Yes I do agree it’s not viable to have Elizabeth Line trains go as far as Woking. Ideally it would be a shuttle between Heathrow and Woking/Weybridge
Thank you
@kevin_roche
Note that the BBC report
https://www.bbc.co.uk/news/uk-england-london-66716733 states the following:
"The line would enable trains to operate between Heathrow and Waterloo via Clapham Junction, Putney, Hounslow, Twickenham, Richmond, Staines and other intermediate stations.
A second branch has been proposed to run from the airport to Virginia Water, enabling services out towards Surrey, Berkshire and Hampshire."
The link from Heathrow to Staines I know has long been a plan of many people to see be built, which is why I thought that would be more of a priority with it going to London Waterloo, than any route serving either Woking or Virgina Water. In the long run you would have a connection from Reading to Heathrow, whether that is at Langley on the GWML or whether it is at Staines on the Reading - London Waterloo route or possibly both, who knows. But I do agree with
@JN114 comment below that you really need both routes:
The airport itself wants Western access towards Slough and Reading, as that serves a greater portion of workers who currently travel in by car.
So build both schemes, it shouldn’t be one or other. There’s significant savings to be had by doing both at once.
Of the 4tph HEx, let 2tph continue to each of Reading and Woking in lieu of the railair coaches; with maybe a couple of stops in each (Slough/Maidenhead, and Staines/Chertsey perhaps)
The 2tph Elizabeth line via T5 extend to Maidenhead all stations.
TfL (as the Mayor is so keen) then introduce a new 4tph Terminal 5 to Waterloo semi-fast service, perhaps 2 via Richmond and 2 via Hounslow.
With a 4 platform T5 using the theoretical layout that was baked into the original station design, the northern half of which was what was fitted out, you can easily have 6tph through the outer platforms with 4tph reversing in the centre pair of platforms.
If both routes where built I would leave Heathrow Express on the GWML, but extend it from through Heaathrow to Reading.
But I would have two other services as per the map that
@chris2 has provided with one that goes to Wokingham, Bracknell, Heathrow T5, Heathrow T2 & T3 and then completes it's journey to Old Oak Common having come from Reading and another service that comes from Guildford that stops Woking, Heathrow T5, Heathrow T2 & T3, Old Oak Common and then goes on into London Paddington.
