Great Western Electrification Progress
The_Engineer
24 Mar 2018
I took this shot about 45 mins ago leaving Bristol Parkway towards Filton. I believe this is a relatively recent appearance, in the gap between Bristol Parkway and the masts already erected further on. Could any OHLE experts advise what these masts are for?
The masts seem to have isolating switches on the horizontal arms, the rods coming down to ground level to operating levers. There must be a neutral section close by and these will be the section isolators.
That’s the sort of thing that appears to allow isolation and/or reconfiguration. Note the devices on the mast. They are switches operated by the vertical rods below, a bit like those in rural areas on the public distribution network. The masts are taller than usual when it is necessary to carry power over to the line (or lines) on the other side of the track while maintaining clearances with respect to other wiring such as the catenary and contact wire...
Here’s a picture of a typical operating lever at ground level:
https://goo.gl/images/ib7xwm
snowball
4 Mar 2013
If the picture was taken leaving Parkway towards Filton, and it seems to be on straight track, then I imagine it must be immediately before Stoke Gifford Junction, where the line from London splits three or four ways, to Severn Tunnel, Avonmouth, Filton Bank and possibly Stoke Gifford Depot. So it seems a very appropriate place to have track sectioning facilities. Though I would have thought just west of the junction would have been more likely.
D1009
22 Feb 2012
Stoke Gifford
Thanks for this and the above replies, yes it was a little way west of Stoke Gifford Jn, which struck me as odd as the electrification towards Filton bank has supposedly been paused. The embankment in this area has been reprofiled, which meant that the route from platform 1 towards Filton bank was taken out of use not long after Chris Grayling officially opened it in January. This severely reduced its usefulness as there is no other signalled route towards Filton bank available from platform 1. This also delayed the completion of the headshunt from Stoke Gifford Yard. Now everything appears to be complete in that regard, and you can see both of these lines on the photo.
Phil G
16 Oct 2017
I traveled Chippenham to Paddington today and took the opportunity to fill in the gaps in my knowledge. Catenary and contact wires now reach the western end of the run at cocklebury road bridge on both lines. After that I had to stop leaning over the chap with the window seat so didn't see much more of the down line. However on the way back I had an uninterrupted view of the up line from wootten Bassett junction to Chippenham and there is about a mile I guess of catenary with no contact wire just east of dauntsea lock followed by about 2 miles of nothing until just west of Dauntsea lock. After that to cocklebury road is complete for catenary and contact wires. There is very little ATF wire yet, just a few sections.
59CosG95
18 Aug 2013
Beeston (Notts)
Just to confirm - are all the earth wires up on both sides of the line between Cocklebury Rd & Wootton Bassett Jct? I know the ATF wires are fairly sporadic, and the C&C is about 70% complete on the Up line (from your observations), and indeed I seem to recall you mentioning that all the earths were up earlier on this thread - but the "2 miles of nothing" rather threw me, I have to admit!
Phil G
16 Oct 2017
Earth wires appear to be complete, apologies for the confusion.
deltic08
26 Aug 2013
North
I am sure this is a section point where a section of live wire can be turned off and isolated and not a feeder point. It is controlled remotely from a central control room. If I am wrong I will be corrected.
Elecman
31 Dec 2013
Lancashire
You don’t Have Section isolation switches at Neutral sections
I expect this would be as close as possible to the junction so (on the original electrification scheme) they could isolate the line towards Temple Meads while keeping the line live to and from Wales. There is probably another one just west of the junction on the other route too. It's now redundant as the wires will end a few supports towards Abbey Wood (or are they electrifying the triangle, perhaps to turn trains?), but I expect when the wiring to Temple Meads was Graylinged they just made the minimum of change to the design rather than spending a lot more time trying to get rid of a feature that will be needed if and when this cut is reversed.
317362
7 Sep 2017
GWR advising locally that the November Newbury blockade is cancelled, work is going to be done overnights due to good progress.
59CosG95
18 Aug 2013
Beeston (Notts)
Are there any updates on when Kensal Green - Maidenhead is due to go ATF-wire ready? IIRC most of the ATF wire is up on that stretch, but there are a few areas nearer Kensal Green that are missing ATF wires.
Thatcham Xing
1 Nov 2016
Looked like the wiring train was at work east of Theale, very near the M4 overbridge, when I passed on the Motorway at about midnight last night.
3973EXL
2 Feb 2017
The up line at Theale east now has the catenary wire up. Wiring train is stabled under the road bridge on the down.
Platform extensions nearly finished. Section between the old & new on the down has just had the tarmac go down.
Now moved to the up platform with the tarmac.
9 Nov 2017
A few people are commenting on the ATF wires from Wootton Bassett to Cocklebury Lane O/Br. - I'm fairly certain there won't be any installed going much past Christian Malford substation. As the OLE isn't continuing onto Thingley Jnc. yet, installing the ATF wires onwards from the switches at Christian Malford would be fairly pointless at this stage - they won't connect up to anything at the other end and would hence need to be permanently earthed anyway. The ATF SPS is all there, so installing the wire itself is something I believe will be done when the OLE continues onto Thingley.
Given other priorities elsewhere, it's not terribly surprising to try and remove non-essential bits from the scope of works.
D1009
22 Feb 2012
Stoke Gifford
I've caught a XC HST to Cheltenham this afternoon, it looked to me like the wiring was in place at least on the down line between Westerleigh Jn and the Winterbourne area. There were some midweek overnight blocks over the last couple of weeks between Parkway and Westerleigh.
To clarify this, catenary and contact wire are in place as far as a point between the old station at Winterbourne and the viaduct west of it. This applies to the down line, but I imagine the up line is the same.
Phil G
16 Oct 2017
To be fair I was only commenting on the status, not expressing an opinion, but to be honest given this section is not supposed to be going live until after Cardiff I'm surprised that any of it has been done yet, however as it's virtually finished now, maybe it will be live sooner than originally planned.
Phil G
16 Oct 2017
Talking of go live dates wasn't testing Didcot to Swindon was supposed to be July with operation in September. Is this still on, will we be seeing 800s on AC at Swindon in the next few weeks?
Mintona
8 Jan 2006
South West
I’m not aware that any train testing has taken place yet. I think the date in July was from when it was to be treated as live, and from September will start being tested rigousously. I believe passenger trains won’t use it until December/January.
Phil G
16 Oct 2017
There's a post on the 800 thread saying that there are interference problems west of Didcot and it's all a bit of a mess. Seems odd as they fixed it before so you would have thought the same fixes would have been done. The kit is all pretty new.
9 Nov 2017
Absolutely - apologies I wasn't suggesting you were being opinionated one way or the other. I just thought people might be interested in why the wires hadn't been isntalled.
Thatcham Xing
1 Nov 2016
Couple of pictures of wiring work at Newbury station on Network Rail West Twitter
....and also now some pics from Bedwyn of Claire Perry (local MP) having a look at the completed turnback extension.
Unfortunately the pics don't really show the extent of the extension, or what's been done to the foot crossing, but assume it's as per the plan shared earlier in the week.
59CosG95
18 Aug 2013
Beeston (Notts)
Speaking of wires: while the C&C looks largely complete on the B&H (and Basingstoke overruns), there are a number of sections of the route west of Southcote Jct where the earth wires have yet to be installed (certainly on the Down side). Not sure on the Up side though.
Phil G
16 Oct 2017
Sorry, didn't mean to sound huffy, there's more than enough of that on here. My assumption on the ATF was simply that it was the least important and so was being done last. I realise you have inside knowledge which I'm sure we're all grateful you share and it's interesting to hear why the ATF may not be done on this section. As a project manager myself the sheer scale of activity to coordinate on this project must be vast and deciding which things can be dropped or done later to ensure the main delivery must be a real challenge. It would have been really interesting to have seen the plans.
