General Knowledge Quiz
Gloster
4 Sep 2020
Up the creek
Flashbacks. When I went to spend a year in a Danish student block in 1990, my neighbour had a habit of doing this. Ten hours of side 1 (his favourite) drove me up The Wall. (This is true.) The disruption to my sleep and work patterns have almost certainly been a cause of things going downhill from then on.
Efini92
14 Dec 2016
Nowadays we have EQ or bass and treble knobs which'd do the same thing.
Okay, maybe too niche but let's give it a go.
If you were to play Pink Floyd's The Wall on continuous repeat, what would it reveal?
It’s one big loop
Strat-tastic
27 Oct 2010
Outrageous Grace
A worn out stylus.
It's on CD too dear boy ;)
Oh no. Maybe if he'd played the whole thing...
It’s one big loop
Yes, but why?
Strat-tastic
27 Oct 2010
Outrageous Grace
Because outside the wall ends with “this is where” and in the flesh? Starts with “it begins”. Or something along those lines.
Close enough. It is "isn't this where.... we came in?", spoken over the same musical background, creating a circular experience.
Your concept album to explore (or something :D)
Mcr Warrior
8 Jan 2009
Also reckon that it's 'micro'. But is the reason that the symbol for 'micro' uses a Greek alphabet letter, whereas all the others don't?
DaleCooper
2 Mar 2015
Mulholland Drive
DaleCooper
2 Mar 2015
Mulholland Drive
This is a bit desperate, but.... milli is the only one to include the same vowel twice.
No
Well, if you are going to be desperate...Kilo is the only one in the phonetic alphabet or a Russian submarine type.
No
The SI unit of mass is the kilogram not a gram if I am making sense.
Having re-read your answer I think you mean it's the only one to be included in an SI unit which is correct. My intended answer was that apart from kilo(k) all submultiples use lower case and all multiples use upper case. I'm going to accept your answer, your turn...
