Handbrakes on DMUs
Ken H
11 Nov 2018
N Yorks
The other week I caught a train from Bingley to Leeds. It was a 158. At leeds it went to an empty low numbered bay. As we got off (it was very full) the engines stopped, i assume by the driver.
We know that air braked trains can slowly lose braking power when the compressors are not working, so:-
Will the driver have applied the handbrake in the cab he had been driving in?
If he did, how would the next driver know to release it? Would he have to start the engines and get brake pressure up before releasing the handbrake? So some duries to perform in the rear cab before he can go to the front cab?
Are the low numbered platforms at leeds level? Are there different regs for sloping platforms?
Tynwald
18 Mar 2016
158 have automatic parkbrakes. As do pretty well all trains now. Only old heritage trains like class 37/47 do not have them.
driver9000
13 Jan 2008
No. The parking brake applies automatically as the main air pressure drops. The main air holds the spring off so it's a fail safe device.
1 Dec 2017
The loss of air pressure you allude to releases a spring that applies the brakes. As such, air pressure is what is preventing said spring from applying them. In reverse, on restarting the engines the raising air pressure will ease off the spring and at the same time be supplying the brake cylinders. That is why upon restarting the engines if main and brake air is particularly low it is prudent to ensure brake cylinder pressure is climbing to ensure the parking brake isn’t “blown off” (yes, I know!) prior to sufficient air holding the service brake on.
In terms of the engines on a 158, normally it would be expected that they would continue running even once shut down as the air conditioning is run down. The fact this didn’t happen in this case means the air con either wasn’t running or the driver bypassed the shut down delay for whatever reason.
Regs are no different whether level gradient or not, a train is simply not left without a parking brake applied or if a method for this to occur automatically isn’t in place.
Efini92
14 Dec 2016
Leeds drivers always do that, it’s no wonder the air con never works on the northern 158’s.
dk1
2 Oct 2009
East Anglia
Parking brake needed to be applied on 153s but thankfully anything to do with those dreaded units are long done for me now.
driver9000
13 Jan 2008
Never had to apply the parking brake when I signed 153s as they had been modified by the time I learned them. I know the parking had to be applied once over to prevent them wandering off on their own though.
dk1
2 Oct 2009
East Anglia
Always had to on our fleet if left for any length of time. PA handset would be wound round the brake controller as a reminder.
Ashley Hill
8 Dec 2019
The West Country
Yes, I remember many cab/cab calls from drivers following a very slow departure asking to release them. As mentioned above they were later modified.
driverd
29 Mar 2021
Doesn't affect the air con (other than allowing the carriage to warm a smidge) saves fuel and prevents filling everyones lungs with particulates. Its also policy at northern as far as I'm aware.
What's not to like?
Efini92
14 Dec 2016
What's not to like?
Of course it affects the air con. By forcing the engines off stops the aircon going into its run down phase which damages the condensers and stops them from being able to vent properly when the carriages get to warm.
wobman
2 Jan 2011
What's not to like?
Tfw shut the 158s down immediately at Birmingham International, the company policy is to shut them down once the service has arrived due to pollution.
On the 158s at tfw they shut the engines down straight after pressing the button and there's no policy regarding air con.
Efini92
14 Dec 2016
That’s probably why they are always running round with the hopper windows open.
158747
5 Aug 2010
Trowbridge
It is possible to shut 158 engines down without damaging the air con. Just press engine stop button briefly, the air con will then shut itself down, the engines stopping a minute or two later, once the air con has shut down.
driverd
29 Mar 2021
Precisely, not entirely sure what Efini92 is on about and they haven't replied directly yet.
I'm just curious if they know something we all don't!
TurboMan
5 Apr 2022
I assume it's because a long press on the engine stop button acts as an emergency engine stop which shuts the engines down immediately and doesn't allow the aircon to go through its shutdown cycle.
driverd
29 Mar 2021
I thought the implications was turning the engines off in any fashion (ie: properly or not), damages the aircon?
tomuk
15 May 2010
On 158s, as built, due to the time needed for the air con to pump down there was a delay added to the engine stop circuit. If the button is pressed normally the engines would shutdown automatically after a couple of minutes delay. If the button is held in the engines shutdown immediately, this is not optimal for the aircon. The aircon system n the 158s has always been marginal as it was specced with a low capacity to keep the weight down. This is not helped by the need to run the wrong more environmentally friendly refrigerant, the long refrigerant pipes leading to leaks and the mis-operation of the system by staff, engine stop, control panel messing and window opening.
