GWR Class 800
D365
29 Jun 2012
Erm, how many times do we have to reiterate that, to give but one example, the East Coast 800s WILL be committed to long diesel runs in Scotland, on lines north of Edinburgh that are not being considered for electrification at all.
How much time do the HSTs spend running at 125mph in South Wales?
10 Mar 2013
i do think there is confusion between the full Bi-modes and the 'last mile ' / emergency capacity of the mainly electric ones
good question about line speeds for the more peripheral areas ...
notadriver
1 Oct 2010
They might not be able to accelerate as well as existing HST sets can on diesel power.
The Ham
6 Jul 2012
With a 22 minute journey time improvement for trains between London & Bristol that would mean that the 800's would have to go a lot slower after Bristol (assuming Bristol was the end of the wires when they started in service) for them to be slower than the current services.
Given that it takes about 1 hour 40 minutes to go from Bristol Parkway to Swansea the average speed of the train is about 50 mph (including for the 5 stops which the train makes). For journey times to London to decrease from the current time Bristol Parkway to Swansea could take 2 hours which would put the average speed at 40 mph including stops.
Yes, Swansea to Cardiff would also be slower with a journey time of 64 minutes compares with 55 minutes currently based on the same speed. However, I would be very surprised if journey times were anywhere near that much slower as an Arriva Trains Wales service with 9 stops takes 66 minutes.
Rich McLean
6 Feb 2012
Is 125mph possible (or even a realistic aspiration) on the routes where the "802"s will be running on Diesel power? I was under the impression that linespeeds West of Newbury/Westbury/Bristol would require many level-crossing closures if they were to be raised. Certainly South/West of Taunton the curves and gradients would seem to make 100+mph tricky.
There area few 110mph line speed sections on the B&H
Noddy
11 Oct 2014
When Swindon-Kemble was redoubled didn't they upgrade the line for 110mph running?
http://www.cliftonbrown.co.uk/content/swindon-kemble-–-getting-speed
It was in all the local papers at the time too...
jimm
6 Apr 2012
As far as I know, it has gone no further than assessments by Network Rail of potential for higher-speed running on parts of both the Kemble route and the Cotswold Line, whether that be going above current 100mph limits or increases from 90 or 95 to 100mph in places or lifting the 75mph ruling limit between Moreton-in-Marsh and Evesham on the Cotswold Line. With the new trains still a couple of years off there's no great urgency to make changes and in any case much of the track may well be able to handle increased speeds without much if any fettling.
SpacePhoenix
18 Mar 2014
What's the hp/tonne values like for Voyagers, Meridians and Adelantes? (can't think of any other "high speed" DMUs
RobShipway
20 Sep 2009
I do not have any figures, but I know when I was on Voyagers last Saturday they seem to be quicker at going 0 - 100mph than an HST, although they are only 4 car so not really a great comparison.
What would be interesting to see is the hp/tonne values of 7 car 222/0 compared with HST 7 car, compared with Class 800 5 car.
Haydn1971
11 Dec 2012
Sheffield
You can't compare bhp/tonne like that - the diesel units provide electricity for traction motors - you need to be comparing the tractive effort of the relative trains
notadriver
1 Oct 2010
Surely bhp / tonne is a good measure? Roughly 80% of the Diesel engine bhp will be available at rail giving a good indication of acceleration.
Voyager and 222s (transmission differences apart) should accelerate roughly the same as each coach has a 750 bhp engine (usually de-rated to 700 bhp). They are the fastest DMUs we have but very polluting in terms of CO2 emissions per passenger.
Haydn1971
11 Dec 2012
Sheffield
Not really - you have the same 25Kv running into overhead powered EMU's - there is clearly a difference in performance between different types of units and also loco hauled trains - tractive effort is the measure
Agreed, 220, 221 & 222's are from the same fleet design, share similar construction and are electro-mechanically very similar. Just because you have a similar output power pack in the 800's, doesn't make them equal - the coaches are different a different size and weight, traction motors may have 15 years worth of technological advancement over the ones used on the 22x classes and the running environments will be different - all working together to change the dynamic of acceleration.
Emblematic
14 Aug 2013
At the lowest speeds, adhesion will be the limiting factor. Modern traction with multiple motored axles and better controlled ac motors will be fastest off the mark, irrespective of quoted power and tractive effort figures.
Above a certain speed, which ignoring anomalies such as poor rail conditions will be relatively low, adhesion will exceed tractive effort, which now becomes the limiting factor. Low geared machines will now out-accelerate higher speed units.
At a certain point, force x velocity will equal the available power, and acceleration is now determined by power alone as tractive effort decreases. Above about 50 mph almost all trains are constrained by power alone.
Haydn1971
11 Dec 2012
Sheffield
Well not really, you don't need full power to maintain 125mph - full power provides maximum electricity for when maximum load is placed on the motors that power the unit forward. I accept that tractive effort is just (a big) part of the story, but bhp/tonne isn't a reasonable measure of how well units perform, there's much more to it than that.
Notwithstanding the above, vast sections of Class 800 routes planned to be covered by diesel power alone have much lower speed limits than what you would expect on a mainline - thus you don't require the same amount of Mw applied to the motors as you would on a mainline - this is clearly a strategy being used by Hitachi, in that the Class 800 units are derated to reduce ultimate loads on power packs and reduce time out of service and in the "803" units, power packs are fully rated to ensure they can deal with the topographical issues down on the hilly South East routes - which notably don't have 125mph speed limits.
notadriver
1 Oct 2010
Well we will have to wait and see. There's a massive amount of difference between a Javelin running on 25 kV AC and on 750 V DC and I expect the 800s to have a similar performance difference when running on Diesel engines. I just hope it isn't too different.
As for different motors, weights etc of new units. I'm fairly well acquainted with the performance characteristics of the Javelin trains which the 800s are a close relative of so I have a fair idea of how they perform away from the overheads compared with other traction.
LexyBoy
23 Jan 2009
North of the rivers
What are the sources for your class 800 figures?
Ask sprinterguy - I'm too lazy to do my own research <D
13.25 hp/tonne for a 221 according to the same post I linked. For comparison, a 390/0 is 14.68 hp/tonne and a 395 17.0 hp/tonne (Wikipedia). In the case of the 395, this is presumably limited by the power that can be supplied through third rail.
Well yes, sort of - it's a decent approximation though. Leaving improvements in generator/motor/control efficiency aside, the power generated by the engine will determine the power available to the traction motors. Tractive effort will depend on how this power is delivered to the rail - i.e. the number of powered axles, and the weight on each of these (Class 800 will have lower power per axle so ought to have better traction I think?). I can't believe that with more power available, and distributed traction rather than powercars, a Class 800 would perform worse than an HST in either acceleration or top speed.
sprinterguy
4 Mar 2010
Macclesfield
To step in here, it should be noted that the power to weight ratio is based on the engines running at their full output of 700kW (The figures came from Hitachi's own published specifications for the trains). At the time I made that posting, two years ago, it had not been announced that the main tranche of IEP trains would have their engines derated, and I have not seen a figure for what the revised, lower, engine output is going to be.
I find it strange that the Bi-mode sets are expected to be limited to 100mph when running on diesel power. Even with downrated engines, they should still have an engine output at least as high as a Voyager, and, while I appreciate that there is more to it than simply engine horsepower, they have no problem reaching 125mph with a similar diesel-electric setup.
notadriver
1 Oct 2010
Hi Sprinterguy - so what is the actual installed diesel power in a 5 car and 9 car IEP set please ?
Very interesting. You would expect a class 390 and 395 to have similar acceleration given that the advantage a 395 has is only just over 2 hp/ton advantage and that they are both geared for 140 mph maximum. But my experience suggests that's not the case and 390s are quite slow to pick up speed.
LexyBoy
23 Jan 2009
North of the rivers
Also to note that my number for the HST is based on the "at rail" power - using the engine power it's more like 10 hp/tonne, so they're likely to be comparable in reality. Still, I'd expect distributed traction and a modern powertrain to give better performance.
Is this definite? I keep reading conflicting statements - that 100 was all that was specified, but Hitachi have said 125 on diesel, or that 100 is still the maximum. Maybe I'm getting mixed up with the AT300s.
sprinterguy
4 Mar 2010
Macclesfield
At full engine output: 2.4MW (2,820hp) for a 5-car set and 3.5MW (4,700hp) for a 9-car set, though as I say, I don't know what the revised lower engine output is going to be.
Hitachi themselves have confirmed that the class 800 trains will have a maximum speed of 100mph in diesel mode. See "About AT 300 Trains" near the bottom of the following article:
http://www.mynewsdesk.com/uk/hitach...f-new-at300-trains-for-the-south-west-1133384
About AT 300 trains
The AT300 trains are a train platform developed by Hitachi Rail. Their most famous relatives in the UK are the Class 395 Javelin™ train currently in service in Kent and the Class 800/801 train for the Intercity Express Programme. This family of trains is designed for intercity travel, with speeds of up to 140 mph for the Class 395 Javelin and 125 mph for the Class 800/801 trains for electric operation and 100 mph for bi-mode operation. The Class AT300 has larger fuel tanks than the Class 800 bi-mode trains and engines that operate at a higher power output
NotATrainspott
2 Feb 2013
The best explanation I have pieced together from various sources is that theoretically, the AT300 design with the standard number of standard diesel power packs is capable of running at 125mph in self-powered mode. However, the way the IEP procurement programme works means that Agility Trains, the consortium of Hitachi and a financial partner, is contracted to provide a number of fault-free diagrams each day, with major financial penalties involved if they don't manage it. As the routes planned for the initial IEP orders don't involve running in self-powered mode above 100mph, they made the financial decision to leave the excess power in reserve so that if any one engine fails, they can still provide the train in service that they were contracted to provide.
The only other relevant information I can find about this issue is that unlike other trains, not every carriage in a self-powered AT300 is actually powered. All driving vehicles are trailers, so out of a 5 car IEP there are only three engines, while there are actually some unpowered trailer carriages in longer sets. The draft interior layout document says that the arrangement of a 5, 8 and 9 car IEP set is as follows:
5 car: DPTS + MeS + MS/MeS + MC/MeC + DPTF
8 car: DPTS + MeS + MS/MeS + TS + TS + MC/MeC + MF/MeF + DPTF
9 car: DPTS + MeS + MS/MeS + TpS + MS/MeS + TS + MC/MeC + MF/MeF + DPTF
If I'm not mistaken, the 'e' means there's a diesel engine in that carriage, as all 'electric' IEPs will still have one diesel engine for emergency use. If each diesel engine is the same power as one in a more traditional DMU, then the reduced number of engines per train set might be the reason why in self-powered mode they wouldn't be able to keep up with a Voyager or similar.
sprinterguy
4 Mar 2010
Macclesfield
Correct, hence 5 engines in a 9-car Bi-mode train. I wouldn't expect a Bi-mode IEP set to demonstrate the same level of performance as a Voyager in terms of acceleration, due to the unpowered trailers as you state, but (prior to the 100mph max announcement) I thought that they would still be able to reach 125mph on diesel power, just that it'd take a little longer and surely still show a clean pair of heels to an HST. The first paragraph of your post provides a plausible reason why this may not be the case.
notadriver
1 Oct 2010
Interesting - so for a 5 car 2800 bhp of which some has to power the auxiliaries. Let's say 200 bhp (will probably be more than that) leaving 2600 bhp to power the train. You'll get around 80 percent at rail 2100 rhp for 5 coaches. Its not too dissimilar to what Javelins get on 3rd rail.
Emblematic
14 Aug 2013
I meant acceleration, not ultimate speed. Power = (force * velocity). If both power and force available are limited, below a certain speed the force limits acceleration, above it power is the limit. Ultimate speed is determined when tractive effort, which is decreasing with speed, balances the resistance to motion, which increases. A nice document showing the calculations with graphs is here.
So in addition to lower top speed, the acceleration will be lower at the higher speed ranges on diesel, and balancing speed on gradients will be lower too.
Interestingly, the 'maximum acceleration' graph in the IEP TTS (which looks suspiciously like a tractive effort curve) seems to indicate that the acceleration becomes power-limited around 30 mph. Assuming that's for electric, It will be lower for diesel (I haven't seen definitive figures, my back-of-envelope calculations are that diesel will have around 60% of the power of electric, but I stand to be corrected on that.)
Switching back momentarily to a sane system of measurement, your 2.1 MW of installed power will reduce to around 1500 kW at the motors. On electric, assuming the motors are the limit, you would have 2700 kW at the rail.
Ask sprinterguy
Tractive effort and adhesion aren't the same thing. Your extra powered axles help getting off the blocks, where maximum force cannot be applied without spinning the wheels. On clean dry rails, you can apply maximum force at relatively low speeds, even with few axles powered. The distributed motors really help in poor rail conditions, and for regenerative braking.
HSTs have around 2.6 MW at the rail, and will be geared lower than the IEPs, so I think the HST clearly beats IEP on diesel. On electric, IEP will win hands down.
LexyBoy
23 Jan 2009
North of the rivers
That's not performance data though, that's the specification for maximum acceleration permitted by the IEP spec. I'd imagine it's based on the forces that would be exerted on the track by a train meeting the other specifications. (I looked this up earlier expecting there to be some specification for minimum acceleration, but nope).
Thanks.
2.6 MW for a 10-vehicle HST, versus perhaps 1.6 MW for a 5-vehicle Cl 800? (based on sprinterguy's 2.4 MW, de-rated to 2, and 80% of this translating to power at rail).
notadriver
1 Oct 2010
What is the weight of a 5 car IEP set? 250 tons - perhaps more as they are longer vehicles with extra bits ?
Emblematic
14 Aug 2013
Me too! Some hard facts would be good! I agree about the graph being a limit not performance curve, so I only used the inflection point. I took that to be performance based, as I cannot think of another reason why your acceleration would need to start dropping at 45 km/h. Track forces and deceleration will be greater under braking, and more constant from higher speeds. I don't really see why they needed a graph in the spec. at all, to be honest - why not just a maximum acceleration value?
Sounds about right. Also around 2.6MW for the 9-car bi-mode, although that would be a bit lighter than a 2+8 HST. The Scotrail pocket rocket short-formed HSTs will still have 2.6MW and be lighter still - I'm looking forward to them!
