GBRF Sleeper Class 92 rescue Class 66
XCTurbostar
13 Sep 2014
Just seen at Nuneaton a repainted Class 92 with a Class 66 behind hauling an intermodal. I believe it was 4L18.
Thanks,
Ross
GB
16 Nov 2008
Somewhere
66 hadn't failed it is just DIT. Persuambly will be used to take it to Felixstowe from Ipswich and back then used on tanks or Parkeston - Whitemoor trip job tomorrow.
Altfish
16 Oct 2014
Altrincham
92033 ran light engine from Crewe to Trafford Park and then was put on the front of the Gbfr Trafford Park to Felixstowe service this afternoon, double headed with 66747 which brought the train into TP this morning.
It was a planned move.
alexl92
12 Oct 2014
Double-headed 92+66? Is that a regular thing? There's a lot of power there... is double-heading a diesel and an electric any different to d-h with two diesels or two electrics?
DownSouth
10 Dec 2011
I expect that the 66 would have been put offline (i.e. idling only, and unattended) for that one, rather than providing power. A Class 92 has way more power than a UK intermodal train (short, and lightly loaded with only single-stack containers) could ever need, certainly one on that route which doesn't have any significant gradients.
This sort of move is common practice for freight operators who can use it to shift locomotives around without paying the higher costs of a light engine move. This even applies to the private Class I Railroads in the USA, despite them owning their own tracks and not being above-rail operators who have to pay the below-rail operator for a train path.
If that combo was double-heading, it would have required a crew in each loco as the multiple unit working systems are not common.
So far as I know, 'automatic' electric+diesel multiple unit working is only done as routine practice on a couple of lines in South Africa, and even there it requires the new electric locos be fitted with a bespoke multiple unit working system that is able to talk to the diesel locos.
DarloRich
Fenny Stratford
the 66 will have been dead. It will have just been hitching a lift to, I guess, Ipswich to pick up further traffic.
TheEdge
29 Nov 2012
Norwich
Are the sleeper 92s going into a their own sleeper use only pool or will they still be used on normal freights?
