Greater Anglia Class 755s (Regional Trains)
LAX54
15 Jan 2008
Not sure how long ago it was someone speculated this thread might only have another 6 pages in it, but sadly it still seems to be going strong!
I hope we aren't about to get into a situation where all the types of new trains are causing teething problems at the same time.
(And I've always been wondering why our Flirts are so much worse than Estonia's were. Gradients could account for it...)
755/4 seem OKish, it is the /3's that are throwing up the issues, so if the rumour/story is valid, maybe 4(5) car Stads on the Cambridge/Peterboros, rather than 3 ?
Railperf
30 Oct 2017
Methinks that since each engine / gen-set is packaged with it's own cooling system, then the twin-engined 753's have to work harder & could have cooling problems if only 'cos they're not much lighter than the 754's. (Anyone know the weight of the extra intermediate car body + it's bogie ?)
If i remember correctly weight per unit is 168 tons for a 4 car and 132 tons for a 3 car. Either way, even the 3 cars only need around 4 to 5 mins to reach 100mph in diesel mode. So you would expect that these would have been tested under full load for much longer than that. And probably a cycle of full load followed by idling or to replicate real life driving. The 3_car units only have 1 engine per engine compartment so in theory should be more volume of space for heat to dissipate..
trebor79
8 Mar 2018
Surely there's lots of empty space in the 3 car engine modules. So should be easy enough to fit some additional radiators.
LAX54
15 Jan 2008
Power output
3 car - 2,600 kW Electric
3 car - 960 kW Diesel
4 car - 2,600 kW Electric
4 car - 1,920 kW Diesel
eastdyke
25 Jan 2010
East Midlands
Is it possible that Stadler are still a degree or two (literally) on the cautious side with the Engine Management System settings?
dm1
19 Jun 2017
Given that the trains are Swiss, gradients really shouldn't be a problem...
Railperf
30 Oct 2017
Hold on here...there are no serious sustained gradients of any note on this route. There is nothing that compares to the Highland main line here. The gradients should be bread and butter to these. The 3 car units have the same power to weight ratio as an 8 car HST
LAX54
15 Jan 2008
Indeedy :) BUT there has to be something between Bury and Chippenham, that is making the 755's poorly ? yes they throw a wobbly elsewhere, but this seems a popular area !
Railperf
30 Oct 2017
Three miles uphill from Bury towards Kennet no steeper than 1 in 128, followed by two miles downhill and a further mile uphill 1 in 154..then downhill all the way to Chippenham Jn. In fact the steepest uphill climbs are from Cambridge towards a summit at Dullingham 1 in 100 on the west side - but limited to 60mph - so again not too taxing. Steeper gradients exist on the East Suffolk line 1 in 75 and 1 in 80 but only a mile or so in length each and again low line speeds.
Could something nearby the route in that area be causing some major electrical interference that is causing the trains control system to have a wobbly??
eastdyke
25 Jan 2010
East Midlands
Is it just the Ipswich towards Cambridge affected? Waiting for the single line? Any electromag stuff from RAFs (USAF) Mildenhall/Lakenheath?
bspahh
5 Jan 2017
Interesting thought - that's not far from Mildenhall is it...?
I don't think the air bases will be having anything to do with the train problems.
The closest bit of track that a train from Cambridge to Bury St Edmunds would get to Mildenhall is near Kennett station, which is ~ 6 miles from RAF Mildenhall. Shippea Hill on Ely-Norwich line is ~ 5.5 miles from RAF Mildenhall, and closer to RAF Lakenheath.
If a train is going to be affected from 5 or 6 miles away, I would expect cars to be affected when they are a mile away.
Midnight Sun
16 Sep 2018
There are USAF E-3's (Awacs) based at Lakenheath. I have seen them fly south over the line after take-off. As a high power lookdown Pulse Doppler radar is fiited. And as they are still at a low height (5000ft), could the radar signal be having a effect at this low height.
hooverboy
12 Oct 2017
There are USAF E-3's (Awacs) based at Lakenheath. I have seen them fly south over the line after take-off. As a high power lookdown Pulse Doppler radar is fiited. And as there are still at a low height (5000ft), could the rader signal be having a effect at this low height.
they've certainly got jamming systems on board that could screw up the electrics!
Icky Qualms
8 Aug 2019
Suffolk
Is there some strange force between Bury and Chippenham Jct ? This seems to be the area most 755s have a wobble and fail !
There is a HV Sig supply cabin in Higham Yard
Apart from that nothing of significance that could possibly cause any electrical interference
dgl
5 Oct 2014
It was reported that people living below Rampisham Transmitting Station on Toller Down (A356, Crewkerne to Grimstone) http://tx.mb21.co.uk/gallery/gallerypage.php?txid=1662&pageid=2500 used to have problems with using remote key fobs and had Russian coming through their toasters so it's not un-heard of for high power RF to cause issues though I would doubt that this is the problem here.
bspahh
5 Jan 2017
I saw a 755/3 for the first time on the Stansted/Norwich service today, on the 16:48. They have only been 755/4 to date on this line.
dk1
2 Oct 2009
East Anglia
Not true. Been loads of 3-cars on the Norwich-Cambridge/Stansted. Each route makes do with whatever is available.
trebor79
8 Mar 2018
Yeah seen a few 3 cars through Attleborough. I guess it's planned to be 4 car but 3 car if there aren't any available for whatever reason. It's better than cancelling the train, and I've never seen a 3 car at "peak" times.
dk1
2 Oct 2009
East Anglia
Beggars can't be choosers & all that. More seats than required at most times anyway.
WroxhamTroll
9 Dec 2019
Norfolk
Not exactly beggars more like paying customers, but most would prefer a service than none at all. The weeks of no service made me almost wish for a dogbox to show up!
trebor79
8 Mar 2018
Oh yes, not complaining at all. I'll take a 3 car FLIRT over a 153 (as I experienced in November) when the booked unit is not available any day!
I haven't seen people standing since the 170s left (Cambridge to Ely in the evening excepted). As you say, plenty of seats.
dk1
2 Oct 2009
East Anglia
Paying customers obviously (on the whole) but a train is a train regardless. I can't be doing with the pampering to exact class & carriages. As long as it arrives at roughly the time stated when the chips are down as they have been lately then that will do.
WroxhamTroll
9 Dec 2019
Norfolk
I think most folks just want what they pay for a seat in the class of booking within +/- 5 mins of schedule. Its the same with airlines and other transport services.
In December I drove to london each week which I thought would be terrible but turns out it was reliable, comfortable and cheaper! Not really the planet saving message.
Anyway back to the 755's are they all in service now? And how is the refueling working as this seemed to be a bit of a weakness.
Railperf
30 Oct 2017
Getting back to the 755/3 breakdowns, the section between Bury and Chippenham seems to be the most popular point of failure, so either the gradients are an issue - or it is a software glitch, or maybe the cooling system on the 3-cars is less up to the job than the 4-cars. Either way there are some very well paid Stadler and Deutz engineers out there whose job it is to sort the issues out!
Thankfully failures on my travels have been rare.
What does seem to be an issue is the fact there does not seem to be any early warning of an overheat situation. Once the alarms start going off, i understand the trains starts going through its engine shutdown procedure, and cannot be restarted until that has happened. The whole shutdown rebooting i am told takes around 15 minutes. Operationally that seems crazy. Surely there should be some early warning of rising temperatures so that drivers - a la class 800's - can ease off the power or take some measures to allow the train to cool down, rather than experiencing the sort of shutdown PC users experience when their PC decides to update and restart without any warning!
bspahh
5 Jan 2017
Yes. I should have written, that it was the first 755/3 that I've seen. I'm normally on them on the first off peak train from Ely into Cambridge, and then between 5 and 7pm in the evening.
Nighthawke
7 Nov 2015
No there are not nor at Mildenhall. The occasional one may visit or do an approach but none are based. Also the chance of one being in the area when a train passes is extremely low.
As for the theory of the bases having an effect on this stretch, well the Norwich-Cambridge line runs much closer to Lakenheath in particular and there have been no breakdowns there to my knowledge.
Maybe we should stick to facts rather than sci-fi speculation.
20-year Brandon resident and 40 years aviation knowledge.
