Govia Thameslink first class penalty fare dispute
Tetchytyke
12 Sep 2013
Isle of Man
Or instead of waiting for this long process of the PIS screen cycling round, you could spend 20 seconds googling it. You don't even have to leave the Google results page to find the answer
Google also tells me, in all earnestness, that the first ever backflip was performed by Sir John H Backflip in 1316.
I await the first thread in here entitled "I Googled it and Google was wrong and now I'm being prosecuted".
This is why (a) AI is near-useless when wanting to verify facts, and (b) why you SHOULD leave the Google search page to look at the source and verify its veracity.
Thameslink's first class declassification policy is on their website though and isn't hard to find. And the default should be assuming it is first class.
Kite159
27 Jan 2014
West of Andover
Clearly the simplest solution is to do away with First Class and replace the seats with those found in Standard class when the trains get their first refresh.
That way, nobody gets confused with the policy of which end is declassified.
The_Train
2 Jun 2018
I have no idea what a backflip has got to do with this but if you are making the point that not everything on Google is correct or that by relying on info from search results could lead to misinformation then you have 2 ways of verifying it in the example I gave (which is actually relevant to this discussion unlike a backflip). 1) check the website link to ensure it is from a valid source - the screenshot I attached to my previous post clearly shows that the information I have sourced is from the Thameslink website or 2) click on said link and check the info on the website.
It all equates to the same thing with regards to the point I was making which is that the information regarding declassified first class on Thameslink is readily available within seconds. It is also correct information so I am not sure of your final point about it being wrong and now being prosecuted!
Why SHOULD you leave the Google search page when the information you have found has a valid and verified website link attached to it. As I have said above, you can clearly see in my screenshot that the information provided is taken from the Thameslink website as it there is a weblink at the bottom.
I agree, especially with Thameslink. It just feels so pointless having 1st class at all. If first class is to remain though, the other option is to put a blanket ban on declassifying first class so again nobody can ever become confused about where they should be sat.
Tetchytyke
12 Sep 2013
Isle of Man
Don't even need to do that. LNR sensibly abolished first class but left the former first class compartment pretty much exactly how it was.
Kite159
27 Jan 2014
West of Andover
Hence, why I said when the units get their first refresh. Although in the case of LNR, the former first class areas are pretty much the same* as standard class in terms of having tables & plug sockets. The only different is having worse seats (*excluding the 350/2 units which are going). It's not a like for like comparison with the Thameslink units which don't have sockets and only some of the units have seat back tables.
buscoaster
21 Jul 2021
Bristol
When taking a Thameslink train at rush hour, it is often completely full including standing. Is it permissible to stand in the first class areas in these situations, and if not, what should a passenger do?
31 Dec 2019
uk
No.
Stand elsewhere - there are 7 and a bit or 11 and a bit coaches of standard class accommodation.
For certain events on the GTR network (e.g. Brighton Pride) not even 11.4 coaches of standard class crush-loaded is enough.
Haywain
3 Feb 2013
Which is why they tend towards queuing and crowd control for that. But if 11.4/12 coaches crush loaded isn't enough there's not much more the railway can do - class 700s are probably the highest capacity trains anywhere on the network.
Tetchytyke
12 Sep 2013
Isle of Man
If it's genuinely crush loaded, such as for certain events in Brighton, then chances are first class will be declassified.
But no, you can't stand in first class just because it is busy in standard class.
31 Dec 2019
uk
I've still yet to see first class declassified on Thameslink bar strike days. Although of course there is an argument of first class being de-facto declassified if it is physically impossible for an inspector to get to the compartment. That could apply equally to many commuter services.
Same as any other service. There are 11 and a half other carriages on a 700/1 or seven and a half on a 700/0.
They do occasionally, for example if a 700/0 covers on a 700/1 diagram, though it isn’t particularly consistent. It’s well advertised though.
skyhigh
14 Sep 2014
Even easier - to support the SDO system, the class 700s already have support to make announcements in certain coaches only. Just have a regular announcement in the front coach that "the First Class compartment in this carriage is for the use of passengers holding First Class tickets only".
Almost zero cost, could be done almost overnight and would rule out most of the "I didn't realise" chancers. Though I suppose there would still be people claiming that they didn't hear the announcements because they were wearing headphones...
jon0844
1 Feb 2009
The 'I didn't realise' chancers likely don't exist. People think that on a DOO train they'll get away with it, and at best be asked to move, at worst be asked to upgrade.
If they get a PF they'll kick off and say they didn't know it was first class, or start with the 'there were no seats in standard' or 'why should I pay more when there's no big upgrade over standard' etc. They might even go the media to try and get sympathy, especially from others that share the same mindset and don't see why they should pay.
I would expect that someone who genuinely didn't know would react in a different way to someone trying it on, as I'm sure most people are doing every single day. On 387s you'll see first class being used as normal on late night services. I have zero way of knowing what ticket they have (or if they have one) but I'm thinking it's rather unlikely that people at night are paying more first class to try and get a seat - when during the day, when you might have more reason to go first, the compartments are near empty.
Playing messages telling people about first class could work, but it's just as likely going to annoy those who would rather not hear superfluous messages on their trip.
Hadders
27 Apr 2011
The PIS screen in the front 1st compartment already says you need a 1st class ticket to use it as part of its message rotation. Adding an audio message, however well intentioned, is highly unlikely to result in more people being made aware of the position.
wilsontown
11 Feb 2012
I was in Thameslink 1st today and it couldn't really be more obvious that it's a 1st class area. But of course the same would apply to the rear compartment that is declassified.
I do think two things can be true - this guy is clearly a chancer but the policy of having a first class section that is always declassified and another that sometimes is declassified is just daft.
Exactly my thoughts. Yes, first class is clearly marked but the majority of the time it is actually declassified, so people have to disregard those clear markings!
The declassification notices are only occasionally shown so it would be easy to miss them and the rules for declassification are not at all obvious.
Of course, people will say that if you are playing it safe, you should avoid first class if you're unsure whether it's declassified. But that misses the point that someone may regularly travel on routes where first class is always declassified (e.g. the Sutton or Rainham services) and thus be caught out by the policy being different on other routes - despite almost all indications being that they would count as the same.
Sure, the platform displays list which services have first class, and it's shown in the timetable. But are we really saying that the average person looks at these?
I think Thameslink needs to have a consistent policy across all routes as a minimum, and should have first class at a fixed end of the train (either the south or north end) with the other end being permanently declassified by removing the signs/antimacassars etc.
When the railway has a clear and unambiguous policy it makes it much easier to say that anyone still occupying first class is likely to be chancing it. At the moment, there is a considerable degree of ambiguity which makes the railway's position hard to morally defend.
jon0844
1 Feb 2009
If GTR/the DfT can see a market in selling first class tickets to people travelling from the suburbs into London then they're not likely to want to get rid of first class entirely, so the only other outcome would be to make first class be so at both ends, at all times. I don't think anyone wants that.
For as long as I've commuted, I've enjoyed using first class on trains that didn't operate first class - which goes back to the FCC days and possibly even Wagn. Most people in the know were quite happy that most people weren't in the know. Look back on threads where people had to carry letters to confirm that they could sit in first class on specific services, as some revenue staff were unaware.
I would actually quite like to still be able to enjoy this, not just on GTR but any train operator. I fear this person is not going to get the outcome that he, or anyone else, wants. It's unlikely it will lead to first class being scrapped entirely - at least not until the transition to GB Rail is completed, and even then if it has a business case then surely it will remain.
Anyone that doesn't know better won't be in first class, simple as.
Nobody needs to know if first class is declassified. Knowing is a bonus, and there are multiple ways to find out, but it isn't essential. The only people I can see with a valid concern is someone who paid for first class and ended up in a place that wasn't actually first class. And that's a totally different (reversed) scenario where a penalty fare wouldn't apply for someone with a first class ticket effectively in standard.
And the current system of having first class advertised at the front of the train works fine as it's easy to tell which way a train is going. People both know which is always declassified and which is (or might be) first. As said above, the only issue is someone paying for first class when there might not be first class at all - but that's not a recent issue, it's existed for literally decades.
While Thameslink doesn't yet have individual route names like London Overground now does (another topic of debate perhaps), the ones that are fully declassified are specific routes/services so there IS consistency. Again, for those who know, it's easy. Anyone that doesn't know, or care to know, just sits in standard.
I'd love to know who actually wants everyone to know they can sit in first class, thus making it packed out at all times, and making you have to move to standard. There's nothing to say you can't broadcast it to the world, but why would you?
Surreytraveller
21 Oct 2009
Just stood on the Platform at St Pancras, Sutton train in the platform and the automatically PA announces 'There is no first class accommodation on this train'. Which is incorrect, as there is first class accommodation on the train, it's just declassified.
It ought to announce 'Standard class ticket holders may sit in first class on this train'.
The whole system is confused, so no wonder the passengers are.
jon0844
1 Feb 2009
Isn't that being somewhat pedantic?
RJ
25 Jun 2005
Back office
In this case though, the passenger wasn’t confused in the slightest.
Passenger knowingly evades fare. Passenger gets a penalty. It really is as simple as that in this case.
Although he will get sympathy from the pro-fare evasion crowd on here!
infobleep
27 Feb 2011
That has been an issue waiting to happen. Indeed some people on here predicted it.
I am surprised i had seen a news story on this previously.
Look at the service from London Victoria to Epsom Downs and also the service to Horsham via Sutton.
They are declassified Mondays to Saturdays only and classified on Sundays.
I can see how it might confuse someone. I dont know how many standard class passengers sit in first class on Sundays. Perhaps they need some RPIs working the services on Sundays.
I often use to see people in stood first class between East Croydon and Clapham Junction. If I was on a busy train and I some how ended uo in the first class section, I would make a point of ensuring I wasn't, no matter how busy the train was.
Never saw anything done about this though.
Are there any Sutton loop trains that have first class any more? A number of years ago there was 4 such services in the timetable. I can't remember if they announced over the station tanoys about them being fully declassified like they did for the ones that were.
MrJeeves
28 Aug 2015
Burgess Hill
I can't find any mention of this being the case.
Southern's site states this route is always declassified, and the timetable information reflects this too.
The fact people are getting this wrong on a railway forum is really just evidence that it is a confusing and not especially ideal situation.
Isn't the railway pro-pedancy?
They may as well remove first class from all the eight-car sets, as there's only the odd eight-car working on the mainline where first class is required
They cover for 700/1s quite frequently, and there are also a number of diagrams which do GN work, alongside the 387s which do have first.
