To answer the OP’s question, the driver may have requested the green flag/light was shown again, for example if they were not ready to see it, or didn’t see it clearly the first time. Or there could have been some other issue and the guard was confirming it was still safe to leave after a brief pause.
It varies by train, station and operator, but generally platform staff show bat to guard to say platform duties complete. Guard acknowledges this by wave/flag. Guard then locks doors. Guard then waves/flag to say doors locked. Platform staff raise bat to say “right away” guard signals driver, train departs. If buzzer not working platform staff can repeat guard signal to driver at some locations in some circumstances.
That’s a really garbled way of putting it. In fact, you’ve got it all mixed up.
Where platform staff and a guard
(or conductor, train manager or other person fulfilling “guard” duties per the Rule Book) are working together for dispatch:
- The starter signal (where provided) and time must be checked by all concerned to ensure the train is permitted to leave.
- Any slam doors used by passengers must be firmly closed and nobody must be in a position where they can interfere with safe movement of the train.
- Platform staff provide the first “tip” to the guard when this station work is complete; the signal being a raised white dispatch bat, white light (in many enclosed station areas, or in darkness/fog/falling snow), or other clear handsignal as agreed.
- Guard acknowledges this, and closes power doors or locks the slam doors, depending on stock in question.
- The guard will still have their door open - the local door - which may be a crew or passenger door, depending on required procedure.
- The platform staff and guard will then complete the “train safety check”, to ensure all other doors are closed and locked, any Bodyside Indicator Lights not related to the local door are extinguished, the dispatch corridor is clear, and the starter signal has not changed to indicate a more restrictive signal aspect.
- When completely satisfied, the platform staff will provide the second “tip” with the white baton/light, which the guard will acknowledge, step onboard and close their local door. (Nb. The guard will not provide any indication that they believe the safety check is complete before the platform staff do.)
- Depending on procedure, the guard will then
EITHER drop a droplight window and show a green flag/light,
OR give the driver the correct signal on the buzzer (usually, but not always, 2 buzzes).
- If the platform has Right Away (RA) indicators, these are used to repeat the green flag indication to the driver. If the driver cannot see the flag/light indication and no RA indication is available, the platform staff will relay the signal by positioning themselves to show a green flag or light to the driver.
- The guard and platform staff will then observe the train’s departure, intervening to stop the train if there is an emergency.
Further note - there are plenty of locations where there are platform staff and RA indicators, but where the buzzer is usually always used on trains with guards...
(unless it fails, or the stock is not fitted with one, in which case you always default back to green flags/lights or an RA indication. In these locations, the guard showing a green flag will be very rare indeed. This may have been the case with the HST mentioned.)
Further note 2 - guards are not typically permitted to authorise departure by voice, except on certain specific types of heritage stock, which is why unambiguous flags and lights are used, not telephone communication.
