To any current Southern (or any Govia franchise for that matter) employees: do you have an internal rewards site with things like Cineworld tickets etc. on?
There's still plenty of time for changes to the service pattern baring in mind that the proposed service pattern is probably the minimum obligations for the serviced and Govia will probably be able to introduce more services if they like
All interesting stuff. I'm wondering what will happen with liveries?
Go-via announced that they are keeping the southern branding.... I presume that means southern livery will remain on all non-Thameslink stock. (I hope not cos it's due a change)
I'm pretty sure that they will want rid of first capital connect livery as soon as when they take over the running from September, wonder if they will just remove all the vinyl and run around in the undercoat underneath.
And have we heard that the tsgn livery on those couple of 365s will definitely be the new livery for all Thameslink stock??
I personally hope that they roll this out en-masse, but with the blue on the doors also being on that thick white diagonal stripe at the ends of each carriage. Brand all of it 'Southern'.Presumably though 'Thameslink' livery will be on 700s only - and they are not likely to be moved to any other routes, given their specialist nature. Likewise there should be little reason for any 377/x to appear on the GN, or whatever stock the GN sub brand is left with for the Kings Cross services appearing elsewhere than on the GN.Perhaps a bit messy and if stock is moved, even more confusing?
Can't the defunct Capital Connect stock be taken over by Northern? They are much longer then the majority of Northerns stock.
They're bringing back Thameslink aren't they? And using Great Northern for the GN route. Trains that run through from the ECML to the core and beyond presumably also being branded Thameslink?
There needs to be a 'catch all' name, like the Govia logo and 'Southern', 'Thameslink' and 'Great Northern' just written as text.
From September, you could keep Capital Connect but with the First logo removed on a temporary basis.
I too hope that they change the livery, I like Southern's but I prefer the new Thameslink liveryI personally hope that they roll this out en-masse, but with the blue on the doors also being on that thick white diagonal stripe at the ends of each carriage. Brand all of it 'Southern'.
In fact I'd like to see this livery applied nationwide, but with differing colours for the doors and diagonal stripe for each franchise, but I can only dream :P
Sorry if it's already been discussed but is there any word on how they plan to increase capacity to Uckfield?
Suggestions of 172s from GOBLIN.
But Southern won't want a few non-standard trains on its patch.
Class 165 Networkers from GW are another possibility, maybe exchange all their 170 fleet for them.
Otherwise they'll poach 170s from further north.
RE - Brighton to Cambridge
When travelling Brighton to Bury St Edmunds....The cynical side of me thinks any cheap tickets between these two destinations, will still involve a change at Victoria/London Bridge and Kings Cross/Liverpool St and Ipswich!![]()
As at the moment, no advance ticket routes me BTN to St Pancras, but always BTN to VIC, then tube to KingsX , or FCC to London Bridge, then AGA Liverpool St/Ipswich.
Interesting thanksSuggestions of 172s from GOBLIN.
Would FGW want a mixed length micro fleet with them though when they could keep their networker turbos and retain a relatively common fleet?For a 50% increase in capacity they would need 21 extra carriages however the 6 170/6s only deliver 18 extra carriages. London Midland would also be short changed with 2 carriages missing.Would 6 x 170/6 from LM with LM getting the GOBLIN 172s work?
Interesting thanksWould FGW want a mixed length micro fleet with them though when they could keep their networker turbos and retain a relatively common fleet?
However following Scottish electrification projects I wonder if ScotRail could release 7 170/4s which would be 21 carriages to southern. That would deliver the planned 50% increase and would be possible since the only fixed assets of the ScotRail franchise are the 380s.
Chase Line Electrification would mean LM could cope with the small defecit in 170s. If you move the GOBLIN 172s to LM (and perhaps LM swap four 170/5s with the Chiltern 172s) that would remove some of the micro fleet issues, just a thought.
Interesting looks as if there will be a few options available to GoVia for their capacity increase.
So it's only going to be 16tph through the core off-peak? I thought the idea was a minimum of 20?
The previous 'provisional timetable', (which most on this forum was amadamant wasn't going to change), also said there was going to be all day services to Caterham, peak only to Tunbridge Wells and Ashford, and all day to Maidstone. What's happened to these?
They can't run the diesels to Victoria (Central side) without turning the fire alarms off first as the smoke extractors were placed to deal with the old thumpers not the new turbostars.
Clearly there would need to be some work done i.e. Coupling changes to the 170s going south and loos fitted to LO 172s coming north.
I see your earlier point about 50% capacity but with a larger fleet of 171s south of the Thames give the option of better diagramming, dont know the patch?
