Has the North been given a raw deal
Domh245
6 Apr 2013
nowhere
But stadler will be building ~half of the new vehicles for the franchise. The Tri mode flirts will likely be built at Bussnang or their Eastern European plants, whilst the tram trains could likely be built at the former vossloh plant at Valencia (which is where the other city links were built). As far as I can tell, all of the CAF DMUs will be built in Wales based on the "50% Welsh built fleet" claim.
Also, given that the Pacers are mainly based on valley line services - which are being entirely replaced by the tram trains and tri-modes, they should be amply covered. The DMUs are primarily replacing the medium and long distance fleets (ie 158, 175, and some proportion of the 150 & 153s)
northwichcat
23 Jan 2009
Northwich
I think the negatives of introducing an additional unit type to the fleet (175) would be outweighed by the benefits of having just one unit type based at Heaton (175) as opposed to the current two (142 and 156), and the benefits of having all of the 156s at Newton Heath. Coradia units were until recently maintained at Heaton (GC's 180s), so there's already a good amount of maintenance knowledge there that could be applied to maintaining the 175s. From a maintenance point of view I think introducing the 175s in the North East and moving the 156s to the North West in turn would actually be more efficient than keeping the current arrangements.
According to one poster on another forum there's very little in common between the 175s and 180s from a maintenance point of view.
47802
6 Mar 2010
Look I'm a Northerner and I thought the previous franchise was a National disgrace, however aside from the current timetable shambles I am happy enough with what's planned ie end of Railbuses, some new stock, cascaded 170's, Electrification of Manchester Blackpool if Network Rail ever finish it, and a number of sparse routes getting better services.
150 are not great but they aren't that bad either good enough for relatively short journeys, the refurbishment of them well its not great but just about adequate and the end of the day you are tarting up a 30 year old train for probably another 7 to 10 years usage.
And has already been pointed out by myself and others the Welsh franchise is much longer
Bornin1980s
4 Apr 2017
I was referring only to the Northern franchise. I only mentioned Wales because of the new CAF plant there, which might have a part in the last of the new Northern trains.
Andyh82
19 May 2014
Based on timescales from franchise announcement to new trains actually entering service, you’d be looking at at least 2028 before any new trains arrived as part of the next franchise.
Many parts of the Northern network, including lots of fairly long distance commuter services won’t see anything but a class 150 for the next 10 years, even refurbished they are still old trains, they look old, they sound old, the ancient looking metal windows with the hoppers, the doors, the general feel of the interior.
It won’t be long after Pacers go when people say hold on a minute, we were told in the press releases we were getting new trains, we’ve actually got trains just as old, and the sprinters will be the next hated train.
Class 158s are ok, as they look modern.
Whether the current franchise can afford it or not, I can’t see a situation where modern stock 156 and above from Anglia, West Midlands, Wales is off lease will be politically acceptable, so will presumably all migrate to Northern eventually by default.
matacaster
19 Jan 2013
Huddersfield
Could some of the spare 185's be used by Northern on S&C where their considerable power and 90mph capability lead to a much better product on the S&C, with improved journey times and passenger comfort. This assumes NR finally get their finger out and re-signal etc S&C for 90mph running.
Agent_Squash
22 Jul 2016
Surely it would be better off using them on a route which is capable of 100mph running? I personally think they should go to the Northern routes they were on previously (excluding Blackpool for obvious reasons)
superkev
1 Mar 2015
west yorkshire
Northern has very little track that's faster than 75mph let alone 100. The recently resignalled Blackpool line to just 75mph is a disgrace.
The 185's would be ideal for the Calder valley which has 5 or 6 miles of 90mph.
185's nice too for the s and c particularly if the fast line speeds could be restored.
K
lejog
27 Feb 2015
K
Except that 185s are limited to 70mph on tbe 90mph strdtches of the Calder Valley.
Agent_Squash
22 Jul 2016
K
What about the Furness/Lakes services, with over 70 miles of 100mph running?
Apart from being 30 plus years old, outdated and no longer fit for purpose ?
They have doors at thirds and lots of seats. Other than the desire for electrification (which gives you a Class 319, which is basically a 4-car electric version of the same thing) in what way aren't they fit for purpose, where the purpose is commuter trains and rural branches?
I agree they're a bit old, but that doesn't make them not fit for purpose. all that means is that people will want to replace them with something nicer and newer.
DarloRich
Fenny Stratford
True. FWIW I think the LM refurb is reasonably OK, it basically puts them "back to box" but with modern interior styling.
I disagree - they needed new seats. Wont be our problem soon anyway ;)
PS i don't understand the issues with a 150 - living as I did in Darlo for many the years the vast majority of our local services were worked by pacers. A 150 is like a place by comparison!
DarloRich
Fenny Stratford
So the seats aren't "fit for purpose"...ie, sitting on. Thanks for confirming !
As i said - nothing a decent refurb wouldn't fix. That is a long way from not fit for purpose. But i think you knew that............
BTW there is nothing wrong with the seats other than they are in 3+2 layout that i don't like. They are perfectly usable.
Jamesrob637
12 Aug 2016
I went yesterday New Mills Central-Sheffield and return (in addition to a whole load of other trains in Derbyshire). Was a Pacer out and a 150 return. Give me a 150 any day! The 150 I had was newly refurbished but even an unrefurbished unit would've been a massive improvement.
Oh and whilst this probably isn't the correct thread, the 20:14 from Sheffield to Manchester being skip-stop is good if it's a little late out of Sheffield. We were 5 or 6 down out of Sheffield due to the incoming service having been delayed, but we were more or less right time by New Mills!
30 Apr 2018
The Moor That Is Low
As a Calder Valley commuter who finds himself on Pacers & 150s almost continuously I find myself in the somewhat self-contradictory position of agreeing with everyone above about 150s.
Yes, 150s will get some flak for being old, unless Northern can refurb them before the Pacers go. Even then, they're a stop-gap for 7-10 years.
Next franchise period will see to their replacement (and the 155/156s?)
They're massively better than a Pacer. Anyone who defends a Pacer still being in regular revenue service in 2018 needs to spend more time on them.
The seats on a 150 aren't great. They'll do for now. See my above about refurbs - attention will always be directed to the oldest rolling stock a TOC uses. If they can refurb almost all before they become the bearers of that epithet, it'll be fine.
If we want better, we'll have to pay for it in fares. Not happening. Northerners' reputation for being tight is deserved. :)
That being said, new trains would increase ridership, especially into Leeds where the road traffic is horrendous and there's no trams. I remember the Airedale line going from Pacers to 308s to 333s. Capacity increases caused ridership to increase to the extent that the 333s needed extending from 3-4 cars. They've needed extending again for about 10 years now.
If only the DfT would see that increasing ridership on these commuter services would make them (more?) profitable and could reduce the subsidy required for Northern. Would probably pay for itself over the life of a franchise.
47802
6 Mar 2010
The point is much of the investment in rolling stock for Northern we have yet to see, and things should change in a big way in that respect in the next 12 months, and the whole point of the improved timetable and some new trains is to see a reduction in the subsidy of the franchise, although whether there will be any passengers left to try these new trains the ways are going with the timetable shambles and ongoing strikes remains to be seen, the railway as a whole is managing to do a good job at driving people away at present but obviously those issues are being debated elsewhere.
Also by the time the Welsh franchise has got a lot of their new trains it will be time to start looking at the next Northern Franchise anyway.
30 Apr 2018
True. I very nearly confused Northern and the DfT with competent organisations there.
XC victim
16 Dec 2015
what is wrong with a 150?
Personally I much prefer to travel on a pacer than a class 150.
I find the class 150 seats are absolutely terrible, too low and usually broken. For some reason the windows are always dirty and hard to see out of and you simultaneously get blasted with hot and cold air, which always makes me feel quite ill. The 3 + 2 seating always ends up being used as 2 + 1. I was really disappointed with them when I first travelled on them 30years ago, and they have pretty much remained unaltered.
The refurbished 144 have nice seats and a lovely window view. It maybe a bit of a bumpy (& screechy) ride but I can live with that.
DarloRich
Fenny Stratford
to repeat: A decent internal refurb fixes this point.
XC victim
16 Dec 2015
From what I have read there are no plans to replace seats or windows. I am not sure whether they are going to work on the heating either so I am really not holding my breath.
Andyh82
19 May 2014
Really?
A class 144 or an ex-ATN class 150 with the low down black seats where almost everything is exactly as built by BR with just a layer of paint on the refurbished ones.
I think with those two options I’d take the pacer
If they are such a robust train perfect for short length commuting, why are Great Northern getting rid of the 313s, internally it’s basically the same train.
underbank
26 Jan 2013
North West England
"Short length commuting" - shame they're used on the long/slow Cumbria coast, S&C and Bentham lines where journeys can easily be 2-3 hours!
