Greater Anglia Class 755s (Regional Trains)
AC47461
13 Feb 2017
RAYLEIGH, ESSEX
Thanks for the detailed info. There is another problem, both bay platforms are used by the Southminster branch trains. To allow easy cross-platform interchange the up bay is used in the AM & the down bay in the PM. A widened embankment & new single track bridge over Wickford High Street would only allow access to a lengthened down bay.......
With the current rush-hour schedules the branch only needs one 10 car 720 duty (replacing the current 12-car 321), it would need SDO on all the branch stations except South Woodham & probably a 2nd crew member for despatching duties.
To be honest, an it's only my opinion, I'd be surprised if any embankment widening would happen. There appears to be room but it's a bit of a squeeze, although the up side could probably be extended without the need for a larger bridge over the High Street as it already sits further back than the down side (I'm sure this has been mentioned before).
Class 170101
1 Mar 2014
On ASDO Front, that is only permitted if the front of the train is not beyond signal, and signal is at end of platform at Elsenham, Enfield Lock, Ware, St Margarets and Hertford East. Relatively simple job to move signal in some cases, but they need to get a move on
Why? Isn't Witham station beyond the signal for 12 car workings on Platform 4 heading country bound? In terms of Hertford East the whole thing needs rebuilding.
rdlover777
4 Feb 2014
Kent
I'm no rolling stock expert but I'm sure Bombardier could come up with a 8 car length equivalent subvariant of the 720, or even Stadler could make an 8 car long version flirt. Personally however I reckon for Wickford it'll be 4 car bimodes, and for the Hertford Branch will be 5 car 720's, after all apparently there is supposed to be an additional Hertford per hour in September which might go some way to counteract the loss of coaches until such time when the infrastructure works can be completed.
The stations mentioned above with crossings etc will use ASDO Front, like on the Braintree Branch where the front of the train stops beyond the platform so as not to block the crossings in rear.
I couldn't help myself and made a 8 car varient of the 745 with 755 intermediate cars
dp21
10 May 2017
GA is not ordering any new stock beyond the 745/755/720 orders, its haemorrhaging money at the moment as it is. A handy go-everywhere (electrified) unit like the 379s are better kept and make sense to clear and train drivers to fill extra Liverpool St - Norwich, Liverpool St - Stansted, Liv St - Hertford East and Shenfield/Wickford Southminster routes that the Aventras are too long for and the Stadlers are too far away to diagram easily. For a while I've been suggesting this and its beginning to make more and more sense. Cheapest option out there.
Interesting first section. Why would they order anything more when they're replacing the entire fleet? Also, why keep the 379s when it's actually cheaper to lease a 720. Besides, to make the stock homogeneous makes sense from a maintainability perspective.
Have you sat in the real one yet?
I've been fortunate enough to on several occasions and I tell you now they're a much nicer place to be than my office.
Wivenswold
24 Jul 2012
Essex
Nice idea but they'll be waiting until at least 2023 as there are a number of other operators waiting for their Aventras. So they have to keep Renatus 321 or 379s. Having bleated on about fleet renewal, GA will have a tough time explaining why 30 year old trains are staying. The 379s could be maintained by Bombardier at Ilford and they're cleared for WA and many GA routes too. Unless there's a plan C, the 379s are most likely to be the "legacy" fleet for GA for some time to come.
MrPIC
30 May 2015
Apparently the leasing costs for 379s are astronomial, I'd wager a different fleet staying, or a new (old) one coming
samuelmorris
18 Jul 2013
Brentwood, Essex
I agree, there's a good reason why the 379s weren't kept in the first place. If they thought that was an option they'd probably have done so to begin with.
delticdave
13 Apr 2017
Essex UK
I'd prefer that they keep the 379's, it would be a nice upgrade for Southminster branch customers.......
TT-ONR-NRN
30 Dec 2016
Cambridge
I suppose it wouldn’t be possible to remove a carriage from one or two five carriage 720s and keep them for the Southminster? Ala Gospel Oak 378s.
samuelmorris
18 Jul 2013
Brentwood, Essex
That was an emergency temporary arrangement though. Such may be necessary to mitigate the delays to NR work on the West Anglia side but for Southminster it'd probably need to be permanent.
I think they might also need to be 3-car not 4, as a 4-car 720 will still be 20% longer than a 4-car 321.
RailWonderer
25 Jul 2018
All around the network
The 379s were ordered in mid 2010 for late 2010, early 2011 service when we were just recovering from a devastating recession, where lease costs were high, a la 350/2. NX only ordered them to meet a DfT obligation to replace StanEx 317s and so that 12 car peak services could be introduced, NX knew they were losing the franchise and acted like it, and only ordered what they had to. Still, 21 360s isn’t enough and they aren’t even cleared for WAML and can’t run north of Stowmarket unlike 379s. 321 renatus units are the realistic but less favoured option.
Wivenswold
24 Jul 2012
Essex
The lease costs were high for the 379s but the current lease ends next year and with a flood of nearly new rolling stock with few obvious homes to go to, then I would suggest the next lease would be on significantly better terms. It may be that the original lease has ended already or was extended with amended terms either way, we'll be able to say "How much?" Before wandering over to look at the Class 350/2s in the showroom opposite.
rdlover777
4 Feb 2014
Kent
does anyone know what happened to 745001, 745101-103 and 755401-404? since 745002-03, 745104 and 755005-018(?) are here
MrPIC
30 May 2015
Renatus 321's are my front runner to stay on the GE and as much as I said the leasing costs are huge for 379's, I do reckon they'll start to replace 317 diagrams on WA as soon as 745's replace them on airports. There's also the ongoing mystery of the lone 317 unit sent to Scotland for PRM mods,maybe it's time to send a search party as nobody seems to have heard anything about it! Maybe they also realised that they mustn't disturb the delicate blend of rust and gaffer tape holding them together
superalbs
Verified Rep - Superalbs Travels
3 Jul 2014
Kraków
745001 is at Velim. Saw it on Wednesday!
I think they were putting sandbags on it, or taking them off, but there were some forklifts around it.
Carlgoss
24 May 2019
Ipswich and Norwich
It's not April 1st is it? Did you hear the one about the Stadler that was delivered minus seats? It's a story on the street, but doesn't sound like Swiss QC!:lol::lol:
Also I note the Trowse sidings storage is moving ahead again, new barriers have gone in and the ground cleared. Can't imagine they'll get more than a couple of sets in there? Just hope the grafitti person 'Spook?' is long gone by the time they start using it.
samuelmorris
18 Jul 2013
Brentwood, Essex
Still find it odd how they started sending XXX X04 first
It seems fairly standard practice for the first few units to stay with the manufacturer longer than the rest, I assume usually because they're fitted with extra test gear that has to be removed before they can be delivered to the operator.
