GWR Dec 19 timetable
II
28 Dec 2016
It also has to fit
I think that you'll find that the point is a combination of:
- Getting the majority of passengers (who are going to Bristol) to their destination quickly
- Not running into the rear of the all stations service that departs Bristol Temple Meads for Taunton at 16:53
- Allowing the cross country service take its path south
- Doubling up as a commuter service out of Bristol to Weston-super-Mare serving three intermediate stations
Indeed. The original bid was for it to depart immediately at 17:06 to reach Weston at 17:35, but that was changed and could have been for any or all of the above reasons. All of the down Weston services were the same with minimal layovers at Bristol, except one which had 7 minutes.
Now the train is 'in the system' it may well be possible to optimise it over time with a little tinkering here and there. The original drafts were based on the Superfast service between Bristol and London running all day, well 8am-8pm roughly, so when those extras are introduced the pattern to Weston will change again from what it is now.
mikeb42
19 Jan 2015
Meanwhile, the performance of the 17:04 Weston/17:25 Bristol TM/17:35 Bristol PW "SuperFast" (infinitely hollow laugh) continues to be absolutely dismal.
https://www.ontimetrains.co.uk/journeys/BPW/PAD/17:35/18:45/GW;dayOfWeekRange=Weekdays;dateRange=12W
If anything it is getting worse. Cancelled again today.
We've given up on it for now. Advice has been issued to use the 17:00 from Temple Meads or other mode of transport until/unless things improve. From my own records I know that driving most of the way down the M4 and then getting the tube is statistically both quicker and more reliably so door-to-door. Time is literally money in this instance; I'm going back to the M4 for my next batch of engagements after one more lottery-of-despair with this service next Thu.
On the evidence so far, this service is basically pointless.
HowardGWR
30 Jan 2013
In fairness the cancellations were nearly all those that would have affected all services on that line, but i appreciate that is irrelevant for your purposes. The M4 was constructed when avoiding flooding was paramount in the design, which is why it took to the Cotswold Hills and Berkshire Downs AsONB, inflicting great environmental damage. An HS route between Bristol and London, designed today, would try to do the same. It would be interesting to discover what considerations took place on the Badminton route, because that was constructed in Edwardian times.
Horizon22
Jobs & Careers
8 Sep 2019
It appears to be that because this is not so much a "core service" and there are other options, it's the first one lopped off where's there's trouble around the peak (4 cancellations due to infrastructure). It's fairly common for this action to be taken with express trains around the country.
However the 1727 & 1755 have also not been great runners.
30907
I don't wish to underplay the problems, but I am intrigued at the nature of your business which can brook no margin for public transport delays and manages to avoid delays on the road network.
Wychwood93
25 Jan 2018
Burton. Dorset.
Agreed. Crossing county lines? - not that. Delays by road - as unpredictable as rail delays. What is it then?
squizzler
4 Jan 2017
Jersey, Channel Islands
To be fair it can dependent on the attitudes of the people he is dealing with and whether they are keen motorists. I know certain associates who are members of the motoring community with the mindset that if you get delayed on the train it is your fault for not choosing to be in control and drive yourself, but if your own car is delayed due to highway or traffic conditions that is simply put down to misfortune.
Also bear in mind that if he is meeting others who motor to appointments, if the roads are a shambles then both parties will be late so nobody loses face.
HowardGWR
30 Jan 2013
Your post confused me: Bristol doesn't have a tube. Also, your complaint was about the reverse direction at the end of the afternoon. I assumed thus that your work was in Bristol and that you were on your way back. Any chance of elucidating what was so disastrous about being half an hour late home from work; annoying agreed.
jimm
6 Apr 2012
Today's derailment at Eastleigh once again demonstrates how to make the GWR afternoon and evening peak not very superfasts to Oxford/Cotswold Line service run on time - which they have failed to do most of the time since their introduction - get the XC services out of the way, in this case due to big delays.
The 16.58 and 17.58 departures from Paddington were both on time into Oxford today. The 18.58 arrived 3 early after a 41-minute run, which may well be a record for a regular timetabled service from London to Oxford - as opposed to last autumn's specials.
Sadly for the 16.58, a late XC had delayed the preceding halts train to Moreton-in-Marsh - after a pretty questionable bit of decision-making, with the halts train held at Didcot North junction for 10 minutes waiting for the XC service to pass - so the IET got held at Wolvercote and again at Ascott-under-Wychwood, and was 18 late at Moreton and 20 late into Worcester, where it terminated short as two late-running Birmingham-Hereford WMR trains barred the way to Malvern.
And not a single connection was achieved at Oxford for passengers using XC from Reading to get trains to Cotswold Line stations.
Even on a day like this, the poor old 18.28 to Banbury, definitely the runt of the superfast litter - was still 7 late at Oxford, as the XC to York had been turned round at Reading and then got stuck behind a delayed Reading-Oxford Turbo.
I could write a lengthy treatise about the overall performance of the Cotswold Line afternoon peak trains (and the Banbury superfast) from London since mid-December, but suffice it to say it is a pretty sorry picture, as I feared it would be.
The assurances given beforehand that it would all turn out fine have, I believe, been amply demonstrated by now to have been wrong, with late running and missed connections a fact of life day in, day out, as a look at recenttraintimes will attest. This bit of the timetable does not work and GWR, Network Rail and other interested parties need to admit this and have another go.
The GWR to GWR connection from the 16.20 Paddington to Oxford into the halts train is about the only reliable one every day.
And with the universities back, the halts train is leaving Oxford with pretty much every seat taken. It does empty out by Charlbury but with lots of new homes nearing completion near Hanborough station and elsewhere in the village and nearby, any strong uptick in custom is going to put a two-car Turbo under sustained pressure capacity-wise.
At the moment GWR has just about got away with it on this one - but the same could be said the of the 16.58, which is already testing the capacity of a five-car IET - in nice quiet January - from London to Oxford and out the other side. Once the tourists start to turn up in numbers from Easter, this one is likely to struggle.
II
28 Dec 2016
As you have to expect with any peak hour service. You hinted at worse, I was expecting a few to have to stand out to Hanborough, but if it's even quieter than I was expecting then that's good news. Timekeeping has been interesting - on the odd occasion it has lost no, or very little time after departing Oxford. Though quite frequently it loses four or more minutes. That can only be down to crew familiarisation with braking points and so on (which should improve over time) as there's nothing else in its way, but it remains a clear fact that it should be given a couple of extra minutes to complete the trip.
My '3-car proof' plan up-thread is ready and waiting to go if the powers that be decide to take in on board. :) Though as plans for the 769s develop it appears that they will be confined to the North Downs Line, branches east of Reading and Basingstoke. Sadly it's the 3-car Turbos that will be cascaded west leaving little prospect of anything other than 2-car Turbos shuttling up and down between Banbury, Oxford, Didcot and Reading as well as the two daily runs down the Cotswold Line. Commuters between Didcot and Oxford are worse off than ever, not helped by the very poor timekeeping of one of the main morning services into Oxford from Didcot at 08:07 - 9 minutes late again today which is about what is typical.
Regarding the XC connections from Reading, I've noted many times the Oxford Superfasts getting held on the down main at Didcot East stopped for anything up to five minutes to allow a XC following behind on the reliefs to go ahead. That has aided connections at Oxford from Reading that might have otherwise been missed, but of course it does knock a delay into the Superfast and there's nearly always something else heading towards Swindon that also gets delayed as a result of that train blocking the down main.
As you say, that is one part of the timetable which really does need looking at, though adjustments will be difficult to make without upsetting the apple cart too much elsewhere.
Perhaps XC were too quick to change their departure times from Southampton. IIRC they moved right 2 or 3 minutes only a couple of years ago, but I’m not sure if that was done to reduce overall running time or avoid a conflict elsewhere...
jimm
6 Apr 2012
It appears that despite the last direct off-peak tickets service of the afternoon from Paddington back to the Cotswold Line being the 15.50, that not too many are opting to take the 16.20 and change at Oxford, which has probably saved GWR's bacon in terms of using a Turbo - for the time being.
I think the 16.58's loadings may have caught them a bit by surprise, with standing out to Hanborough and sometimes to Charlbury. The old 16.50 Paddington to Oxford was always very quiet, but now the 16.20 is the one that is lightly loaded instead - though not so much returning to London as the 18.02.
The issues with the northbound XC services - and things running ahead of them on the relief line, be that freight, 387s or Turbos - are the reason why far too much of the time the superfasts are precious little faster into Oxford than trains that call at Slough and Reading en route and, as you point out, also tend to hold up one or both of the pair of Bristol services running right behind the xx.58s to Oxford and beyond.
Adjustments they will have to make, whether or not any apples get spilled - funny how the last-minute afternoon peak changes that they did not consult anyone about are the part of the new Cotswold Line timetable that just does not work...
Maybe put the first-stop Chippenham service at the start of the sequence, then stop the Oxford/Cotswold service at Reading, to spare people the daily 'will it/won't it connect' XC lottery, with the Bristol train that makes the regular stops running behind that, though there are then a pair of West Country trains not far behind as well. Or revert to the standard xx.50 slot for Oxford/Cotswold down trains and do something else with the Didcot peak extras that are a big factor in all of this.
squizzler
4 Jan 2017
On the subject of the Cotswold line, the 1250 out of paddington is nine cars of fresh air after Reading. I connected at Worcester Shrub Hill to an onward train which departed at 1517 so could watch it boarding on the opposite platform (the IET would form the 1520 WOS - PAD) and am quite sure that at 3 minutes before departure there were cars with nobody on at all.
Perhaps GWR should offer Megabus style £1 fares on that diagram from Reading onward?
HowardGWR
30 Jan 2013
Hmm. Perhaps Pullman Dining provision on that 1250, with connecting coach to Stratford upon Avon from Honeybourne (arr 1430), might entice tourists? :)
irish_rail
30 Oct 2013
Plymouth
Quite. Meanwhile the 1304 to Plymouth is bizarrely a pair of 5 cars despite the fact it doesn't split at any point on its trip or return to London. Surely the 1304 should become a 9 and the 2 released 802s , one forms the 1250 and one could be used to strengthen another service that needs lengthening.
Clarence Yard
18 Dec 2014
No, it isn't bizarre. The 2 x 5 cars are LA finishers so you need them back there otherwise you will be a set short on LA overnight. The 1304 returns to Pad at 2022 and then it forms the 2104 to Plymouth.
The problem with short forming the 1250 is that it's back working from Worcester forms the 1748 Pad-Worcester on a short turnround, not a train to short form or to try and muck around with at Pad in the evening peak and, arriving back at Pad at 2344 it is also a North Pole finisher, so you will back into "imbalance" territory if you did such a swap. That is why the 1250 is a 9 car.
Diagramming these units is not a matter of simple swaps, for all the reasons that I have mentioned before. They are not fully interchangeable fleets and because of the needs of the train plan, the diagramming at certain times in certain locations is almost hard wired.
Goldfish62
14 Feb 2010
Couple of 9 cars on Penzance services today. 0915 from Penzance and 1405 from Paddington.
Clarence Yard
18 Dec 2014
Stops and misbalances meant that is was -4 on the 802 5 cars diagrams today but with +2 on the 802 9 cars, they covered the morning position nicely, albeit being a little tight at Long Rock last night.
Across all the fleets there were 3 x 5 vice 9, 1 x 5 vice 10 and 3 x 9 vice 5. 800 sets were fine for availability but it was the overnight misbalances that caused this mornings variations in the 800 deployment.
jimm
6 Apr 2012
In addition, the return run at 15.20 from Worcester calls at Oxford at 16.32, Reading at 16.57 and Slough at 17.09, a time of the day when the odd passenger or two has been known to board trains in the Thames Valley - but, as ever, why would some of the usual suspects let the facts get in the way?
irish_rail
30 Oct 2013
Plymouth
Oh yeah because reading and slough are really short of London services, God forbid an intending passenger need wait 3 minutes for the next London to arrive if the ex Worcester was busy. And btw, heading into London at that time, a 5 car IET would suffice off Oxford, and I do know that route rather better than you might suspect Jimm before you tell me I'm wrong.
Goldfish62
14 Feb 2010
Thanks for the explanation.
jimm
6 Apr 2012
So as ever you jump in feet first, claiming that a nine-car set which is on a diagram for a very good reason doesn't need to be on that diagram at all and could perfectly well go off to - knock me down with a feather - the West Country. Why not Bristol or Cardiff?
Yet again Clarence Yard has to lay out the facts that you could have worked out for yourself, by following the diagrams through to the end of the day.
Yes, you are plain wrong about the number of passengers from Oxford* heading towards Reading and London in late afternoon - as anyone on the station at that time of the day when the London fasts are due into platform 3 can see, all the more so in the tourist season from Easter onwards.
You have been told this over and over - same as you have been told lots of other things over and over, but then keep claiming that the opposite is true months, or even years, later.
If you know the route oh so well, why do you keep posting things about Oxford and Cotswold services and rolling stock allocations that are oh so wrong?
At Reading, as I'm sure you know, lots of people will just get on the first fast train to Paddington that turns up, even if it's an already busy five-car when there is a nine-car or 2x5 due just a couple of minutes behind. The past two mornings I have got off five-car sets there, which have left platform 10 full and standing, just as a nine-car with lots of empty seats is pulling into platform 11.
Slough may have lots of London trains, but does not have lots of London fasts, so guess which services the passengers from Slough to Paddington want to get on? I know they are mere commuters, but when the choice is a 15-minute non-stop run on an IET, or 35 minutes on a stopping 345 or 387, it's pretty obvious which one they will choose.
*And just for a bit of fun, I repeated the exercise of totting up the number of passengers using all the stations in Cornwall in 2018-19 and comparing that with the figure for Oxford station (where little trains will suffice) to follow on from doing the same with the 2017-18 figures last month - post 1006 on page 34 of this thread.
2017-18 figures
Oxford: 7,984,000
Cornwall: 6,453,406
2018-19 figures
Oxford: 8,270,000
Cornwall: 6,397,332
HowardGWR
30 Jan 2013
2017-18 figures
Oxford: 7,984,000
Cornwall: 6,453,406
2018-19 figures
Oxford: 8,270,000
Cornwall: 6,397,332
Actually jimm, as a BTW, I think the figures for Cornwall in total are still quite impressive and thus justify GWR's half hourly service with the join/split sometimes at Plymouth, from Dec 19 2019. Doesn't take anything away from the point you are making though. Doubtless this fact added to their decision-making,
irish_rail
30 Oct 2013
Plymouth
Exactly! The fact oxford gets twice the number of trains than Cornwall from London yet doesn't have significantly more passengers rather supports the argument that either oxford is over served or Cornwall underserved.
irish_rail
30 Oct 2013
Plymouth
2017-18 figures
Oxford: 7,984,000
Cornwall: 6,453,406
2018-19 figures
Oxford: 8,270,000
Cornwall: 6,397,332
And rather than bang on about how good we have it down here why not actually visit or listen to those of us on the ground dealing with the hectic farce that is the December 2019 timetable. Passengers - confused. Staff - confused. Trains- short formed daily.
Lack of crew to cope with all the extra ecs moves. It isn't going well whatever the punctuality figures may claim.
There is no reason why diagrams couldn't be 're jigged come may, so that a 9 car is used on the 1304 to Plymouth and back and then swapped at London onto a different working so it finishes at the right place.
Saying that people choose to get on the oxford to London's at Reading isn't really justified. An announcement telling them to wait 2 minutes for the next train would suffice and most would probably listen. Or are your precious south eastern customers immune from having to do what they are told , whereas those in the south west should do whatever GWR tell them too!
HamworthyGoods
15 Jan 2019
Why are you so keen that the 13.04 is a 9 car not at a 10 car I don’t understand? Same number of seats etc.
The reason the 13.04 is a 10 car which nobody seems to have picked up is in the high summer this train divides at Plymouth with 5 cars carrying onto Penzance. The rear 5 cars attach onto the 5 cars which come up from Newquay.
Goldfish62
14 Feb 2010
Although I don't see what conclusions can be drawn from comparing passenger numbers on an 80 mile stretch of railway serving multiple stations in one of the country's most socially and economically deprived areas with the one station in a wealthy city in the oute London commuter belt. Chalk and cheese.
What next? Waterloo and the Far North line?
jimm
6 Apr 2012
As I noted back on page 34, almost a quarter of the passengers in Cornwall are on the Falmouth branch - so largely students and locals travelling up and down to Truro - and holiday season park-and-riders on the St Ives branch.
Take them off the total, take out all the people simply making other local trips within Cornwall, or no further than Plymouth, and the idea that there are vast numbers making London-Cornwall journeys all the time simply does not hold water and amply justifies the decision-making process - explained many times now by Clarence Yard - on the structure of the timetable and rolling stock allocations there and in other places on GWR where there is far higher overall passenger demand, such as Oxford.
Did you actually read and absorb the whole of HowardGWR's post? It doesn't look like it.
You are the person who has laughably claimed that as there are 500,000 people scattered across Cornwall that it should be treated like a conurbation of 500,000 when it comes to planning services.
Oxford station generates all that traffic off the back of a population of less than 160,000. Chuck in the adjacent 'village' of Kidlington (population about the same as the city of Truro) and Oxford Parkway station and that's another million passengers on to the local total.
Could you enlighten me as to where all the short-formed train are today then?
From GWR Journeycheck just now.
0 Train Formation Updates
You keep crying wolf, but the script never changes, and you never actually produce any concrete evidence for what you say.
If a nine-car is used on the 13.04 to Plymouth then it gets back to Paddington at 20.22, so it wouldn't be going anywhere else for at least another 20 minutes and might just about squeeze in a lightly-loaded run to Bristol and back at that time of the day - or just go straight on to the depot. All very, er, productive....
It's not justified - did you miss the bit where I said that is exactly what happens? Unless a preceding train from Bristol/South Wales is late and has just cleared everyone off the platform when a five-car from Oxford/Cotswold Line/Cheltenham gets in, the passengers wanting a fast from Reading to Paddington get on whatever is in the platform, no matter what any announcements might tell them, or how busy the train is.
It's very simple - because of irishrail's dogged insistence that the South West is just so special that everything running between there and London simply must be an unsplittable 640-seat train all the time, irrespective of the variable loadings at different times of the day, and west of Plymouth - whereas everywhere else on the GWR HSS operation can just make do with whatever is left over, even if there are far more passengers, year-round, on those routes to begin with.
You probably need to read back through some of irishrail's output to get what I am driving at - such as the example I give at the start of this post.
Apparently the area you say is socially and economically deprived - so not likely to be a top generator of rail travel demand - needs 640-seat London trains morning, noon and night, year-round, whereas other places do not - and while it is fine for those 640-seat trains to run half-empty, or worse, one or both ways through Cornwall, every journey any of them makes in other parts of the country, such as the 12.50 Paddington to Worcester/15.20 return, when they might not be packed to the doors all the time, must be eliminated forthwith and the offending piece of rolling stock dispatched to the West Country post haste.
irish_rail
30 Oct 2013
Plymouth
You don't seem to get it jimm for the umpteenth time I am not calling for every Penzance train to be 9 car all day.
I AM however saying running pairs of 5s that don't even split is inefficient and wasteful.
I am also saying that the coupling and uncoupling at Plymouth is shambolic. As someone who is actually doing it day in day out I think I have a better idea on how it is going than you.
And if there are no short forms today, then congratulations, GWR have finally provided for the first time since mid December a day with no short forms on the Plymouth route. Lets hope it's not the last time either.....
