GWR Brighton services axed from May timetable change
mrcheek
11 Sep 2007
You'd be very surprised - it's regularly full and standing from the Gloucester/Bristol end and right the way through. A handy link for the elderly to save them trekking across London.
I personally would rather see one of the Weymouths cancelled.
Weymouth has services every two hours, with no alternative. Would be daft to reduce that even further
BayPaul
11 Jul 2019
But they still won't need to go via London. There is an hourly service from Bristol to Portsmouth, with a number of opportunities for same platform changes onto the equally regular Southern services along the coast.
Bishopstone
24 Jun 2010
Seaford
With a second change required for destinations east of Barnham, albeit same platform again.
HamworthyGoods
15 Jan 2019
That is in the current temporary Southern timetable that runs at the moment, the GWR changes happen in May by which time Southern are planning to revert to the previous direct Southampton to Brighton service.
BayPaul
11 Jul 2019
At present. If the coastway timetable goes back to pre-covid, then presumably Brighton - Southampton and Brighton - Portsmouth semi-fast services will return at some point
geoffk
4 Aug 2010
Exeter
Maybe DfT see it as one of the many forthcoming ways of reducing diesel miles on electrified routes. Look out for more.
If not Brighton, where will the GWR service terminate instead - Southampton or Portsmouth? There's no SN Southampton - Brighton service at the moment, just to Littlehampton.
Dr Hoo
10 Nov 2015
Hope Valley
It can't do much for the 'ambience' to be wedged in a packed DMU all the way from Gloucester to Brighton even if someone has kindly given up their seat for an elderly fellow traveller.
TheBigD
19 Nov 2008
Whilst not in Southern/GWR land, could we see things like XC cut back to Cambridge instead of Stansted Airport with that but of the service covered by GA services?
Graham H
16 Apr 2018
Not seen it mentioned but the early morning service which effectively gets the unit to Brighton serves a number of the smaller stations between Portsmouth and Brighton and has been a very useful work/school trip and a most unusual way to travel
But surely not GWR’s problem. SN should be providing both calls and capacity.
If we’re looking at the only weekday eastbound service, the one that starts 1041 from Great Malvern, then it terminates at Warminster from May 16th:
https://www.realtimetrains.co.uk/service/gb-nr:C38335/2022-05-16/detailed
ValleyLines142
25 Jul 2011
Gloucester
Exactly. Most of the time it's a 3-car 158, although one day last week it was a 2-car 165 with no tables and 3+2 seating - absolutely dreadful.
Graham H
16 Apr 2018
And they will. As far as I recall, the GW service actually took a path from Southern years ago (10 or more) in return for serving the smaller stations that the original path used to stop at rather than running ecs. I was more commenting on the unusual opportunity to travel from some of the smaller coastway services using a GWR 158 or now a 166
JohnRegular
12 Dec 2016
I suspect a regular (even 1tp2h) Bristol-Brighton service would be well patronised, including a decent number of end-to-end journies, and if it existed now I doubt anyone would want to see it axed. But we don't live in that world, and GWR needs every last carriage it can get working on its core routes. A single same-platform change is perfectly acceptable really.
woolos
5 Oct 2018
Brighton will still have 2 cross county route to the rest of the the county .Peterborough and Bedford.
Kite159
27 Jan 2014
West of Andover
Don't you mean Cambridge instead of Peterborough?
Unless Thameslink are changing things so it's Brighton to Peterborough & Horsham to Cambridge?
Are you suggesting full and standing from the Bristol end, all of whom are passengers for Brighton? Ie few people alight at any of the intermediate stations, and by extension there is no room for anyone to board at them either?
ValleyLines142
25 Jul 2011
Gloucester
I can't comment on passenger loadings for every single station, but I've spoken to a lot of passengers (I work at Gloucester station) and they've stated that they're travelling to the south coast.
Hopefully, a simple cross-platform interchange is an adequate replacement.
virgintrain1
29 Jul 2011
Today I travelled Bristol to Brighton return. I'd say about 30 % of the original Bristol and Bath passengers were still on east of Fareham. Full and standing east of Southampton in both directions. The direct service saved me about an hour due to the current Southern timetable.
trainmania100
8 Nov 2015
Newhaven
Brighton isn't just losing its gwr service , it's losing its only fast service along the west coastway. I guess there's quite a few slow services along the route maybe not enough space for a fast train, maybe no need for a fast train, but for the people that do go to Portsmouth and Southampton the full way, there needs to be more than just a 90 minute stopper
Peregrine 4903
18 Aug 2019
That's only because of the Copyhold blockade this week.
Also, Brighton - Southampton/Portsmouth services are returning in May.
Peregrine 4903
18 Aug 2019
The GWR service had so much pathing time, I wouldn't exactly call it fast.
Towers
30 Aug 2021
However, all the 'smaller' station calls were omitted if the booked unit was a two car rather than three, so if travelling to/from those stations the service wasn't entirely reliable.
25 Jan 2021
Bristol
I realise mine might be a lonely voice, plaintively piping up to say that I shall miss these services, having used them to connect to Gatwick Airport via a convenient, level interchange at Brighton. Certainly a much more leisurely experience compared with the ruck-and maul of the Circle Line from Paddington to Victoria, or (the one occasion of) dealing with the ticketing “GatExtapo” who didn’t believe a First Class open return between Bristol and the airport could possibly be valid on his service.
Still, I suppose the decision is one of those that we will increasingly see, as bureaucratic tidiness starts to take increasing precedence over what the market would actually like!
route101
16 May 2010
Most (but not quite all) weekends between now and the May timetable change, the Brighton trains won't be running anyway, usually due to some engineering work and bus replacements somewhere along the route between Westbury and Fareham. With that level of uncertainty over whether the trains would actually run at all, it was surely only a matter of time before they were pulled completely.
Yes, I was looking at doing GWR to and from Brighton, services never really operated at the weekend. Only the chance during weekdays?
Brighton to Southampton service, is that getting split too at Barnham?
