Getting between Tyndrum stations
EM2
16 Nov 2008
The home of the concrete cow
Google Maps suggests it's fifteen minutes or so to walk between the Lower and Upper stations.
Does that seem right? Is it a fairly easy stroll?
6Gman
1 May 2012
Upper to Lower is presumably easier than Lower to Upper.
:D
InOban
12 Mar 2017
Much easier to stay on train to Crianlarich, and have a cup of tea while you wait for the other train...
alex17595
15 Mar 2013
Burton on Trent
It's very much easier to go downhill. There is a little cut through you can use rather than going around the road up to the Upper station.
LA50041
20 Feb 2017
If you're reasonably fit it can be done in about 15 minutes, but it is a very steep climb to upper.
If you've got some time the there's a pub that does a decent pint and snacks just along the main road
sdrennan
23 Feb 2011
Did this once on a sunday traveling from Oban to Mallaig. Changing at Crianlarich would give me a 40minute change.
I decuded to change at Tyndrum and have a walk and go to the Green Welly shop with an extra 35 mins.
It is easy from Lower Tyndrum to the vilage but definitely a hike to the Uppet station especially as I had a large rucksack. Fine if you are reasonably fit
As others have said, definitely easier downhill. There's a great fish and chip shop on the main road too, and they sell beer.
Also, if you will be doing this in the dark, take a torch. The road to Upper is through trees and practically a blackout!
QueensCurve
22 Dec 2014
An easier stroll than Ranoch Station to Dalwhinnie, which I did in September 1987. Followed by a much needed steak served on a cast-iron Bull at the Loch Ericht hotel.
Richard1960
28 Nov 2012
Harlow
Midge season is generally late May to late October. They prefer still, cloudy weather, and dislike bright sunshine and/or strong wind.
Was on Loch Awe station last April a steep climb down from the hotel it serves,got warned about the midges on the way down.!
PaulLothian
27 Sep 2010
Linlithgow
Also depends how far north you are - we have been well bitten in Gigha (far south) in late April, but rarely encounter any on our annual week in Wester Ross and Sutherland at the very end of May/beginning of June.
Interestingly, despite the data suggesting that the average onset of spring's moving northward across the British Isles is becoming earlier year by year, we have not tracked the same level of change in midge activity over the past 15 years during our late spring stravaiging up and down the west coast.
tsr
15 Nov 2011
Between the parallel lines
Fair play! Loch Ericht the whole way or did you bag Ben Alder?
And that's probably an easier walk between stations than Corrour to Fort William via the Abhainn Rath river... a route which shows you the very definitions of the words stunning, desolate, boggy, cold and windy. Even the midges didn't seem to like it there.
D1009
22 Feb 2012
Stoke Gifford
Slightly OT, but should you tire of the wilderness that is Rannoch moor, I can recommend the CityLink coach between Tyndrum and Fort William which follows a completely different and magnificent route through the Pass of Glencoe, Ballachulish bridge and the shores of Loch Linnhe. It's also quicker than the train.
It's the way I always go, albeit by car.
endecotp
23 Apr 2014
Sometimes there is a good bus/train connection of Bridge of Orchy that gives you time to have lunch in the hotel.
I'd definitely recommend this bus/train loop to anyone considering a West Higland Line daytrip.
snowball
4 Mar 2013
That's the obvious and direct route for anybody going by road - the A82 trunk road,
Essan
22 Feb 2017
Evesham / Lochailort
Unless there's an accident or landside and the road is closed for any length of time between N Ballachullish and Corran Ferry. In which case the diversion is about 250 miles - via the A9!
xotGD
4 Feb 2017
adamedwards
4 Apr 2016
Anyone with a bike should try cycling Connel Ferry to Fort William along the Caledonia Way much of which is former railway and has fab views.
