GWR Bristol - Oxford service
Benjwri
16 Jan 2022
Anyone got the timetable for the old Bristol to Oxford service?
Theres certainly demand. People can be put off using rail if there's no direct service as People don't always want to change trains on a journey
I don’t have a timetable, but it was a lot slower because it used a turbo via the loop at Challow which was overtaken. Plus when compared to the opportunities to change st Didcot, with only every other Bristol service now calling, there is far less opportunity to get travel.
jayah
18 Apr 2011
Although only a trial until December, so won't necessarily remain at all after then, and very likely not in the same form.
The timings quoted in the above statement do suggest it will be only part of a units diagram, as it is unlikely to be able to take a platform up at BTM for 2 hours, presumably it is being used for something else in the peaks and between the two runs to Oxford.
How does a trial like this work?
The timetable for December until next year will be final and published before the even trial starts.
Devonian
10 Sep 2019
Totnes
E.g. September 2001, Monday to Friday:
Bristol TMBath SpaChippenhamSwindonDidcotOxford
062006320644070207240743
0715072907410803-0836
090209150926094310081030
100010121024104011051126
112811401153121012321254
133013411354141214371459
142814411454151015311559
154916041617163316561716
172917441757181318381854
185019021915193319542011
1948195920122032-2110
210021122125214122022223
Fewer services on Saturdays/Sundays
anthony263
19 Aug 2008
South Wales
Thank you for that. I think this trial will hopefully prove to be a success as there's demand there for such a service especially if you could add new stations between Bristol and Swindon
Wilts Wanderer
21 Nov 2016
Amazing, that’s far more services than my memory recollects. At a guess I would have said there were 5 or 6 each way!
You can add trains in whenever you want if space is there. Either at a timetable period change or any agreed date via whats called a train operator variation request TOVR (or spot bid in old money)
Mark J
12 May 2018
GWR have announced proposed departure times for 2 trains a day on Saturdays from Bristol Temple Meads to Oxford and back. No information about what rolling stock.
How will that work when Didcot West Junction is required for train service movements, as it was last weekend.
All services going north of Didcot had to reverse up Didcot West to proceed.
Will the Oxford > Bristol service be run with Class 166, due to the lack of overhead power between Didcot and Oxford?
MarkyT
20 May 2012
Torbay
Seems to be 80x which can switch to diesel while stationary at Didcot or on the move.
Benjwri
16 Jan 2022
That’s quite a rare occurrence, but I would imagine they could still fit them through, or if not they would just be cancelled for that weekend.
The trains have contingent rights, so only work if there are paths. If for whatever reason trains need to use Didcot West and these trains were in the way, they would get cancelled off. If they had firm rights then the they go into the mix of NR/GWR deciding which fit and are more important.
Mark J
12 May 2018
I'll rather GWR used any 'spare' sets to lengthen train services that are overcrowded, rather than a new service.
For example. A five carriage 800 set on a Saturday morning, from Paddington to Oxford is not sufficient.
Admittedly the GW mainline west of Didcot was closed last weekend.
However, it was a spectacle watching all these trains waiting to reverse at Didcot West in order to carry on where they were going!
Benjwri
16 Jan 2022
This unit wouldn't be able to be used on a Oxford morning service. It starts in Bristol, and therefore is almost definitely coming from Stoke Gifford, and therefore would be almost impossible to get into place for a Paddington to Oxford morning run, as the split of units between depots, in terms of how many are being provided, is set. It's also worth remembering the Bristol to London services are also hideously busy on a Saturday, and these services will help take some load away from these for people travelling anywhere other than Reading or London. It is also likely to help a bit with Oxford trains and the customers that join at Didcot from the west.
Regardless, for a portion of this time during the Bath Christmas markets this service is likely to run instead of one of the market extras, so at those time no stock will be lost.
The exile
31 Mar 2010
Somerset
The new service will potentially alleviate some of that overcrowding as it basically covers the outer parts of two busy routes without getting crammed with London(and Reading)-bound passengers
Northampton
You can run the trains further to Milton Jn so that you can get trains from the curve direct onto the Mains at Foxhall Jn, not a great problem at all tbh.
The bigger problem is likely to be the cross-platform shunt for the Didcot terminator and only 1 relief line, which I suspect is why the number of reversing moves has been limited. (The shunt can go up to the goods line, but there's still then only 1 passenger-rated line from Foxhall Jn to Didcot parkway, and only access to Plats 3 and 4).
infobleep
27 Feb 2011
Discussed in post 13.
Thanks I missed your earlier comment.
Hopefully it will be reasonably successful this time and the proformance will be good enough, then lwss chance of it being axed in the future.
I no longer live in Oxford so it won't be something I'll be using.
I probably used it 3 times in 1999. One of my trips was before the first train of the day ran, so I changed at Didcot.
DaveHarries
12 Dec 2011
England
Interesting to see this planned restoration of Bristol - Oxford services. My work as a driver for a vehicle hire company means that I can currently do Oxford - Bristol for around £20 single (£2 on the S6 bus from Oxford to Swindon, then train Swindon - Bristol): I wonder if GWR will manage to undercut that.
Dave
Wilts Wanderer
21 Nov 2016
Dave
Probably not on price, but how long does your version take?
DaveHarries
12 Dec 2011
England
Fair point. Would beat it on price but not on time. If I try and do it by train at present leaving Oxford station (where the S6 currently terminates due to the works on the railway bridge) leaving at 1400 tomorrow:
Train:
Oxford to Didcot Parkway: dep. 1409, arr. 1426 (17 minutes)
Didcot Parkway - Swindon: dep. 1438, arr. 1456 (18 minutes)
Bus:
Oxford to Swindon: dep. 1415, arr. 1537 (82 minutes) direct.
The bus also carries a schedule of 3 trips per hour for much of the day until early evening. In terms of price though the GWR app quotes £12.60 whereas the bus would be £2.00. And the bus is scheduled to operate at a frequency of 3 per hour, journey time 82 minutes from Oxford to Swindon during the day as well instead of the 47 minutes offered by the train and that is on the presumption that the trains run to time.
However I live and work in Bristol. If, for example, I get sent to Oxford and have to get back to Bristol TM leaving Oxford at around 1400:
Train:
Didcot Parkway - Bristol TM: dep. 1438, arr. 1537 (59 minutes)
Bus and Train:
Swindon - Bristol TM (Train): dep. 1555, arr. 1635 (40 minutes) direct.
So the train is, of course, quicker than the bus on both counts. In terms of fares:
Train Only: £28.10 Single
Train and Bus: £21.10 on single tickets
So not a massive saving from Oxford. If I am coming from Banbury (which I sometimes get sent to):
Train:
Banbury - Bristol TM: £38.50
Train & Bus:
Banbury - Oxford: £7.10 (Train)
Oxford - Swindon: £2.00 (Bus)
Swindon - Bristol TM: £19.10 (Train)
Total: £28.20
So saving by using the bus from Oxford to Swindon is £10.30 compared to doing it only by train. So the savings are not that huge and I know that. But when I have got on at Oxford station I have tended to find that I am not the only paying passenger doing the bus trip end-to-end.
Dave
Busaholic
7 Jun 2014
The proposed timetable is only of value for passengers travelling from Bristol to Oxford for a few hours, and not the other way round as implied by the GWR 'spin.'
Benjwri
16 Jan 2022
It’s a trial though, the whole point is to gauge usage and see whether people would use it, and if so how many, with the current fleet restraints and without spending too much.
The success is gauged by comparing it to usage on the route changing at Didcot/Reading before the change, or similar.
156444
28 Aug 2020
The Didcot terminator normally uses Platform 5 on a Saturday rather than shunting from 3 to 4, so I don't think that would be an issue for the trial
lachlan
11 Aug 2019
Thanks for sharing - it only appears to save 10 minutes versus changing at Didcot. That being said extra trains are always welcome and we're looking forward to visits to Oxford and perhaps Bicester too with fewer changes. If successful, they'll provide valuable connections to East West Rail too
anthony263
19 Aug 2008
South Wales
Donto be surprised to see east-west services run through to Bristol TM. Saves terminating at Oxford
John R
1 Jul 2013
Really? That would require an extra 5 diagrams at the very least, possibly 6, if all services were extended. That would approximately double the running costs of the service, if stock was even available.
Benjwri
16 Jan 2022
Not to mention a bunch of paths via Bath that don't exist.
