Greater Anglia Class 755s (Regional Trains)
Dave1987
20 Oct 2012
Why not? Through a combination of water and oil heating and glow plugs and similar heating elements I see no reason why the block could not be kept at the optimal temperature.
Cylinder bore experiences temperatures of up to 600 degrees on the ignition of the fuel vapour. Last time I checked even when you pressurise water you can only gets its boiling point up to 120 degrees. And the water jacket is what surrounds the cylinders :rolleyes:
You can use heater plugs to get closer. But surely that cycle is going to occur anyway, both between ignitions of the fuel and on the overrun, when in a car engine no fuel is injected?
Dave1987
20 Oct 2012
Heater plugs are designed for short time to ignite the charge until the cylinder block is at a temperature where the fuel will self combust under pressure. Unless you have fuel vapour being ignited in the cylinders you will never keep the cylinder block at optimum temperatures. As soon as you slow down or stop the combustion process the cylinder block will be cooling down. How and when the engines are used or the thermal cycles managed will be key to the wear. If an engine is going to be fired up you might as well use it for a decent length of time which I expect will be the case for the lines they will be used on.
As someone totally ignorant in such matters, can you please explain what is needed, why, and what such specially designed and tensioned OLE looks like?
I ask this because I remember travelling across LGV Nord between Calais and Lille on a Eurostar some years ago, and I was in the front coach and able to see the shadow of the leading power car and its pantographs; at one stage, the driver dropped, then raised, then dropped, then raised a pantograph for some reason, there being reasonable time gaps between each action. By observation, the OLE seemed to be to the same design when the driver undertook these actions as elsewhere on LGV Nord.
Or is it that all LGV OLE is designed so that pantograph raising can take place anywhere on the line?
All LGVs (including HS1 which is designed to French LGV standards) have a level contact wire tensioned at a much higher force than on the GB main line network. So in theory it is better able to withstand pantograph raising at speed.
24 Jun 2014
Derby
Thanks for the explanation
Railperf
30 Oct 2017
That is not theory ..that is based on almost 40 years of running TGVs..and many more years of running dual voltage locomotives that need to pan up and down on the move when switching from 25Kv AC to 1.5 Kv DC power supplies.
Checkout this video at around 2 min 45 secs. A double TGV consist raising 4 pantographs simultaneously at speed under 1.5Kv DC catenary
twpsaesneg
21 Jul 2009
I don't think anyone is disputing that the LGV wiring spec is not able to withstand this, only that the UK legacy systems running at substantially lower tensions and with wire grading into and out of bridges and level crossings would perform badly with a risk of damage to both infrastructure and pantograph.
We can and do use pan down coasting on the East and West Coast main lines, with pan back up at speed but the locations are carefully assessed and it is currently only used in limited circumstances.
With respect to the changeovers that could be used with the FLIRTs, I believe it will be more likely that changeover occurs during station duties to start with.
hwl
5 Feb 2012
The designers of Sizewell B have a different view, they operate with water (liquid) at 315C and about 60C below boiling point, you just need to pressurise it a bit more!
samuelmorris
18 Jul 2013
Brentwood, Essex
The designers of Sizewell B have a different view, they operate with water (liquid) at 315C and about 50C below boiling point, you just need to pressurise it a bit more!
Indeed, quite a lot more. 150 bar! You'd struggle to fit the equipment for that inside the UK loading gauge...
Railperf
30 Oct 2017
Yes..the UK 'knitting' - HS1 excepted - isn't the most robust in the world lol.
As with all these things - the benefits of panning up and down will be assessed along with the risks and costs. If panning up and down allows greater capacity on the network and quicker journeys - then i guess certain sections could be beefed up to allow that if the payback covers those costs.
jopsuk
13 May 2008
you would only really need a few select sections:
1. A short bit of new wiring between Coldham's Lane and Coldham's Road in Cambridge- would not be too challenging given the low speed though care because of tight curve
2. A short section at Norwich between Loddon Road and the mainline
3. A section east of the eastern entrance to Crown Point
4. In Ipswich, between the mainline and the bacon factory curve
5. In Peterborough, from under the mainline
This would allow units to approach, layover and leave stations in urban areas on electric power. It covers most changeovers. The remaining ones are:
1. Ipswich-Peterborough - no benefit to being able to use electric power through Ely
2. Norwich-Cambridge- Pan up during stop at Ely
3. Peterborough/Cambridge-Ipswich- Pan Up during stop at Stowmarket
4. Sudbury-Marks Tey - just run as diesel
twpsaesneg
21 Jul 2009
The difficulty is most if not all of these areas are in locations where there is already high driver workload. For a changeover section the driver needs to be in an area where he's not already occupied with other things, like AWS, signals, speed restrictions and the like. There also needs to be suitable length of wiring for the changeover process to start and have enough time to stop the train whilst still under the wires in the event of the diesels not starting up.
For Ipswich and Norwich the balance of operational convenience and cost probably falls to putting units onto hotel power on the wires whilst on layover only and then starting off on diesel.
Peterborough platforms 6 and 7 aren't wired at present, and I suspect the wiring solution for the intersection bridge would be tricky so I can't see any expenditure being authorised there.
Don't get me wrong, I would love to see more wiring and more use of existing infrastructure, but I'm not sure the benefits from trying to get very small amounts of wiring used is worth it - we'd be better pushing for more strategic wiring like Peterborough to Ely and Ipswich to Felixstowe.
trebor79
8 Mar 2018
Yep. Higher pressures actually mean smaller machines. Hence the very high pressure hydraulics used on the 787, actuators, piping etc are all tiny as a result so there's a weight saving.
AlexNL
19 Dec 2014
I agree there’s no technical reason. Cash is another matter, as building and maintaining strengthened sections for (potentially) small savings in fuel may be rather overkill. Someone will do the maths no doubt.
If a relatively tiny enhancement to the OHLE helps to improve the air quality in and around the station, the city council might decide to make some funding available.
But the trains can pan up in the station when stationary at any time. And pan down on the move is fine. So the only air quality / fuel saving would be for the minute or two the train is under the wires entering the station, when the train will be generally not taking power.
For the same amount of cash as building the strengthened OLE, the city council could buy a decent fleet of electric buses which would do far more for air quality.
So all things considered, extremely unlikely.
