Heljan Class 33 Headcodes
DJ_K666
5 May 2009
Way too far north of 75A
If anyone has recently bought the new Heljan 33/1 as I have and noticed there are no headcode sheets, I have got hold of the font to make them up.
Problem is, what size to use? I'll probably use red blanks on one end and either 92, 99 or the ubiquitous 62 on the other.
Anyone know? Or if you could colour photocopy or scan a spare sheet that would be grand.
GearJammer
12 Nov 2009
On the Southern
Entirely up to you but why put numbers? I cut out the letters and had red headcodes one end and the good old EH at the other, you could put EH (Eastleigh), SL (Stewarts Lane) or whatever Southern region depot you fancy, also means you won't get no smart ass saying thats the wrong headcode for the train its pulling! :)
DJ_K666
5 May 2009
I could put letters, although for freight I'd more than likely just use white blanks. Problem is, I need the size to get it right. I might take a vernier to the ones already supplied (the new issue comes without the sheet and the codes pre-installed) to get the size then use the closest I can get the printer to put out...
O L Leigh
20 Jan 2006
In the cab with the paper
I found the headcodes for my Crompton tucked away inside the folds of the instruction sheets. Mind you, it was a very tiny piece of paper.
Couldn't you just contact Heljan and ask them for a sheet...?
O L Leigh
