Greater Anglia Class 755s (Regional Trains)
dp21
10 May 2017
For those interested, 755001 made took it's first journey under it's own power the other day. Ok it was a matter of a few feet but it's still a major milestone.
longhorn
24 May 2018
When the cars are connected, does sheer weight of the one car keep its connector sitting in the groove of the partner car? Or is there a cap sits on top of the connector in the top picture.
hexagon789
2 Sep 2016
Must be a cap or bolt or something, otherwise the cars might part in a derailment and would be more likely to jackknife I'd have thought.
longhorn
24 May 2018
If this set is suppose to be out testing, surprised there are not more pics of the train.
Wivenswold
24 Jul 2012
Essex
Last I read the first unit is undergoing static testing indoors at Stadler’s Erlen Commissioning Centre. I don't know where Stadler's test track is though, I assume they have one.
MrPIC
30 May 2015
Think its heading off to either Romania or Czechia very shortly for testing, and then to Berlin for a trade show before coming to the UK after that
The_Engineer
24 Mar 2018
Is it a trick of the light, or does the diesel bit in the middle seem to be sloping differently to the rest of the train??
twpsaesneg
21 Jul 2009
Looks to be a similar profile to what the the rest of the cars woukd be if the doors were open - could be they've maximised body profile in the engine unit to give more space, since they'd not have to allow for a door open in service on that seeing as there aren't any.
Or it could be a ropey bit of track!
dp21
10 May 2017
It looks different because it's actually slightly larger than the rest of the vehicles (about 10cm). Don't ask me why. My first question was why not make the rest of the vehicles slightly wider to match it?
Anyone who knows better can enlighten us.
ac6000cw
10 May 2014
Cambridge, UK
It's probably suspension testing or unevenness of the track in reality - if you run a ruler along the train on the photo, the rear two cars are out-of-line with the front two, and the power car is twisting/tilting to bridge the difference.
MrPIC
30 May 2015
The power car is indeed slightly wider than the other vehicles, to maximise space for the engines. This can be done on this "coach" only really because its so short, if the rest of the coaches were this wide they wouldn't meet the gauge.
ac6000cw
10 May 2014
Cambridge, UK
My guess would be that because the power car is shorter it has less throw-over on curves so can be wider while staying within the clearance requirements. As passenger vehicles have got longer it's probably mostly the curve throw-over issue that limits the body width.
The_Engineer
24 Mar 2018
Correct!! Hence the taper too, on Mk.IV coach ends and other long bodied stock.
MrPIC
30 May 2015
An 8 coach of the 4 car bi mode yes, the AC only flirts are 12 coaches long with no power cars. The power cars are for the diesel engines.
Rick1984
23 Aug 2012
Smart train but find the livery a bit messy. Think the 321 livery is the best Greater Anglia livery.
fat_boy_pete
16 Mar 2015
Essex
It's shorter, so can be wider and still keep within the loading gauge. Allows the corridor to be less claustrophobic.
MrPIC
30 May 2015
Any recent pics of the Aventra 720's? Last I saw was a picture of a coach and the flirts seem to be racing ahead!
whhistle
30 Dec 2010
Very European looking.
I like it! A bit different to what we're used to seeing on our metals these days.
Well, I did like it... until someone pointed out the larger engine vehicle. What a shame.
Although regarding the yellow fronts, I'd like some proper, recent testing to be done.
I would highly suspect a tiny amount of yellow like that isn't going to make any difference.
