Heaton Chapel on Sundays
Does anyone know why Heaton Chapel has such a random Sunday service? It seems to be made up of calls on all manner of random services to/from random destinations with some very long gaps (about 3 hours over lunch for instance), yet these are services which mostly run hourly or two hourly clockface or very close to it.
Why doesn't it just have an hourly or even two hourly call in one of the services?
I would have thought that it would be harder to path such a random service, not easier.
ReturnToSPT
1 Nov 2023
Heaton Chapel
Would love to know the reasoning for this. Surely less traffic on the network on a Sunday too so should be easy to get eg the Crewe service to call every house as in the week? Makes the whole area car dependent on Sundays as huge gaps in service. Same for levenshulme.
Mcr Warrior
8 Jan 2009
I'd certainly agree that the service intervals in the Manchester Piccadilly direction (which is where all Northbound trains calling at Heaton Chapel will be headed) are somewhat random on a Sunday, including a couple of calls from trains originating at Chester.
Makes the service provision at Heaton Chapel on a Sunday almost seem like an afterthought!
In the other direction, however, it's an hourly service by trains which call at Heaton Chapel on Sundays (then Stockport and most/all stations to Buxton) at broadly clockface times between 0859 and 2259, albeit nothing calling at or around 0959, as, for some reason, that particular Buxton train runs fast through Heaton Chapel.
I'd certainly agree that the service intervals in the Manchester Piccadilly direction (which is where all Northbound trains calling at Heaton Chapel will be headed) are somewhat random on a Sunday, including a couple of calls from trains originating at Chester. Makes the service provision at Heaton Chapel on a Sunday seem like an afterthought!
In the other direction, however, it's an hourly service by trains which call at Heaton Chapel on Sundays (then Stockport and most/all stations to Buxton) at broadly clockface times between 0859 and 2259, albeit nothing calling at or around 0959, as that particular Buxton train runs fast through Heaton Chapel.
That is utterly bizarre. 14 trains southbound, near enough hourly except the missing one, only 8 northbound with several long gaps, made up of one Buxton, one Macclesfield, two Crewes, five Stokes and two Chester via Altrincham.
On a weekday the Buxton always (or nearly always) calls, so why can't it be the same on a Sunday? The main constraint on paths is presumably the 3tph Avanti, and that's the same every day.
Most notably it lacks a "just after lunch" train to go Sunday shopping, which seems to be throwing traffic away. 1422 is a bit late for that, you'd want about 1300-1330.
Mind you out of the services it involves, it's only the Buxton that is anything like clockface, the other ones are rather random.
jonnyfan
6 Apr 2013
Manchester
The Sunday timetable needs a good re-write, just like they did with the Mon-Sat timetable which gives a pretty much clockface timetable all day.
On Sundays the Buxton's interwork with the Chester's, which gives some trains limited turnaround times at Piccadilly. Also the Crewe line uses only 2 units on a Sunday, so turnarounds are very tight (only 4 minutes at Piccadilly) so calls at Levenshulme and Heaton Chapel just aren't possible.
If they re-did the timetable and diagramming for the Buxton and Chester services, I reckon you can easily get the Buxton's to serve both stations every hour, in both directions.
That missing 0959 is probably a fair annoyance too, as anyone wanting to go for a walk in the Peak would presumably aim for the 0859, but in the likely event of that being cancelled (well, it is Northern) that's your day out ruined.
At least it's not as much a mess as it would have been had that hair-brained scheme to change to paired by speed from the present paired by direction layout gone ahead. That would have meant Levvy and HC calls on the fast line in one direction, and thus a very odd service pattern.
Another constraint is the mess of different line blockages between Piccadilly and Slade Lane Jn on Sunday mornings.
These are to allow for track inspections, which are obviously important and need to be done at some point. But rather than having them at a consistent time year round or, perish the thought, having them during the night with good lighting, they vary by lettered timetable period (4-8 week subdivisions of the timetable) depending on daylight hours.
With Slade Lane Jn and the Piccadilly throat being single lead constraints for many moves (e.g. trains to/from the Styal line that need to cross to/from the Fast lines), and lots of irregularly timed ECS moves off Longsight, this makes it near impossible to produce a clockface timetable.
Add on the desire of TOCs such as Northern to run a reduced timetable because they still don't have Sunday in the working week on the west side, and this is the outcome. Something has to give and unfortunately it's the local stations to the south of Manchester.
hexagon789
2 Sep 2016
Ironically, OTT gives the 0859 a 100% for running reliability for the past 12 weeks, albeit late running 60% of the time.
I was curious! ;)
jfollows
26 Feb 2011
Wilmslow
The full "proposal" shown in https://www.railforums.co.uk/threads/manchester-south-remodelling-proposals-historical.241695/ had four platforms at Levenshulme and Heaton Chapel.
ReturnToSPT
1 Nov 2023
Heaton Chapel
Wonder if anyone knows of any plans to rectify this in any upcoming timetable changes? As suggested by @jonnyfan stops by every Buxton train should be possible without too much disruption.
Jamesrob637
12 Aug 2016
Very bizarre. Even Davenport and Woodsmoor see a train every hour in both directions on a Sunday.
Mcr Warrior
8 Jan 2009
Aren't they invariably always served by Buxton trains, which, at most times of the day, seem to run fast through both Heaton Chapel and Levenshulme inbound to Manchester Piccadilly on Sundays?
Think that there are something like 14 direct services calling at Heaton Chapel, Davenport and Woodsmoor on a Sunday (all continuing to Buxton) but only 1 doing both in the Manchester direction.
Jamesrob637
12 Aug 2016
Only the first train of the day from Buxton calls at Heaton Chapel and Levenshulme.
Starmill
18 May 2012
Bolton
It could be worse. Levenshulme and Heaton Chapel could have the same service as Bramhall. Or Fairfield.
And Gorton has two. Which is twice what it has Monday - Saturday.
The answer to this is that it did in December 2017 and prior, because there was 1tph Alderley Edge to Manchester Piccadilly, half of which continued to and from Crewe. In May 2018 the service from Crewe was increased to hourly, which was achieved only by binning the calls at Levenshulme and Heaton Chapel.
It may be possible to restore some of the calls by removing them at Chelford and Goostrey, but for political reasons that probably won't happen.
Jamesrob637
12 Aug 2016
Call at one of Goostrey or Chelford, and one of Heaton Chapel or Levenshulme. Heaton Chapel best as Levenshulme is a bit more pleasant on the bus (not as far into Manchester or back)
Sorted.
Jamesrob637
12 Aug 2016
It does seem odd when you consider just how much goes through.
Not sure how well you know the area. However, those who live at the bottom of what is collectively known as the "Four Heatons" can walk to Stockport in the same time as they can walk to Heaton Chapel from where at least there are many trains to and from Manchester, even on a Sunday.
It is however quite a well off area, which means they won't, they'll go by car.
Starmill
18 May 2012
Bolton
Erm, Levenshulme and Heaton Chapel are two of the busiest commuter stations in the county?
323235
8 Dec 2007
North East Cheshire
This all stems from the 2018 timetable mess as Heaton Chapel and Levenshume used to have a regular Sunday service in both directions prior to this. I did raise the issue with our Stockport MP.
ayubdaud
11 Mar 2020
Bolton
I am led to believe that the gaps in calling pattern will be addressed in the June timetable.
Jamesrob637
12 Aug 2016
With the ex-Buxton, ex-Crewe or both? The service towards Stockport (and Buxton) is adequate, but the 09:49 from Piccadilly really needs to plus the 2-hour morning gap, otherwise it's fine.
scrapy
15 Dec 2008
Yes think there was 2tph on a Sunday at Heaton Chapel and Levenshulme pre 2018. The Buxton services called as did the Alderley Edge/Crewe services. (Only 1tp2 hours continued to Crewe on Sundays pre 2018)
ayubdaud
11 Mar 2020
Bolton
From Piccadilly it is 2B02 presumably to fit the pattern. The other way I think is the Crewe train but really could be anything.
tomoufc
12 Dec 2014
Both Heaton Chapel and Levenshulme should have at least 4tph each day. The Sunday service is a disgrace, making the railways effectively unusable for most purposes. Coming up from the South on a Sunday I more often than not have to change for a 192 bus at Stockport. A half hourly clockface timetable would effectively re-open many longer distance journeys that were far more effective prior to the Covid cuts.
