Heathrow third runway
Kevin51
12 Dec 2019
Herts
What is this to do with railways you ask. Well it is the fact that the Colnbrook branch runs right across the third runway foot print. I am guessing a lot of excavated material will need to be removed and a lot of construction material brought in. Is the branch current used, a map shows a number of industrial units that will have to be moved, are they rail connected?
My guess is Heathrow wanting to promote being a good neighbour will use the branch, may be the only reason it still exists. Looking at a map I am guessing after coming under the M25/M4 junction the line could swing due west with a terminal parallel to the M4 and the new runway. Has anybody seen what is planned?
