Grove Park light railway
theageofthetra
27 May 2012
Beckenham
Since starting at this depot I have often thought the drivers lengthy walks could be aided by a minature railway in the yard up to the station! Joking aside I have two questions
1) There was a narrow gauge railway built in the 20's to assist the construction of the nearby Downham estate-are there any remains or bits of rolling stock left, & where did it join the main line?
2)Did any rail depots have narrow gauge railways for the movement of staff (as opposed to the movement of equipment e.g Horwich)
Thanks
Found this pic online but can't really place where it is? It also looks standard gauge- I suspect ex WW1 narrow gauge field railway equipment was used in the construction areas.
http://www.ideal-homes.org.uk/__data/assets/image/0014/305060/under-construction-01584-750.jpg
I'm sure your suspicions are right. Andrew Hajducki's book "The Railways of Beckenham" has a section on the Bethlem Hospital project which had the same combination. In fact it could even have been the same stock?
I'm pretty sure the photo is taken N of Grove Park, looking over towards Hither Green Cemetery, in which case the bracket signal would be for the Bromley North branch platform, but not sure how far N as the area has changed a great deal in the 30 years since I moved away, let alone since Downham was built. Somewhere opposite the southernmost car shed?
