GWR Turbo height
24 Nov 2016
Torbay
Correct, some have been done some haven't. The ones that have been done have a triangle on the cab wit RHM (Ride Height Modifications) written on it.
CR165022
12 Nov 2019
Buckinghamshire
Thanks, do you know what as actually happened to them? Was the body risen or something?
Clarence Yard
18 Dec 2014
All have - the ride height was modified (upwards) using bogie shims.
This cut out the need to alter a lot of the platforms in the Bristol and Exeter areas which were more suited to the 15x units, which sat higher than the Turbos.
NSE specified a closer platform/vehicle interface than Regional Railways, which now causes issues with the required clearances, even over lines which the Turbos have traditionally operated.
adc82140
10 May 2008
How much taller are they now? Enough to be visibly different, or more subtle than that?
pdeaves
14 Sep 2014
Gateway to the South West
The raising shim is, I believe, 25mm so is probably imperceptible to the human eye in normal circumstances. As stated, it was easier/cheaper/less disruptive to modify these trains than all the platforms (which potentially could have made stepping distances worse for other stock).
Clarence Yard
18 Dec 2014
Yes, 25mm is the shim - that still puts the stepboard height about 25mm less than a cl.150, iirc.
