Going to Heathrow, worried about crowds.
island
30 Dec 2010
If the flight is at 1030, you do not need to be there for 0730. Many airlines may not even have opened their check-in desks by then. (BA, for example, opens check-in for flights between two and three hours before departure.) Furthermore, as previously mentioned, most airlines will charge excess baggage on a 25kg-suitcase, primarily due to 'elf 'n' safety rules stating bags over 23kg must only be handled by two people. Finally, conformance was mentioned above but at this point in time it only applies to BA and Virgin, neither of which operate from T4 where the OP appears to be going. (It is rolling out to other airlines at Heathrow next year.)
As a regular traveller between Southeastern-land and Heathrow, my suggestion for that route is Catford to Victoria, District to Barons Court or Hammersmith, and pick up the Piccadilly there. Next best is Catford Bridge to Charing Cross and walk down to Embankment for the District.
I do not encourage going from Catford Bridge either to London Bridge or Waterloo East for the Jubilee then changing at Green Park (horrendously long walkway) or going to Charing Cross and joining the Bakerloo line (also long walkway and the change to the Piccadilly at Piccadilly Circus isn't great either). The route changing at London Bridge and Green Park is, however, step-free.
greatkingrat
20 Jan 2011
There aren't any trains from Catford to Victoria. You would either have to go from Catford to Blackfriars, or change again at somewhere like Peckham Rye.
island
30 Dec 2010
You'll have to trust me when I said I meant Blackfriars :) District goes past there too.
30907
Given the choice with a 25kg suitcase Catford Bridge wins on level access versus steep steps!
rajguna
5 Oct 2013
The early time is not to win the race of check-in, it's to miss the rush at central London.
The baggage allowance is 30kg (+ 7kg hand luggage) so 25kg and no hand luggage shouldn't be an issue. I've flown with luggage heavier than 23kg twice this year and I've never had to pay extra for any of them, only a little tag was attached which mentioned that it was overweight.
Are there any advantages for going through Blackfriars rather than Charing Cross? Like 30907 said I can simply walk from the house right onto the train at Bridge but have to climb stairs at CTF and even though it's not much of an issue I am really lazy.:)
rajguna
5 Oct 2013
I've never been to Embankment before, is there more than one set of stairs?
island
30 Dec 2010
From memory it's just the one flight to the sub-surface lines.
