its directory into the convertor's shortcut on the desktop.You will not see anything happen, but check at the end of the directory listing - a new file of the same name, but with a csv extension will have been created.
Hope that helps!
Al. :grin:
yankee317
16 May 2008
thank you so much.lmao that little you just told me justsolved all my problems lol.it just so happens that i wasnt installing the folders into the correct places.and you were right! the files didnt need to be converted they had them in csv format already i just didnt look carfully. thank you so much!!!!
