GWR Touch Card Start Journey from TFL Station
njr001
8 Feb 2013
Several days ago I used GWR's booking engine to find times of trains from Rickmansworth to Aylesbury Vale Parkway (as I had the site bookmarked on my computer.) When I checked fares and delivery options it showed that a GWR touch card could be used, as travel is not until this weekend I applied for a touch card which I have just received two days later.
Will it really work for this journey touching in at Rickmansworth?
Joshua_Harman
2 Feb 2021
Yes, a ticket or travel card loaded onto a national rail Smartcard will work within the appropriate zones and stations and on buses for travel cards, but they cannot be topped up within London because the TVM’s are equipped to deal with oyster and cannot read ITSO cards (except at St.Pancras where there is one or two machines that can read NR Smartcards but I haven’t tried them to see if it will work) I also don’t know which ticket offices will / can do it, but if you can buy it online or from another national rail station then it will work as normal, just tap, and go.
MrJeeves
28 Aug 2015
Burgess Hill
Yep! TfL have been equipped with ITSO compatibility since September 2014 as part of a project named ITSO on Prestige. You just have to have an appropriate ticket loaded onto the smartcard in advance for it to work.
CyrusWuff
20 May 2013
It should work is probably a more accurate statement. The gateline configuration at the Met Line stations in Zones 7 to 9 is more than a little bit flakey where ITSO's involved!
Upon querying this with TfL Customer Services, it's been reported that they've told the customer to inform the retailer that products shouldn't be being issued on ITSO and they should swap it for a paper ticket!
redreni
24 Sep 2010
Slade Green
Sounds like we're definitely ready to get rid of ticket offices.
njr001
8 Feb 2013
Many thanks for the replies. I'll give it a try on Sunday.
Happy to report it worked without any problem including on return touching in at Amersham rather than Aylesbury Vale Parkway
