GWR Class 800
Trailfinder
15 Jan 2015
I had a quick trip up to Paddington today to video the changes of the track layout at Westbourne Park on lines 5/6.
800023 was in platform 1 at 1400 and left on a test run just after.
On returning to Ealing Broadway noted several 800s in North Pole, did not record their numbers, but one was 802002.
Trailfinder
15 Jan 2015
Forgot to add, I have taken a 800 to Reading to try them out.
I sat in a table seat, nobody sitting opposite, so their was plenty of leg room - I am 6ft 2in.
I found the seats firm but bearable, my only complaint was I felt that their was something hard poking me in the back and forcing me into an unnatural position. I was unable to rest my head on the headrest part of the seats, thats if there was a headrest there, because the back of my head was above the seat. If this was a car, it could result in a few whiplash injuries in the event of a rear end collision.
I note on the GWR Help twitter account, when there is a complaint about the uncomfortable seats on the new trains, the response is that the seats are ergonomically designed. Why they just don't say that the seats are nothing to do with GWR and have been specified by the DfT, so complaints should be made to them. The Civil Servants at the DfT must all be midgets.
Master29
19 Feb 2015
I know there has been much discussion of the inclusion of foodbars on the Virgin Azumas but off hand does anyone know the first/standard seating in terms of numbers. I do know the Dft draft seating page but I`m guessing that won`t be final. Obviously less standard but more 1st simply because GWR policy.
D1009
22 Feb 2012
Stoke Gifford
Quote pasted from 800 initial diagrams thread.
For Dec 2018 onwards, clearly 800E point to points should be quicker than existing HST 125 timings, but how will the 800D point to points compare? Are any of the 800D timings going to be improved over HSt125 timings? If so, between which points? And I mean net SRT's, not gross timings which include bags of recovery time. Is there any evidence to support lesser dwell times being allowed for too?
I think the more pertinent question is will there be any change to the way the software regulates the power on diesel as more sections are electrified. I somehow doubt whether anyone is allowed to answer that one at this stage.
Railperf
30 Oct 2017
Yes, a very good question. it has more recently been suggested now that 940hp is available to around 30mph and then ramps back to 750hp by around 60mph. But as before - the actual performance figures in real life somehow don't seem to reflect this - or maybe we don't know how to use our abacus's properly lol. Add to that the suggestion that without being upgraded to 940hp the units would not achieve the high 118's on level track - and that would suggest that maybe the 940hp may be kicking back in at higher speeds to stop the alternators stalling or running out of juice. (or something along those lines). More interestingly, how differently will the 802's perform with their outputs not constrained by DfT and TOC maintenance and availability agreements/ contracts?
Noddy
11 Oct 2014
Are there any East Coast routes that are not wired and go above 100mph???
Railperf
30 Oct 2017
No, just 125mph track on the GWML which will remain unwired from Didcot to Bath and Didcot to Bristol Parkway for another year. And sections of 110mph on the Berks and Hants too!
Master29
19 Feb 2015
Master29
19 Feb 2015
I believe it`s 290 standard and 36 first in GWR 5 car units and 576 standard and 71 first on 9 car.
tgrb
11 Feb 2017
I'm on the 10:42(ish) heading to Swansea - I've gone in standard for the first time on a 800 - I've got a table seat with a great view :)
With the seats yes they are firm but definitely comfortable...
Anyway to my point....
They had a problem opening the doors at Newport and once they got moving there was an announcement from the TM asking the Hitachi engineer to pick up the next (something) call..... have they got an Hitachi engineer on all services??
TM has just walked through talking on his phone about a problem with the rear set... it would seem there are still teething issues!
Dai Corner
20 Jul 2015
I don't know whether every 800 carries one, but I've heard several stories about Hitachi engineers being contacted via the PA. I think I'd have found money for a more discreet method such as walkie-talkie if I'd been running the project.
JN114
28 Jun 2005
Probably ‘IC’ call - that’s the legend on the button for making internal (non-cab) calls on the PA. Customer hosts often use it to talk to each other from various points in the set.
JohnRegular
12 Dec 2016
On the 1530 Paddington-Weston Super Mare, my first trip on an 800. As everyone else has said the legroom is great and the train feels fast and quiet.
But I just am not a fan of the seats, I fully expected to be a fan of them as I don't mind thinner seats on the whole. My back is killing me and I've not even been sat for an hour! On the other hand I happily sat for 7 hours on a VTEC HST from Aberdeen. I hate getting on the negativity bandwagon but I think I'll sit on a Voyager for 9 hours next time instead.
Sean Emmett
9 Mar 2015
I suspect reason its so quiet is that there must be at least 2 engines out. Most gutless performance to date. Only 98 max betw RDG DID and barely 100 to SWI.
Filton Bank
13 Aug 2017
IC calls can also be routed to the driving cab - it depends how long the button is pressed for.
Sean Emmett
9 Mar 2015
I was hoping for a pint in the bar on the platform at WSM during the booked 19 minute layover, but by the time we got there it was time to come back...
When I alighted at BRI on the return I confirmed one engine out on each unit (nos 800 006/013).
LunchSociety
5 Jul 2017
Have we heard any suggestions as to why this might be the case? One assumes that this is not a planned "test" but we seem to hear quite often about IEP sets running with at least one engine out. Have these particular MTU engines been used in any other rolling stock?
43096
23 Nov 2015
At the moment the agreement is one Train Manager per 10-car set. A Ticket Examiner will be rostered to work in the front set. If they are not available an alternative member of staff must be sourced or the unit locked out.
The RMT does not want Customer Hosts being used as the competent person in the front set. To be honest I would rather have my CHs taking charge than a TE who I have no responsibility for. CHs are also briefed extensively on the layout and safety features of the train. TE knowledge is lacking at best.
This is the agreement:
But why is this even necessary? We have had two unit trains with no gangway connection between them for years on the railway - including on GW - with no need for this. There is a very simple solution: driver in front 5, guard in rear 5 = suitably trained staff in each part. This is just another example of the railway disappearing up its own very expensive fundamental orifice.
initiation
10 Nov 2014
How did it cope with the mad rush that is the 1717 from Temple Meads? With 5 coaches I always feared this service would end up standing room only
Sean Emmett
9 Mar 2015
We were 20 mins late. Suspect a fair few were on the stopper that should have followed the IET, but went ahead.
So 20 mins late off Temple Meads and emerged from Flax Bourton Tunnel at around 80 mph.
A few years ago No. 9 was doing 74 there with 9 on. Somehow that felt faster....
Does anyone know when the next new class 800 set is due to enter service?
Informed posting on wnxx suggests that 800023 should be accepted on Monday or Tuesday to add to 800005/6/8-15/7/8/20 in service.
There appears to be a gen group 'ietgen' created with workings on groups.io which includes reports of 800s in service.
TT-ONR-NRN
30 Dec 2016
Worcester
When are 9 car IETs entering service? Will the 802 9 cars enter service before the 800 ones? I’ve only seen 9 car 802s. No 9 car 800s (GWR)
DanNCL
17 Jul 2017
County Durham
I think 9 car 800s start operating Cheltenham services in June
I'm surprised that the 9 car units don't enter service until June. There are already complete GWR 9 car 800s at Newton Aycliffe.
I personally think the 9 car 800s will be in use before the 802s
50031
28 Aug 2013
Someone in the know mentioned previously that 9 cars would initially start Cheltenham services in June but eventually that route would see all 3 combinations of IET (5/9/10) when the enhanced timetable commences. 9 cars will eventually appear on other routes in time I presume
