Heating duct smell (West coast route)
9 Dec 2012
Back in the day with the mk3 stock on West Coast I always remember that random strong rubber burning smell that would randomly infiltrate the carriages , What was the reason for this? Up there with the stinky pendolino toilet smell!
Brake linings. There was a design flaw in the Mk3 that put the air intake too near the brakes. There was a design change later that closed the intakes if the brakes were on, but you still got it.
Mag_seven
1 Sep 2014
here to eternity
The only smell as such that I can remember was when the train braked too sharply and you got the smell of burning brake blocks.
randyrippley
21 Feb 2016
ABS disk brake pads
There was a rumour that they were originally asbestos and had to be rapidly replaced when it was realised dust was entering the cabin from them.
If I remember correctly the supposed design flaw was intentional in that hot air from the brakes was deliberately routed to the cabin as a free source of heat. But no-one thought through the dust and fumes issue
Grumpy Git
13 Oct 2019
ABS disk brake pads
The "black" faces of 50s/60s racing drivers was due mainly to brake dust
hexagon789
2 Sep 2016
They did originally contain asbestos, they were changed to non-absbestos ones at the same time as many other modifications were made to the braking system.
hexagon789
2 Sep 2016
As I understand it if, as recommended in the braking instructions, an initial brake application was made to commence retardation of the train this was sufficient to close the vents and then a heavier brake application as required little or no smell would be evident as the vents would be closed before the heavier application was made.
Presumably many drivers just stuck the brake straight in though, or the vent mechanism wasn't always reliable at closing to atmosphere under brake applications.
Sad Sprinter
5 Jun 2017
Way on down South London town
Isn't this the "Tube" smell as well?
No it's definitely the smell the OP mentions, I remember them strongly on childhood runs on 125s when the trains would break sharply before Didcot-or at a signal check somewhere in the middle of a field in Whiltshire. Always hated that smell. On the Northern Line, I notice you tend to smell it most northbound at Stockwell. I wonder if its got something to do with the strange hump in the rails the train goes over just before braking into the station.
Trackman
28 Feb 2013
Lewisham
It was one of the Living Carpets for those who saw the original series of Vic Reeve's Big Night out. Sadly there is not a you tube clip. It went something like 'You know that horrible burning smell on a train? Well that's me that is'
coppercapped
13 Sep 2015
Reading
ABS disk brake pads
As I understood it at the time the air intakes were placed low down to avoid sucking in diesel engine exhaust fumes which tend to attach to the air flow along the top of the trains when moving at speed.
It seemed to me to be the right call - a bit of a pong every so often instead of having trainloads of carbon monoxide poisoned passengers.
DLJ
13 Mar 2017
That's how I remember it - 'Anchors on' at Didcot East, always.
