Getting to Harwich ferry during July strike action
johncrossley
30 Mar 2021
What are the alternative bus/coach options for getting to the Harwich ferry during July strike action, if it occurs? What are the parking options for three days? Recommendations for free on street parking that is reasonably safe or relatively cheap car parks would be welcome.
36270k
7 Jan 2015
Trimley
A bit slow but there is a bus No 103 between Colchester/Manningtree/Harwich
Suggestion:
Get the train from Liverpool Street to Manningtree
Walk to the Skinners Arms ( About 10 mins )
Then 103 bus to Harwich
Mcr Warrior
8 Jan 2009
Suggestion:
The bus number varies, more often it operates (hourly) as the 104, occasionally as the 102 or 103. Journey time from Manningtree to Harwich is about 45 minutes. Bus is operated by 'First' and normally originates from Colchester, if that's more convenient for connections.
30907
Assuming you are heading for HPQ aka International Port, the 102 is a very limited service, and the other routes will drop you a mile away.
johncrossley
30 Mar 2021
Yes, sorry, I basically mean the foot passenger terminal for the Hoek van Holland ferry. I can live with a walk or taxi ride up to about 1.5 miles away. Presumably parking at the terminal itself is very expensive and you might as well take the car to the Netherlands if you are doing that.
30907
That's OK then. The direct walking route from Dovercourt Hospital bus stop is 1.1m according to G*****maps and looks fairly accurate and tolerable with pavements.
