Western 52
What is/were the heaviest vehicles to run on the UK railways? My guess would be the molten iron Torpedo cars used in steel works, which I've heard can weigh several hundred tons, but anything heavier?
In Port Talbot some of their torpedo cars weigh 600t fully laden - about 400t of molten steel. They are carried on four, three axle bogies. That's a 50t axle load. And they don't have any brakes!What is/were the heaviest vehicles to run on the UK railways? My guess would be the molten iron Torpedo cars used in steel works, which I've heard can weigh several hundred tons, but anything heavier?
The largest was the Boche Buster!There were a couple of huge railway guns, each had a 14 inch gun originally ordered for a Japanese battleship, but not delivered which were used about 1916-1918. They were known as BL14. They weighed about 250t,
One of them was subsequently used to mount a standard 18 inch gun (strictly a howitzer) and I think it was used in Kent in WW2
The heaviest to run on the national network will probably have been the Dounreay reactor pressure vessel and parts transporter wagon with 16 axles.What is/were the heaviest vehicles to run on the UK railways? My guess would be the molten iron Torpedo cars used in steel works, which I've heard can weigh several hundred tons, but anything heavier?
The one with the most people in surely.What is/were the heaviest vehicles to run on the UK railways?
In the 1970s a number of molten steel carrying torpedo wagons were built to operate on BR lines when part of the steelworks where the steel was produced by the blast furnace was closed for some work and the molten steel had to be moved to another location. These weighed about 250 Tonnes had 4 bogies and were a similar design to the ones at Scunthorpe and Port Talbot. I believe these are the heaviest vehicles to operate in Britain.
They also used to operate at times in North Lincolnshire from Appleby Frodingham works through to Normanby Park works, most of the journey was on the works railway execpt one section between Crosby Mines Signal Box and Normanby Park South Signal Box on B.R. tracks. The trains was also operated by the steelworks loco,s who also ran over this same section of line with ore trains from the ironstone mines to the steelworks.Cargo Fleet to Consett.
Molten Metal Trains
In August 1969, British Steel Corporation (BSC) introduced a daily service of trains to carry molten iron the sixty three miles from the Cargo Fleet Works in Middlesbrough to the steelworks in Cons…southpelawjunction.co.uk
I think you mean the wagon built by Head Wrightson which carries a spent fuel flask and can have its rail bogies replaced at Thurso with road bogies for the trip from Thurso station to Dounreay.The heaviest to run on the national network will probably have been the Dounreay reactor pressure vessel and parts transporter wagon with 16 axles.
No bridges where it operated loaded so minimal clearance issues.
According to Wikipedia a class 67 has a weight of 88-90 tonnes/87-89 long tons, so will have an axle weight considerably above 20t across it‘s four axles. Presumably that 20t limit hasn’t existed for at least two decades.Last I heard UK national railways have a 20 ton axle limit. The locomotive with the most axles is 6 currently. So the heaviest vehicle (if talking locomotives) would be less than 120 tons.
The class 46 was the heaviest diesel loco at 138 tons with 8 axles. From recollection they were all withdrawn in the 80's. The nuclear flask test of 1984 at Old Dalby had a class 46 designated for the purpose of the crash because of its weight and immiment withdrawal.
I believe Steam Engines (if including the tender) are heavier and still run on the railways regularly. So on the national network, its going to be one of the steam locos.
If you also lookup Route Availability on that source, you will see RA10, Network Rail maximum axle load for permitted routes is in excess of 25 tonnes .According to Wikipedia a class 67 has a weight of 88-90 tonnes/87-89 long tons, so will have an axle weight considerably above 20t across it‘s four axles. Presumably that 20t limit hasn’t existed for at least two decades.
For many years, the maximum axle loading on UK railways has been 25 old fashioned TONS, which are of course heavier than those new fangled metric ones!If you also lookup Route Availability on that source, you will see RA10, Network Rail maximum axle load for permitted routes is in excess of 25 tonnes .
https://en.wikipedia.org/wiki/Route_availability#Line_calculations
Although not massively- 25 imperial tons is 25.4 tonnes (and 28 US tons)For many years, the maximum axle loading on UK railways has been 25 old fashioned TONS, which are of course heavier than those new fangled metric ones!
The British Army had two 14 inch guns on railway mountings in WW1, as described - HMGs (His Majesty's Guns) Boche-Buster and Scene-Shifter. The 14 inch guns (being non-standard in British service) were declared obsolete in 1926: while the guns themselves were scrapped, the mountings remained.There were a couple of huge railway guns, each had a 14 inch gun originally ordered for a Japanese battleship, but not delivered which were used about 1916-1918. They were known as BL14. They weighed about 250t,
Yep, I was going to say the same. 185s must surely be the heaviest passenger vehicles, unless the voyagers beat them to that record.Is the question what was the heaviest railway vehicle ever or what is the heaviest vehicle currently running on the British network? I was expecting 185s to be mentioned.
Nope.Yep, I was going to say the same. 185s must surely be the heaviest passenger vehicles, unless the voyagers beat them to that record.
Fascinating! Having lived in London all my life, where industry is -- or rather was, as I doubt if much is manufactured here these days -- pretty much all light, the wonders of heavy industry never cease to amaze me.Cargo Fleet to Consett.
Molten Metal Trains
there was of course the (originally Vickers, later MoD) rail connected range at Eskmeals (south of Ravenglass) used for testing naval guns going into ships being built at BarrowA few years back a mystery photo appeared on the Cumbrian Railways site, asking for help identifying an absolutely massive gun (presumably naval) on rail wagons. ... Gun number 1 was used at Silloth
thanks, I didn't know thatthere was of course the (originally Vickers, later MoD) rail connected range at Eskmeals (south of Ravenglass) used for testing naval guns going into ships being built at Barrow
