General Knowledge Quiz
Jona26
2 Jan 2013
West Sussex
If the port is Bristol then thinking of rhyming slang: Canberra is situated between two mountains which the indigenous peoples likened to a woman's breasts. Is Manchester similarly endowed?
Well done - correct in all respects. The etymology of Canberra and Manchester does indeed refer to their surrounding hills and similarity to breasts.
Don't go milking your success
DaleCooper
2 Mar 2015
Mulholland Drive
Thanks, I'm glad I didn't make a tit of myself.
Next question:
This BBC creation has been in production from 1975 to the present day, it is neither a television nor a radio programme. What is it and what name was it given by the BBC?
Cowley
15 Apr 2016
Devon
The Radio Times?
Or maybe one of the gardening or housekeeping type magazines?
ComUtoR
13 Dec 2013
1975 was the date of the previous EU vote so I was thinking along those lines.
Did they come up with the election results map ?
DaleCooper
2 Mar 2015
Mulholland Drive
I would think such maps are older than 1975, anyway that's not the answer.
Blue Peter Badges ?
Realized BPBs are older than 1975, based on when I first saw the programme
I thought someone would suggest that particularly after I gave this rather obscure hint:
I have a couple of them at home.
DaleCooper
2 Mar 2015
Mulholland Drive
Illuminati mind control devices?
While it is true that I am a Grand Wizard of the Illuminati (keep that under your hat) and have a stockpile of mind control devices they are a Reptilian Elite design rather than BBC therefore that answer is incorrect.
would this be something that was used commercially and not just within the BBC?
Yes, as I said I have a couple and so could you if you wished.
Another hint:
I've just weighed one of mine (oo er missus!) it's about 5kg.
dgl
5 Oct 2014
No research done on this but could it be the log periodic antenna used as both receive and transmit antenna's at most low power relay stations.
Or could it be the monitor speakers they designed for use in their studios (LS5/8).
Sent from my Lumia 625 using Tapatalk
DaleCooper
2 Mar 2015
Mulholland Drive
After a bit of research Is the answer Matrix H decoding, used on FM radios.
Sources
http://www.bbc.co.uk/rd/publications/rdreport_1977_02
https://en.wikipedia.org/wiki/Matrix_H
After what I know has been a lot of effort on your part I'm afraid I have say "No not that".
I'm going to give it to you although I suspect the LS5/8 weighs a lot more than 5kg and I think they are out of production. The loudspeaker I meant is the LS3/5A miniature monitor designed for use in outside broadcast vans, highly valued by audiophiles and attracting silly prices on eBay.
It's your turn dgl...
The 24 hour deadline has passed, anybody want to jump in?
Gutfright
22 Jan 2016
By my reckoning 24 hours has ticked away.
How about the first person to name six current or former England football internationals whose name begins and ends in the same letter (like Danny Ward only not Welsh) gets the floor?
Gutfright
22 Jan 2016
Stanley Matthews
Theo Walcott
Shaun Wright-Phillips
Neil Franklin
Adam Lallana
Sammy Crooks
Well done, you could also have had Stan Bowles, Ugo Ehiogu, Robbie Fowler,
Nigel Martyn, Ray Parlour and Nigel Winterburn.
Your turn to take to the pitch...
