However can that TOC get away with full red gangway doors?
Lets try this one. I suspect it will be as easy as most of my other ones.
I wouldn't be so sure. 43?Thank you.
I believe the yellow front is no longer mandatoryHowever can that TOC get away with full red gangway doors?
Indeed it isn’t,but red? Surely a distraction to oncoming trains.I believe the yellow front is no longer mandatory
Not a 43.I wouldn't be so sure. 43?
Sorry, it is not a 444 either.444?
Not a 375.Is it a 375?
As for the red on the 197... isn't that just the blood to go with the "Dracula" fangs hanging down at the sides...?![]()
Sorry, not a 165.165?
Not a 331
It has not been suggested but it is not one of them.Has a 450 been suggested?
No. Another hint: The train may not necessarily be blue.333?
377?
Both incorrect. This particular class does not have a gangway.Am I right in thinking that it is gangwayed?
If so I’ll submit a 387 as another electrostar.
313?
Yes i meant that. Sorry for not clarifying.313's are gangwayed within set. Unless the OP means there isn't a gangway at the front/rear
Ah, 221?A little newer. Built in the early 2000s.
You are correct that silver pole is not part of the trainAh, 221?
I think it is a door and the silver pole isn’t part of the train at all?
Both incorrect. Someone was really close with one of their guesses.222?
220?Both incorrect. Someone was really close with one of their guesses.
Not a 220. Some post further up is really close.220?
