Great Western Electrification Progress
linuxlad7
9 Nov 2017
Corroding at a higher than expected rate.
No, not a fact. Your opinion, and it’s wrong. Expecting it to be signed off for passenger use on electric in March.
Where has that march month come from. what are they actually doing with the tunnel ??collecting data, polishing up the conductors...?? offering prayers??
Again, any more definitive words from Mr Dolphyn??
Tom Quinne
8 Jul 2017
People actually working on the project, and official information issued to those who need to know.
It’s not as simple as leave the tunnel isolated and forget about it, along hangs on being able to run full fat EMUs through to Wales.
JN114
28 Jun 2005
Mr Dolphin has said March on Twitter it least once. March is what we’re being told at GW what is being worked towards. I don’t know the specifics of work/sign off required.
Optom1
20 Sep 2019
Cardiff
Furrer and Frey have issued a10 point statement referring to British contracts (reading between the lines it obviously refers to the Severn Tunnel) setting out remedial work/forward planning that may be needed to ensure reliability.A previous message by F& by a member mentioned drip trays.I notice that these are mentioned specifically as a possible solution to reduce corrosion byF&F.
ATW158Xpress
6 Dec 2016
Could these timings taken from RTT be GWR testing the 800s on the OLE between Cardiff and Newport?
https://www.realtimetrains.co.uk/search/detailed/GAERJ/2020-01-01/1906
Yes test train will be making 24 trips between Cardiff Brickyard Sidings and Gaer Jn to test the OLE from St Bride’s (Newport) neutral section to the limit of wires at Cardiff West Jn/Line A and Brickyard Sidings.
https://www.realtimetrains.co.uk/se...0?stp=WVS&show=non-passenger&order=wtt&toc=GW
Optom1
20 Sep 2019
Cardiff
From F&F “NetworkRail has chosen to temporarily suspend acceptance of future installations of R.O.C.S until further remedial action is completed in a small number of specific wet locations”F&F Network Rail are “cooperating closely”.F&F also seem to imply that it is Network Rails responsibilty to improve the wet area problems
Scottychoo
10 Dec 2018
Well let's see who is correct then, I will put money on it not being you. You heard it here first.
JN114
28 Jun 2005
What is the point in posting things like this?
Some don’t like being pointed out that they’re wrong. So instead of admitting they’re throwing the proverbial at the wall in the hope it will stick; they double down inferring that they somehow have insider information that’s different from all the other insider information that’s being regurgitated on the forum - hence the “heard it here first” comment.
Meanwhile in reality my employer is briefing me for March, we’ve seen comments on Twitter from senior project engineers that it’s March. My friends and colleagues directly involved in the project say it’s March... But I guess my circle of friends and colleagues is missing that one big piece of the jigsaw that makes young Martin here so sure that we’re all wrong and he’s right.
Optom1
20 Sep 2019
Cardiff
Does anyone know when the copper contact wire was replaced by aluminium ,thus giving the tunnel its “stand alone statua”?
S-Bahn
2 Nov 2018
Will be travelling From Cardiff to London at the Weekend - Am I correct that it's likely to be electric all the way except for the tunnel?
Optom1
20 Sep 2019
Cardiff
Real time only shows electrics from Monday,but that cannot be defined as the definitive source,lots of other variables.Let us know!
S-Bahn
2 Nov 2018
Fingers crossed! Hopefully while I'm waiting I'll see an IET coming in from London pan up!
McRhu
14 Oct 2015
Lanark
Aluminium contact wire?! I'd not heard this. Isn't it a tad on the soft and ductile side for this purpose, along with being very galvanic? I take it this is an alloy (Aluminium Silver or Aluminium Titanium or such)?
hwl
5 Feb 2012
The key word tends to get forgotten!
Aluminium Alloy contact wire to match (chemically for anti-corrosion purposes) the extruded rail system that supports the contact wire in the tunnels so presumably AA6082-T6 (convienienty available off the shelf from specialist electrical cable manufacturers).
Soft or ductile doesn't apply to 6082.
hwl
5 Feb 2012
I see. Thank you hwl.
The contact wire is closely supported by an inverted U-cross-section "rail" made from section of Aluminium alloy extrusion that reduces clearances as there is effectively zero movement
https://www.furrerfrey.ch/en/systems/conductor_rail.html
Also recently installed in the Crossrail and Glasgow Queen Street tunnels.
I think many of us suspect that the delay in turning it on has contributed to the corrosion issues as they should reduce when the juice is on.
Domh245
6 Apr 2013
nowhere
Pardon my ignorance, but does this 'beat' the March target that was stated for the tunnel to go live? I note that it is subject to a speed restriction of 75mph through the tunnel "until additional testing in accordance with ENE TSI clause 6.2.4.5 is carried out" - presumably that is what is scheduled to be completed by March, but it is theoretically completely usable now?
Linda smith
31 Oct 2018
Word on the street is that the orr signed off the Cardiff - bristol section for traffic. This includes the Severn tunnel btw.
McRhu
14 Oct 2015
Lanark
Thanks again hwl. I take it the substitution of aluminium alloy contact wire for the copper (alloy) one was to limit galvanic corrosion from the aluminium rail to the copper wire? As regards the use of aluminium in catenary (as opposed to contact) wires weren't there issues with the MK IIIa/b acsr? although I think this related primarily to wear and tear I seem to recall some electrical issues too. One does wonder, if cost were no issue, what would be the best material for the various ole wires for difficult, corrosive environments; Gold + Titanium/Tungsten maybe?
linuxlad7
9 Nov 2017
with more than a dollop of silicon I read... and excellent corrosion resistance...
hwl
5 Feb 2012
yes but other different corrosion issues on other components elsewhere too.
No simple answer as very few good conductors to chose from and very different chemical issues in different locations.
