GW 769s to Scotrail?
Deepgreen
12 Jun 2013
Gomshall, Surrey
First thought would be component recovery for 318 / 320 but the wrong ownership for that as 769 are Porterbrook, 318 and 320 are Eversholt, so that can probably be discounted as a theory.
Oh, what wonderful flexibility and efficiency privatisation brought...!
Stop gap involves training staff for short term use. That doesn't sound cheap to do.
Are the 769s better than 156s? There would no doubt be a period when the 769s lead to an unreliable service.
GWR couldn't get them into service after years, so very doubtful if anyone else would even try.
43096
23 Nov 2015
There's probably rather less in common that you might think. 320/321 being bog standard 25kV AC units with Brush electrical equipment and thyristor control, whereas Class 319 has GEC traction systems using GTO choppers.
fgwrich
15 Apr 2009
Hampshire
GWR could have and nearly did as @Clarence Yard has said previously (At least 6 units if I recall were ready to go) but the DfT pulled the rug out from under everyone's feet citing post covid costs. So, no doubt Brodies (now partly owned by Porterbrook) will have picked form those 6 and with both Brodies & Porterbrooks combined engineering expertise, might actually be able to make them work reliably and successfully.
Senna1210
30 May 2019
The units are in good order and it would be a sin for them not to see operation in more than one form or another going forward.
Energy
29 Dec 2018
The DfT received the same amount of money from the Treasury but had a real term cut due to the high inflation from the Liz Truss mini-budget. Operators were told they would need to cut costs, for GWR cutting the 769s (or not extending the lease) is an obvious choice.
To be fair to the DfT, they don't decide how much money they get.
20 Mar 2012
After shuttling between kilmarnock and barassie over the past few weeks. The 769s appear to going even further this week with a trips on the ayrshire coast this evening before returning to kilmarnock tonight via Glasgow central and barrhead
RJMC
21 Nov 2018
My son wanted to go and see it for his YouTube channel so we managed to catch it going through Lochwinnoch, I have to say it’s definitely not Scotrail blue, it’s slightly darker. Not sure if I’m allowed to post a link to the video here or not
Anonymous10
19 Dec 2019
wales
The forum certainly wouldn't have an issue from what I've seen in other threads.
collosus
2 Mar 2024
Milton keynes
Please let me know the channel name
RJMC
21 Nov 2018
Here is the video, channel should be accessible from the link as well
ToddMeister
26 Apr 2024
If it's in the location I suspect it's in, it's very close to the running line and signal stops adjacent to the place are fairly common, so he'd likely have plenty of opportunity?
Brodies is directly next to the running line at Kilmarnock. Units are easily viewable when arriving and departing station either from Glasgow direction or the Barassie branch line.
Alpool10
7 May 2024
Ayrshire
From my house (right next to the old laigh milton viaduct) I keep seeing late night (11pm-midnight) movements passing over the bridge towards Gatehead level crossing and on to Kilmarnock, trains look far too long to be ScotRail moving stock and don’t show up on Real time trains. Given the passenger services between Kilmarnock and Ayr are not current running, could it be late night testing of these units? It’s always too dark to take a look through the binoculars!
pokemonsuper9
20 Dec 2022
Greater Manchester
Are you able to hear them?
With the electric motors they'll make quite a different noise to the usual trains.
warwickshire
6 Feb 2020
leamingtonspa
37884 5q23 0939 Long Marston to Doncaster Wagon Works with 769935, 4 minutes late Through Barnt Green, is this possible its going to Doncaster Works for onward use by Scotrail ie overhaul etc ???. Any information please is much welcomed. Thank you Kindly Warwickshire.
twpsaesneg
21 Jul 2009
The "Test Trains & R.T.C. Photography and Gen Group" has a post suggesting that the move to Doncaster Wagon Works is for repaint, which sounds hopeful for future use.
Link to post on above mentioned FB group
The_Train
2 Jun 2018
Seen it suggested that 935 has been earmarked for a freight (presumably parcels) overhaul for a FOC
