General Knowledge Quiz
MotCO
25 Aug 2014
Neither of these, I'm afraid. (Are there many adult fans of space hoppers?)
The product in question is plastic, specifically ABS.
If ABS, I'm thnking of Lego, but that was definitely around before 1977. Was Duplo invented later?
krus_aragon
10 Jun 2009
North Wales
We seem to be drifting further away, sadly. The product I'm after is Lego's Technic range.
Early sets (up to 2000 or so) were based upon basic studded Lego bricks with holes for axles:
Whereas recent sets use beams with no studs:
These give a smoother look to the final model, but the construction method is markedly different. Whereas building with studded bricks tends to go from the ground up, studless construction means you need to build more skeletally, from the inside out.
As @MotCO got so very close with Lego's Duplo range, I'll offer the floor to them.
MotCO
25 Aug 2014
Thank you - I don't think I would have got the final answer.
What links the following:
  • Poduce and discharge
  • A US magazine title
  • A small arachnid
  • A leading UK economic forecasting group
Neo9320
17 Feb 2019
Somerset
Time:
Emit - discharge
Mite - small arachnid
Time - US magazine
Not sure about the economic group
MotCO
25 Aug 2014
Time:
Emit - discharge
Time - US magazine
Correct - your stay in hospital is obviously doing you good!
The economic group is the Ernsy & Young ITEM club, which used to be regularly reported in the Guardian.
Please take the floor.
Neo9320
17 Feb 2019
Somerset
They must be pumping me with some experimental mind drugs!!
here’s one off the top of my head:
To what does the term ‘Burtonisation’ refer?
xotGD
4 Feb 2017
Criminals getting themselves a suit before appearing in court.
Neo9320
17 Feb 2019
Somerset
Some form of water treatment or purification?
I shall give you that!
it’s the process of adding minerals (mainly gypsum) to the water before brewing beer. Gives the water the same great quality of burton on trent water, the finest brewing water in the land.
your turn to be the brewmaster!
Gloster
4 Sep 2020
Up the creek
Yorkshire used to be divided into three ridings (plus York). Which other county in the British Isles had ridings in the present century?
As a bonus, which other county used to have three ridings?
