Guided busway or "tram" in Caen, France
starrymarkb
4 Aug 2009
Exeter
I understand the system ended up costing almost as much as a tram, but has been far more troublesome.
Nancy has a similar system IIRC
Anon Mouse
20 Mar 2011
Would that be classed as a monorail? (apologies if its a stupid question!)
WatcherZero
25 Feb 2010
A monorail is when theres a single rail guiding and supporting the weight of the vehicle. These are commonly called Rubber-tyred tram's or Guided Bus systems.
Anon Mouse
20 Mar 2011
Thanks for the explanation!
Looks like a giant Scalextric set. I'm not too sure if I like it!
WatcherZero
25 Feb 2010
What can be confusing is there is another type of system where the track supports the weight of the vehicle and provides power while rubber tyres actually guide the vehicle round corners and such without bearing any of the vehicles weight.
starrymarkb
4 Aug 2009
Exeter
Not that I'm aware of. Closest thing to that description would be the Paris Metro, (where the Rubber tyres are used for traction, but share support with steel wheels on the guide rails)
VAL systems (Lille, Toulouse etc) use rubber tyres for support and guidance
Edit - unamericanise my spell checker!
WatcherZero
25 Feb 2010
You would for example see that on a rollercoaster or monorail in a station. Similar too boat rides guided by rail have wheels for avoiding structures in the water.
Was this the system that led to damage to the road surface as the busses were following exactly the same path to the milimetre every single time?
