GWR Weekend Brighton services
387star
Despite no apparent weekend engineering works these trains are often pulled. They are usually very busy services especially the extra Sunday ones.
Currently in the long term plan Saturday sees only the morning train run whilst Sunday sees just one train rather than four which sits at Brighton around three hours before taking the pathway of what would have been the next GWR service. However the short term plan cuts even these two services.
Fratton has had a huge influx of drivers recently so hopefully these services will resume. I'm sure at weekends they are very valuable.
D9006
28 Aug 2019
Wigan
The line is closed between Salisbury and Southampton all weekend, buses between these 2 points, remember bashing the 33s in 1980s, these services diverted via Basingstoke, with a run round involved there. It seems a culture now to just pup on RRB rather than arrange diversions, crew route knowledge I guess a big factor now
387star
This weekend yes next weekend there's nothing still no Brighton...
jackot
1 Aug 2021
Yes, from experience it tends to be a very unreliable experience. Between the 2 times I have tried to catch in from Salisbury to Brighton it has been cancelled or terminated early at Southampton for no apparent reason.
43055
8 Mar 2018
Part of the temporary timetable reductions sees the Saturday service start from Fratton at 0954 and Sunday return cancelled. The GWR website has a PDF will all the altered services.
Kite159
27 Jan 2014
West of Andover
It's a shame for it not to be running, considering it is a lot faster than the Southern services. Especially on Sundays when the Southampton - Brighton calls at every station between Brighton & Chichester (and suffers from overcrowding along the way)
The exile
31 Mar 2010
Somerset
Better that a service is cancelled on a route where there are alternatives, than leave a large gap where there aren’t. Ok - better if not cancelled at all….
route101
16 May 2010
Surprised they still run to Brighton. Looking at doing the GWR to Brighton in the near future, is it generally a turbo now?
LA50041
20 Feb 2017
There is however major engineering works on the BML with VIC-Brighton trains diverted via Littlehampton meaning there are only 2 full length Platforms available at Brighton
Peregrine 4903
18 Aug 2019
Doesn't affect GWR, there Saturday and mon - fri trains are certainly still running despite platform capacity at brighton. Required quite a bit of work but is possible to fit them in at least for the Saturday.
387star
It's nonsensical as ever. They had the crew for it. Hoping the Sunday four make a return one day. The morning Brighton to Cardiff was a packed train as was the late evening one that arrived in Brighton around 9pm
LA50041
20 Feb 2017
However the SX and SO do not have a 2.5 hour turnaround, which is unlikely to be accommodated with the reduced capacity at Brighton
Peregrine 4903
18 Aug 2019
Eh I respectfully disagree there. On Sunday there are only 4tph from Southern than run into Brighton from the West Coastway. The GWR can sit in Platform 1 or Platform 3, the London via Littlehampton services can use 2 and the Brighton to Portsmouth/Southampton services use 1.
If its for Saturday or SX, a 2 and a half hour lay over can still be accommidated, just through platform sharing, either the GWR is put in 3 and the Southern Brighton - West Worthing and Portsmouth/Littlehampton services platform share or a combination of the above solution.
The reasons these trains are being cancelled is not due to capacity reasons at Brighton.
LA50041
20 Feb 2017
Unless you do the platform workings at Brighton, we will have to agree to disagree then
387star
GWR are running them to Brighton on weekdays next week despite engineering work on the BML on those days
Peregrine 4903
18 Aug 2019
I would laugh if both of you work for Southern doing platform workings at Brighton and didn't know the other was on the forum....
Doesn't have to be Southern, there are other parties involved in train planning.
Tim456
17 Jul 2016
If this article is correct there will be NO GWR services after mid May:
Apologies - already being discussed here:
