StephenHunter
Assuming this is built, would it be possible to run IETs into there? I am thinking that you could do Heathrow to Cardiff and other destinations on a through ticketing arrangement.
Possibly because there are no flights from Bristol to Johannesburg?If the start or destination is Cardiff, why not fly from Bristol...? It's closer.
I can’t believe Reading XC would ever happen while they’re still running diesels.Beyond Reading, potential options discussed informally have included trains coming off East West Rail and extending what was the Reading CrossCountry terminators.
So? There also are no flights from Heathrow to Venice.Possibly because there are no flights from Bristol to Johannesburg?
BA fly multiple flights every day to Venice... but that's irrelevant. There are no long haul flights from anywhere in southern England except Heathrow/Gatwick, so people have no choice but to go via them... or they use KLM or similar to interchange somewhere elseSo? There also are no flights from Heathrow to Venice.
I agree, there's no way it would ever make sense to send long distance trains to Heathrow. GWR don't even make much of the connection possibilities, so I assume they don't think it's much of a market eitherOdd about the flights to Venice - my Skyscanner fu can't be very strong today...
Even if there is no choice apart from Heathrow or Gatwick for long haul flights, the fact remains that total flows to Heathrow for long distance flights are not sufficient to make it worthwhile to route prime fast services to and from London via Heathrow as the additional time would make the end-to-end journey less competitive.
I would suggest that extending Crossrail or HEx services west of Heathrow on a fifteen or twenty minute frequency to Reading to make connections there to 'all over the place' and serving at least Slough and Maidenhead on the way would be the way forward.
Anyway, I have the feeling that this has all been discussed in earlier threads.
You can already buy through tickets from Heathrow to Cardiff, the two fastest choices would be via either Paddington or (pre-Covid) the Railair coach link via Reading.
To the first part of your question, yes IETs would physically fit the route but would be unable to use the lines east of the Airport to Airport Junction as they are not yet fitted with the ETCS signalling equipment used in the tunnels.
Even if the Western Access were to be built it is very unlikely that fast services to Cardiff (or indeed anywhere else west of Reading) would routed through Heathrow because of the increase in end-to-end (e.g., Cardiff-Paddington) journey times. The service offered would most likely be a through suburban service to Slough, Maidenhead, Twyford and Reading as these areas have inadequate public transport connections to Heathrow. There is a small but finite chance that some services could be extended to Oxford or Newbury but no destinations further away could support a train frequency that would be competitive. If you have to wait for an hour for a train a car could get you past Swindon...
I'd trial an hourly fast line call at Hayes and Harlington for a semi-fast GW service. Obviously it would be pick up only westbound, set down only eastbound.
Very easy cross-platform interchange onto a Heathrow bound Crossrail train for those traveling from the Thames Valley and further west.
Increased Heathrow rail connectivity for the Thames Valley for free, what more could you want?
I believe that the poster is suggesting this to demonstrate viability of the proposal by using the existing eastern access link and rail services.Hayes is on the wrong side of any Western access link.
That's correct. I've also edited my previous post for clarification.I believe that the poster is suggesting this to demonstrate viability of the proposal by using the existing eastern access link and rail services.
It doesn't need to be an advertised stop on the departure boards at Paddington. Being pick up only westbound/set down only eastbound at Hayes & Harlington should stop it from being used as an alternative to HEx.Ah I see. I don’t think Heathrow Express will want any reduction in the time saving given they’ve already got a competitor that doesn’t take much longer, is substantially cheaper and will in the near future offer much better connections in the form of TfL Rail / Elizabeth line.
Otherwise I’m not sure there’s a huge benefit - there’s already the GWR Didcot service, the second stop of which is Hayes.
It would be a faster and easier connection from Reading, Oxford and further west without any need for extra infrastructure.
It's not an idea for the benefit of those coming from London - they already have HEx and TfL Rail, but those traveling to Heathrow from the west.
There's a clear risk of delayed train departures from Hayes and Harlington due to passengers with lots of luggage, so an infrequent service would be a sensible starting point for a trial.Ah sorry totally mis-understood what you were saying. Okay I understand that slightly more although it would be irregular so you’d have to pick one service group and put it on that. Everyone else would need to change at Paddington or Reading anyway which somewhat defeats the point.
Good question. It's a pretty straight shot along the M4 so I'd think the coach would win. If there was a faster service to Hayes, perhaps another scenario - but any service calling at Hayes would also call at Maidenhead and Slough minimum (Twyford too most likely) so I can't see it.Will Reading-Old Oak Common (OOC)-Heathrow T5 be faster than the Reading-Heathrow Airlink. I assume that an OOC interchange would be better than Reading because train frequency will be so much higher.
