Greater Anglia Class 755s (Regional Trains)
trebor79
8 Mar 2018
They have 'scrubbers' which are like a block that should clean the surface of the wheel. Sadly they are not performing as well as intended.
Is that the intermittent "rubbing" noise you can hear when sat above the front or rear bogies? Can't hear it above the intermediate bogies and I think it was mentioned the scrubbers are only on the outermost bogies.
How come this problem hasn't been an issue in other countries than run FLIRTS?
dk1
2 Oct 2009
East Anglia
How come this problem hasn't been a en in other countries than run FLIRTS?
Not sure on either question I'm afraid.
AlexNL
19 Dec 2014
That's because the infrastructure in each country is different. The track gauge may usually be 1435mm but that's where the similarities end.
In the Netherlands we've also seen detection issues on lines where new lighter rolling stock was about to be introduced. They fixed that by replacing the track circuits with a stronger version ("prikspanningspoorstroomlopen") and by imposing limitations when the trains have to run beyond their normal area (e.g. no solo running).
Failed Unit
26 Jan 2009
Central Belt
They can maybe pull the wool over the majority publics eyes, but the truth will always come out as GTR and the May 2018 timetable fiasco proved.
F Great Eastern
2 Apr 2009
Isn't that why there's facilities like Wildenrath? Did Stadler use such a faculty for testing before delivery?
trebor79
8 Mar 2018
might be because Europe doesn't have as many safety features on their trains as we do
But track circuiting is pretty standard isn't it? If it's a rail/wheel contact issue causing lack of track circuit detection you'd expect that to manifest itself elsewhere too.
The level crossing incident is odd. If the train "disappeared" before passing the crossing, but after the barriers had come down, surely the fail safe design is for the barriers to stay down?
AlexNL
19 Dec 2014
That is indeed why such facilities exist. I think the 755s have gone to Velim for their initial tests?
Either way, the situation that's now seen with the 755s clearly hasn't occured during testing. Perhaps it only manifests itself under very specific circumstances?
The principle is the same but the way it's implemented in countries can be slightly different. Different voltages / frequencies for example. That's why local testing happens next to test tracks.
If the level crossing is activated only by a track circuit becoming occupied, then it's not unexpected for the crossing to consider the track free when the TC no longer detects the train.
The fail-safe design in a track circuit is to show the block as occupied when a failure occurs, which would lower the barriers. In this case obviously something went wrong causing the TC to incorrectly think the block is free.
D6700
13 Mar 2010
We need to get some hybrid 156/755 combo's, like happened when there was a similar issue with 158's when new!
(No, I don't need to be told it can't be done)
gingerheid
2 Apr 2006
Facebook just reminded me that a year ago today I was getting sarcastic about the free Google Cardboard VR googles they were handing out. Little did I realise how wrong I was. I don't need them to see a new train. I need them to see any train...
Pete_uk
28 Jan 2017
Stroud, Glos
Just found out what almost happened. Shocking to say the least. If the train had hit the car the brown stuff would have hit the fan. Lucky car driver.
LAX54
15 Jan 2008
In the short term pending rectification, maybe treat them as *Z09 trains (cannot be guaranteed to activate TC's) and keep them away from non-treadled AHB's maybe ? least they could keep some resemblance of a service :)
GB
16 Nov 2008
Somewhere
Nah, the Felixstowe branch has been running great with no passenger services :)
Tug
2 Aug 2019
It sounds like we are very lucky on the Wherry (Gt Yamouth & Lowestoft) Line that the full upgrade with automatic crossings and remote signalling has not been finished. I cannot see it being switched on until the 755 issues are sorted.
Does anybody know what the solution to the apparently superficially similar 158 problem was?
Grumbler
27 Mar 2015
There's an interesting and informative discussion on the "Near miss at level crossing" thread on uk.railway on Usenet.
Rick1984
23 Aug 2012
One thing I noticed they make some interesting noises before pulling away. A bit like the squeal of wheels round curves.
dk1
2 Oct 2009
East Anglia
That sounds like a ready made excuse to me although the local forecast is not that bad.
Didn't sound good for rail head conditions when watching Look East yesterday. We will have to just wait and see.
chubs
30 Oct 2012
Definitely unusual weather here, trees full of leaves last weekend now totally bare and the wind was pounding the house last night.
I know it happens from time to time but rare to be that severe.
GarethC
22 Aug 2014
Can anyone confirm where the Class 755s are operating today (Sunday)? Are they doing Norwich-Sheringham[Cromer] and Norwich-Great Yarmouth/Lowestoft? Leaving Norwich-Cambridge and Ipswich-Lowestoft with the Class 156s+170?
Are they still cleaning the wheels manually after every trip?
Thanks,
Gareth
