Greater Anglia Class 755s (Regional Trains)
720144
26 May 2024
uk
Today the 10.00 formed of 3 x 755 held up A late running freight let out of Colchester in front of 1P18. And looks like the crossing at Stowmarket was slow to close too on that run. There seems no sense in sending out the freight first. That made 2 trains late!. The Norwich woukd have kept time if it had been let through first. Lost lots of time following all the way to Ipswich.
The 12:32 Norwich to Liverpool Street is 11-car but incorrcectly shown on RTT as a 4-car.
The 12:32 will still be formed of the same 11 coaches, they don’t bother changing it over for a single 4 car unless a random train fault occurs for a 745 like last week. Might be a glitch.
Railperf
30 Oct 2017
Out of Interest, are the 755's restricted any power draw from the OLE when coupled as a triple unit - either automatically or drivers being asked to use a lower percentage of power when moving off?
Freight stuck behind 2F36 in Colchester P1 which was early with its slack schedule of excessive SRTs and engineering allowance...
Well the freight was due out at 1031 before the the Colchester service even arrived. So either the freight was not ready to start or the signaller / luminate cleared the early Colchester service through? But why would the signaller do that knowing he is risking creating a delay?
13 Jan 2024
Cambridge
It says 11 coaches now
I think dk1 said before that the train works that out itself
800301
29 Dec 2022
Essex
The delay is down to the signaller, not releasing that 4L66 was late as it was not in ARS, by the time it was noticed, 2F30 was already in P1
Railperf
30 Oct 2017
But then it still doesn't explain why the signaller then stuck the freight in front of a class 1 express. Why not wait until 1P18 was through? There was nothing due immediately behind it to stop the freight going out.
dk1
2 Oct 2009
East Anglia
Yes it takes what it needs. Nobody has ever told me how much power I should take, not that I’d listen anyway :)
Siggys have lots to do, especially on Colchester workstation, and occasionally make decisions which, in retrospect, were not perfect.
Railperf
30 Oct 2017
Siggys have lots to do, especually 9n Colchester workstation, and occasionally make decisions which, in retrospect, were not perfect.
Would the freight driver not have been contacting the box if his signal had not cleared as planned?
800301
29 Dec 2022
Essex
They did and questioned their departure time, I guess as mentioned above the signaller had other things to deal with
Railperf
30 Oct 2017
So does that suggest the box is understaffed? It must have been an exceptional incident for the staff to be so distracted. Why was ARS not able to signal the freight out.
306024
23 Jan 2013
East Anglia
In deciding whether to run the freight or not, there were 5 other trains between Ipswich and Derby Road alone that were in the mix. All on bits of single line. Get that bit of railway wrong and the delays could easily be far greater than that to the Norwich train.
Railperf
30 Oct 2017
Oh. That's interesting. RTT only seemed to indicate that there were some freight cancellations, and the trains that did run along the Felixstowe branch seemed to do so on time and even early. SO I am a bit confused.
So it sounds line more capacity is needed (doubling) to absorb freight issues / delays/ cancellations.
Has the freightliner depot absorbed sidings that could have been used as a buffer for incoming/outgoing trains.
26 May 2024
uk
Yes they don’t bother changing it around for a single 4 car to do the 2nd run of the day to London & back. It makes sense to keep the same train on running all day.
I’m surprised they have the 3 car unit in the middle instead of leading on the London end. Instead both 4s are at front & rear. There must be a short distance with the middle & front pant, a bit unusual to see that happen.
dk1
2 Oct 2009
East Anglia
The units automatically set which pans to raise at least 80m apart and will select diesel on a unit if less than that. Very rare that happens however.
Railperf
30 Oct 2017
Surely there is enough time - and there is a triangular track formation to allow the formation to be formed to prevent that unless a last minute unit change has to be made and it happens to be the wrong way round to run on leccy? I would imagine control try to keep a certain amount of units with pans at various ends based on the diagrams they wish to form.
13 Jan 2024
Cambridge
755/4s have 2 pans and they can turn units around quite easily
Also I think the units turn around quite a bit (Ipswich - Lowestoft - Norwich)
dk1
2 Oct 2009
East Anglia
Some of the Felixstowe route has been doubled already
Works very well too. They did a decent job with that.
It’s just alll incorporated into the software.
They do. Back on the day there was a ridiculous plan to keep 1st class at the London end. It lasted less than a week :lol:
13 Jan 2024
Cambridge
Looking at journey check I see that most trains are the right way. Also I saw on opentraintimes a train that left Norwich, went into the Trowse (?) siding, went down the Wensum Curve and reversed again back to Norwich in the about 45 mins they lay over there. So it looks like they do turn them around sometimes
dk1
2 Oct 2009
East Anglia
NVS. Are you sure it was the same train?
720144
26 May 2024
uk
I know, only 10 745/0s have first class the best upgrade your going to get for the rest of the fleet running an intercity Norwich service on a 745/1 & triple 755 is a table at every seat with the comfy standard class seating & an at seat catering trolly service. At this point you’re better off removing first class & the cafe bar off all the 745/0s for flexibility on the whole Anglia network precisely.
Yes that’s happened quite a bit this year when you get the reverse formation either they reverse at crown point & vic sidings or possibly at Stansaid junction. When drivers switch cabs on the 745/s I’ve noticed the rear pants always switch around to the other end.
Railperf
30 Oct 2017
Surprised to see the ACPO board on the up main after passing Trowse Jn. I would have thought everything starting from Norwich or CP would already be on electric.
Also is it my imagination or have there been a few new banner repeaters installed lately either side of Ipswich?
dk1
2 Oct 2009
East Anglia
755s leaving much of Norwich Low Level or from platform 6 would be on diesel. They are not allowed to stop as they exit or at Trowse Bridge to raise so do it in this area since it was introduced a couple of years ago.
No new banner repeaters.
Railperf
30 Oct 2017
Thanks for the info, i guess it keeps things moving and probably prevents risk of an issue if the unit stopped and then couldn't get started again at that busy location.
dk1
2 Oct 2009
East Anglia
Until those locations got introduced we had to go on diesel all the way to Ipswich as stopping to raise pan was not permitted incase of causing delays to other services.
No shunting in the Norwich station or Crown Point areas is permitted on electric either.
Railperf
30 Oct 2017
Yes, that makes sense. What a waste of diesel fuel that would have been. I wonder how many litres of diesel that consumed? DO you get any indication?
It's strange to see how many 755's are sitting around in the day. It's an embarrasment of riches. Even a couple of sets stabled at Ipswich despite 3 units being used on an Intercity diagram. Is there still talk of doubling Trowse bridge? Looks like movement on Gypsy lane now too. Goodness me it has taken years to sort that one!
dk1
2 Oct 2009
East Anglia
Yes 13 years now for Gypsy. No more news with Trowse Bridge and doubt there will be for many years now. Yes we do get an indication of diesel litres used on passenger workings but it’s not something I pay much attention to.
Apart from the Thunderbird 755 (not always enough units for that) there’s usually one ready for swapping another unit over later and for fuelling at Colchester.
LowLevel
26 Oct 2013
Could have a proper splurge and reintroduce the Summer Saturday Yarmouths - cheaper fares on a standard class only train with a triple unit through from Liverpool St, could be popular, no faff bolting on a 47 at Norwich either :lol:
